Home » Eclipse Projects » Equinox » Hide filter access to WEB-INF
Hide filter access to WEB-INF [message #119511] Mon, 13 October 2008 22:41 Go to next message
Hi, Im working on a web-application using Eclipse-Equinox server side, I
have integrated myFaces to it. I need the WEB-INF/web.xml file to set some
configurations for myFaces, but I dont want that the users have access to
this resource.
My web resources are under the /web directory, so I have /web/WEB-INF
JspServlet _jspServlet = new JspServlet(context.getBundle(), "/web");
Is there a way to hide to the browser the WEB-INF resource, and any files
or sub directories inside it?
Thanks.
Re: Hide filter access to WEB-INF [message #119542 is a reply to message #119511] Mon, 13 October 2008 23:18 Go to previous messageGo to next message
The JSPServlet has built in code to filter out request to WEB-INF. Do you
have a situation where this isn't working?
Looking at the code the match is not case insensitive so perhaps there is a
bug lurking here. Please let me know here.
Anyway... probably the easiest way is to register the JSPServlet with an
extension alias e.g. something like "/*.jsp" or "/web/*.jsp". I should add
that the current OSGi HTTP Service spec does not provide support for
extension aliases so this is specific to the equinox http service
implementations (both servletbridge and jetty-based implementations).
Another possibility is to register a special 404Servlet at WEB-INF although
again it's important to be careful about case sensitivity issues.
HTH
-Simon
"Ignacio M" <nmorenor@gmail.com> wrote in message
news:5ff6ceca6c0f8833c24207229a20a05e$1@www.eclipse.org...
> this resource.
> Thanks.
Re: Hide filter access to WEB-INF [message #119931 is a reply to message #119542] Tue, 21 October 2008 20:59 Go to previous messageGo to next message
Im checking this, like I say Im using apache myFaces Servlet, but Im using
the ClassLoader from your JspServlet. I have made a CtxListenerAdaptor
that extends from HttpServlet, then Im adding this to the service method...
public void service(HttpServletRequest req, HttpServletResponse resp)
				throws ServletException, IOException {
			String pathInfo = req.getPathInfo();
			System.out.println(pathInfo);
			if (pathInfo != null && pathInfo.contains("/WEB-INF/")) { //$NON-NLS-1$
				resp.sendError(HttpServletResponse.SC_NOT_FOUND);
				return;
			ClassLoader original = Thread.currentThread()
					.getContextClassLoader();
			try {
				Thread.currentThread().setContextClassLoader(jspLoader);
				delegate.service(req, resp);
			} finally {
				Thread.currentThread().setContextClassLoader(original);
but when I call the getPathInfo I get a null value this class is called to
get this info
org.eclipse.equinox.http.servlet.internal.HttpServletRequest Adaptor is
there a fix for this issue. Or we need to search a workaround for this.
Re: Hide filter access to WEB-INF [message #119942 is a reply to message #119931] Tue, 21 October 2008 21:14 Go to previous messageGo to next message
But there is a catch, when I do a request to
http://localhost:8080/jsf/WEB-INF/web.xml this service method is not
called...
Ignacio M
Re: Hide filter access to WEB-INF [message #119954 is a reply to message #119942] Tue, 21 October 2008 21:31 Go to previous messageGo to next message
I think that path info is working as expected, because Im registering the
servlets with this.
_http.registerServlet("/jsf/*.jsf", _servlet, initparams,_context);
so the /WEB-INF/web.xml does not match with this alias. I need to think in
another way...
Re: Hide filter access to WEB-INF [message #120030 is a reply to message #119542] Wed, 22 October 2008 20:31 Go to previous messageGo to next message
What do you think if we modify this class
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet
Making it extend from HttpServlet instead implemet Servlet from her self,
and add this lines...
return;
do you think that it will cause a performance problem or anything else? I
test this change and it is working Im not able to view nothing inside a
WEB-INF direcotry...
Re: Hide filter access to WEB-INF [message #120058 is a reply to message #120030] Wed, 22 October 2008 21:46 Go to previous messageGo to next message
Ignacio,
I would not want to make a special rule like this since the OSGi Http
Service makes no special provision for a WEB-INF path.
Here are a couple of alternatives I'd suggest:
1) For your "resource" registration use a custom HttpContext that filters
out the WEB-INF folder.
2) Use a custom ResourceServlet and filter out WEB-INF like you've shown.
3) Package your resources in a separate folder hierarchy from your JSF/JSP
components that need a WEB-INF folder.
Are any of those workable?
-Simon
news:8016f7001f44be975eb327715bb339f5$1@www.eclipse.org...
> return;
Re: Hide filter access to WEB-INF [message #120131 is a reply to message #120058] Thu, 23 October 2008 22:11 Go to previous message
The HttpContext implementation sounds good... Thanks, with this
implementation can we filter any other directory on my web app, based on
javax.security.auth.Subject?? This could be rely good... Today I was
looking to this plugin org.eclipse.equinox.examples.httpsecurity, I think
that is a good base to implement this new HttpContext. Ill try that and
probably I will post more questions thoughts on this later...
many Thanks
Ignacio.
Previous Topic:Running multiple instances of servletbridge in a tomcat instance
Next Topic:Re: Problem integrating equinox transforms (xslt)
Current Time: Thu Nov 20 05:49:36 EST 2025
Powered by FUDForum. Page generated in 0.05406 seconds
