Home » Language IDEs » ServerTools (WTP) » web.xml wrong editing with
web.xml wrong editing with [message #119402] Mon, 11 July 2005 13:17 Go to next message
Hi, I use Tomcat 5.5 eclipse 3.1 wtp m5
Got an error:
cvc-complex-type.2.4.a: Invalid content was found starting with element
'display-name'. One of
'{"http://java.sun.com/xml/ns/j2ee":servlet-class,
"http://java.sun.com/xml/ns/j2ee":jsp-file}' is expected.
when I use anannotated java classes
Re: web.xml wrong editing with [message #119592 is a reply to message #119402] Mon, 11 July 2005 18:56 Go to previous messageGo to next message
Which version of XDoclet are you using? If not 1.2.3, give that one a
try. I believe I saw something like this in an earlier version that was
fixed in 1.2.3, but I'm not certain it was the same error.
Larry
> Got an error:
Re: web.xml wrong editing with [message #119812 is a reply to message #119592] Tue, 12 July 2005 06:40 Go to previous messageGo to next message
> Cheers,
> Larry
>> Got an error:
>> element 'display-name'. One of
I use XDoclet 1.2.3
Re: web.xml wrong editing with [message #119955 is a reply to message #119812] Tue, 12 July 2005 11:33 Go to previous message
Ok, it must be a different problem. Assuming you haven't already
figured out the problem, can you post the web.xml, or the portion that's
causing the problem.
Larry
>> was fixed in 1.2.3, but I'm not certain it was the same error.
>> Cheers,
>> Larry
>>> Got an error:
> I use XDoclet 1.2.3
Previous Topic:Custom DTD in JSP editor?
Next Topic:XML schema saving is slow
Current Time: Wed Nov 19 20:19:38 EST 2025
Powered by FUDForum. Page generated in 0.03790 seconds
