Home » Archived » Apogee » apogee resource model
apogee resource model [message #910] Thu, 13 July 2006 09:49 Go to next message
I noticed in your proposal that it indicated that a resource model was
created and was being refactored to work with Apache JackRabbit. Is this
work posted or available anywhere?
Glenn Everitt
Re: apogee resource model [message #1000 is a reply to message #910] Mon, 17 July 2006 13:03 Go to previous message
--------------030804090007090902090109
Glenn:
Subversion access is here. This gives you source code for the
plugins, but not the plugin bundles themselves.
https://svn.nuxeo.org/pub/Apogee
To run the Apogee wizards, including the Jackrabbit wizard, use the PDE
Plugin Manifest Editor to launch an new Eclipse "application" for the
Jackrabbit plugin. This forces the Apogee wizards to be loaded as well.
Or, you can export the plugins bundles and install them into your root
Eclipse. But my advice is not to do this. Treat Apogee as under
active development for now. Until there is an Eclipse update site for
Apogee, just treat it as PDE.
With the Apogee plugin loaded, you should see an Apogee perspective in
Eclipse. No documentation gets installed under Eclipse.
Read the code.
-- Dan
>Glenn Everitt
<html>
<head>
<title></title>
</head>
<br>
Glenn:<br>
<br>
Subversion access is here.&nbsp;&nbsp;&nbsp; This gives you source code for the
plugins, but not the plugin bundles themselves.<br>
<br>
<font face="Courier New, Courier, monospace"><a class="moz-txt-link-freetext" href="https://svn.nuxeo.org/pub/Apogee">https://svn.nuxeo.org/pub/Apogee</a><br>
</font><br>
Jackrabbit plugin.&nbsp;&nbsp;&nbsp; This forces the Apogee wizards to be loaded as
well.<br>
<br>
Eclipse.&nbsp;&nbsp;&nbsp; But my advice is not to do this.&nbsp;&nbsp;&nbsp; Treat Apogee as under
active development for now.&nbsp;&nbsp;&nbsp; Until there is an Eclipse update site
for Apogee, just treat it as PDE.<br>
<br>
Eclipse.&nbsp;&nbsp;&nbsp; No documentation gets installed under Eclipse.&nbsp;&nbsp; <br>
<br>
Read the code.<br>
<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; -- Dan<br>
<br>
<br>
<br>
<blockquote cite="mide95j26$r0p$1@utils.eclipse.org" type="cite">
<pre wrap="">I noticed in your proposal that it indicated that a resource model was
Glenn Everitt
</pre>
</blockquote>
<br>
</body>
</html>
--------------030804090007090902090109--
Re: apogee resource model [message #564494 is a reply to message #910] Mon, 17 July 2006 13:03 Go to previous message
Glenn:
Read the code.
-- Dan
>Glenn Everitt
<html>
<head>
<title></title>
</head>
<br>
Glenn:<br>
<br>
<br>
</font><br>
well.<br>
<br>
<br>
<br>
Read the code.<br>
<br>
<br>
<br>
<br>
Glenn Everitt
</pre>
</blockquote>
<br>
</body>
</html>
Previous Topic:Re: Want EFS bundle for Jackrabbit DBFileSystem
Next Topic:Re: Want EFS bundle for Jackrabbit DBFileSystem
Current Time: Sun Nov 09 08:13:38 EST 2025
Powered by FUDForum. Page generated in 0.04163 seconds
