| Override property problem [message #119489] |
Wed, 01 March 2006 09:38  |
I have class which has String attributes
For example
public class Person{
String name;
public String getName(){
return name;
public String setName(String name){
this.name=name;
Let's say that this class is visualised in the VE editor and the
attribute "name" is displayed and can be edited in the Properties view.
I do not know how to associate my own cell editor (for the Properties
view) with the attribute name.
I have tried to use the approach from the "Extending The Visual Editor:
Enabling support for a custom widget tutorial" I made something like this:
I created the Person.override file and made all things to make it work.
<xmi:XMI xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:org.eclipse.ve.internal.cde.decorators="http:///org/eclipse/ve/internal/cde/decorators.ecore"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:event="event.xmi">
<event:Add featureName="eStructuralFeatures">
<addedEObjects xsi:type="ecore:EReference" name="name"
unsettable="true">
<eAnnotations
xsi:type=" org.eclipse.ve.internal.cde.decorators:BasePropertyDecorator "
cellEditorClassname="me.testpackage/me.myTestPackage.MyPersonCellEditor "/>
</addedEObjects>
</event:Add>
</xmi:XMI>
The problem is that the "name" attribute of the Person class is still
edited by the default editor for the Strings:-(. (The override is
applied to the person class).
| Re: Override property problem [message #119897 is a reply to message #119533] |
Mon, 06 March 2006 04:38  |
I have found the problem, indeed the errors were logged, there was an
syntax error in my .override. I must admit that I hate editing those
files:-).
Thanks for help
Rich Kulp wrote:
> That should of worked. Were there any errors logged in the .log file? Do
> a clear cache and try again, we may of cached the old override file and
> so didn't know it had changed.
> To clear the cache:
> 1) Open a VE then close it and all VE's.
> 2) Do a Project->Clean...->Clean All Projects
> 3) Wait for build to finish
> 4) Open your VE.
> Another possibility is that your override file is not being picked up.
> First are you sure your container is in your classpath? That is how we
> determine which overrides to process.
| Re: Override property problem [message #612229 is a reply to message #119489] |
Wed, 01 March 2006 10:44  |
To clear the cache:
4) Open your VE.
Rich Kulp
| Re: Override property problem [message #612258 is a reply to message #119533] |
files:-).
Thanks for help
> To clear the cache:
> 4) Open your VE.
FUDForum. Page generated in 0.04789 seconds
