| Using gcc discovery scanner with gcc cross compiler within a tool chain [message #119562] |
Mon, 06 September 2004 05:42   |
Eclipse User  |
I'm trying to write a toolchain (managed build) which uses a gcc cross
compiler (so cdt doesn't call "gcc" but "ppc-amigaos-gcc" to compile). If I
use DefaultGCCScannerInfoCollector for my newly created target, I only get
the include paths for the host gcc compiler but not for the target compiler.
Is there a possibilty to tell the discovery scanner to use a different
command? (it iss possible to do this manually within standard makefile
project, but by using the plugin the developer shouldn't care about this).
Thanks in advance!
Ciao,
Sebastian
| Re: Using gcc discovery scanner with gcc cross compiler within a tool chain [message #120097 is a reply to message #119891] |
Wed, 08 September 2004 08:21   |
Eclipse User  |
Hello Sean and Vladimir,
I think specifing the includes manually with the builtin option is not
possible, because I don't know where the system includes exactly are located
on the users system.
Altering the prefs has the disadvantage, that then the discovery scanner
works only properly for the cross compiler. But I guess at the moment it is
the only possibility until 2.1.0 is out (I'll mention this in the docs).
Thanks for the hint.
Ciao,
Sebastian
FUDForum. Page generated in 0.06741 seconds
