Home » Language IDEs » ServerTools (WTP) » rdb-problem
rdb-problem [message #119294] Mon, 11 July 2005 09:15 Go to next message
I made a connection to the mySQL database using the database explorer. But I
don't see any tables. Did anyone have the same problem and would help me?
thanks in advance
Matthias
Re: rdb-problem [message #121075 is a reply to message #119294] Fri, 15 July 2005 07:51 Go to previous messageGo to next message
Hi Matthias,
Which version of MySql are you running?
Which version of the jdbc driver are you using?
We tested with Mysql 4.0.23 and 4.0.24.
We used the MySQL Connector/J 3.0.9-stable (formerly MM.MySQL) JDBC Driver
(mysql-connector-java-3.0.9-stable-bin.jar)
We tested with InnoDB and ISAM tables.
Dirk le Roux
Re: rdb-problem [message #140081 is a reply to message #121075] Wed, 21 September 2005 23:03 Go to previous message
I found this through a search... It has been more than two months but I
have the same problem.
mysql version 4.1.12
mysql connector/j version 3.1.10
I guess this should not be a surprise since the database explorer view
only shows mysql 4.0 as an option... Does this mean mysql 4.1.x is
really out of the picture?
Luis
Dirk le Roux wrote:
> Hi Matthias,
> Which version of MySql are you running? Which version of the jdbc driver
> are you using?
> Driver (mysql-connector-java-3.0.9-stable-bin.jar)
> Dirk le Roux
Previous Topic:What are the targetIDs of WST editors?
Next Topic:XML Schema validation errors when certain nesting of xsd:redefine's is reached
Current Time: Wed Nov 05 23:17:20 EST 2025
Powered by FUDForum. Page generated in 0.03681 seconds
