Home » Eclipse Projects » GEF » Connection Retarget problem
Connection Retarget problem [message #119436] Wed, 25 February 2004 13:07 Go to next message
Originally posted by: bharath.starthis.com
I have a source edit part and a target edit part connected by an edge edit
part. When I move the edge from one target and reconnect it to another,
the edge is removed from the original target and gets affixed to the new
target. The problem is, the edge does originate from the source anymore.
It positions itself at the top left corner of the screen.
If I save my editor and re-open it, I can see the correct result. I tried
to change refreshVisuals() of the edge edit part to reflect the change but
it does not work. Did anybody come across this problem?
Thanks in advance.
Bharath.
Re: Connection Retarget problem [message #119477 is a reply to message #119436] Wed, 25 February 2004 17:21 Go to previous messageGo to next message
It sounds like the source connection anchor is getting messed up. I would
try stepping through the code and see what is happening. I think there are
some places where if you aren't provide a valid anchor, we create a bogus
one in the top-left so that you can see the connection and know that things
are bad.
"Bharath" <bharath@starthis.com> wrote in message
news:c1io91$959$1@eclipse.org...
> Thanks in advance.
> Bharath.
Re: Connection Retarget problem [message #119490 is a reply to message #119477] Wed, 25 February 2004 19:16 Go to previous message
Hi Randy,
Thanks for your advice. The anchor may not be the problem because I return
just a ChopboxAnchor which renders jagged edges. I wrote my own anchor to
correct it but I am able to place the anchor ONLY on one specific side
(left or right). My edge should go to the top, left or right side of the
edit part (rectangle) and I am looking for a function which will indicate
the side of the rectangle on which the edge intersects.
If I have to refresh the edge edit part, I only need to attach the current
source and target after retargetting, right?
Thanks!
> are bad.
> > Hi,
> > Thanks in advance.
> > Bharath.
Previous Topic:DND Problems with j2sdk-1.4.*
Next Topic:Efficiently Reloading the diagram
Current Time: Wed Nov 05 06:25:39 EST 2025
Powered by FUDForum. Page generated in 0.04515 seconds
