Home » Archived » Test and Performance Tools Platform (TPTP) » Get console result from TPTPProcess
Get console result from TPTPProcess [message #119534] Fri, 14 December 2007 07:43 Go to next message
Originally posted by: cguibert.axway.com
Hello
In my test, I need to run an application that write some data to the
console, in particularly, whether the start process was OK or not. So I
need to get the console output in order check if my TestMethod is success
or failed.
I'm using the TPTPProcess sample to do that, but I'm not able to get the
console output using the sample.
I did the below tests:
Test1:
proc.setExecutable("myApplication");
proc.setParameter(" >toto.out 2>toto.err");
Test2:
proc.setExecutable("MyTest.bat")
where MyTest.bat contains the following:
@echo off
myApplication >toto.out 2> toto.err
But I have no ways to get the console output in my Test.
I guess I missed something but I can't see what.
Do you have any idea ?
Re: Get console result from TPTPProcess [message #119559 is a reply to message #119534] Sat, 15 December 2007 11:32 Go to previous messageGo to next message
Console data should be processed by the another way.
What API are using - new (org.eclipse.tptp.platform.execution...) or old
(org.eclipse.hyades.execution...)?
Igor
Re: Get console result from TPTPProcess [message #119674 is a reply to message #119559] Mon, 17 December 2007 11:09 Go to previous messageGo to next message
Hello Igor
The new API are used. What 'other way' should I use ?
CG
Re: Get console result from TPTPProcess [message #119687 is a reply to message #119674] Tue, 18 December 2007 02:57 Go to previous message
Hi CG,
To get console data you need to set a DataProcessor to the console:
IConsole console = process.getConsole();
console.setDataProcessor(...);
Please find the console example in the
org.eclipse.tptp.platform.execution.samples.TPTPProcess.java sample.
Igor
Previous Topic:[AGR] AGR's future???
Next Topic:Problems with TPTP Profiler
Current Time: Tue Dec 02 10:44:55 EST 2025
Powered by FUDForum. Page generated in 0.05166 seconds
