Home » Language IDEs » ServerTools (WTP) » JBoss 4.0.3 definitions
JBoss 4.0.3 definitions [message #119281] Mon, 11 July 2005 07:37 Go to next message
Originally posted by: thisisnot.mymail.com
The plugins I found on the newsgroup don't work for me well, I'm using
WTP M5 and eclipse 3.1;
Anyone to update their plugin?
Re: JBoss 4.0.3 definitions [message #119877 is a reply to message #119281] Tue, 12 July 2005 08:49 Go to previous messageGo to next message
Originally posted by: marko._protected_.net
Hi Srgjan!
I posted patch for WTP M5 to use JBoss 4.0.2. It had problems (Encoding
in XML file) but someone else fixed it and posted corrected version in
reply to my original post. I am still using 4.0.2 but I assume that it
should be possible to use it for 4.0.3 also.
Did you try it?
Re: JBoss 4.0.3 definitions [message #119995 is a reply to message #119877] Tue, 12 July 2005 12:18 Go to previous messageGo to next message
Originally posted by: luc_jn.yahoo.com
I will very much like that update. a link please :
Tjansk
Re: JBoss 4.0.3 definitions [message #120019 is a reply to message #119995] Tue, 12 July 2005 12:54 Go to previous messageGo to next message
> Tjansk
OK!
I will put this file for SHORT period on web site:
http://www.mrvelj.net/download/JBoss402EclipseWTP.zip
Re: JBoss 4.0.3 definitions [message #120045 is a reply to message #120019] Tue, 12 July 2005 13:26 Go to previous messageGo to next message
Thanks you Sir you made my day.
Re: JBoss 4.0.3 definitions [message #120057 is a reply to message #120019] Tue, 12 July 2005 13:37 Go to previous messageGo to next message
I have installed the zip file but I can not find jboss4.0.3 on the
servers, or does the zip file should be install in special way ?
Re: JBoss 4.0.3 definitions [message #120070 is a reply to message #119877] Tue, 12 July 2005 13:38 Go to previous messageGo to next message
Hi Marko,
I had tried that plugin some time ago but my eclipse reacted badly (I
had the JBoss as a server definition but I wasn't able to create a new
instance). Happily I found the post and this time it worked without a
flaw. Thanks a lot! Or should I say hvala? Where are you from? If you
have the time could you make a new versione for the 4.0.3?
Marko Mrvelj wrote:
> Hi Srgjan!
> (Encoding in XML file) but someone else fixed it and posted corrected
> version in reply to my original post. I am still using 4.0.2 but I
> assume that it should be possible to use it for 4.0.3 also.
> Did you try it?
Re: JBoss 4.0.3 definitions [message #120087 is a reply to message #120019] Tue, 12 July 2005 13:45 Go to previous messageGo to next message
OOOOOOOOOOOOOOOO SSSSSSSSSOOOORRRRRYYYYYYYY it is here the jboss 4.0.2 I
run eclipse with -clean.
HOOOOOOOOO boy .We people are weird, I was wondering if jboss 4.0.3 was on
is woy :)
Re: JBoss 4.0.3 definitions [message #120100 is a reply to message #120019] Tue, 12 July 2005 13:59 Go to previous messageGo to next message
How Do I selct jboss ? I have made Dynamic webproject,
then selecte Application server root(C:/jboss-4.0.2/jboss-4.0.2),
class variable(C:/jboss-4.0.2/jboss-4.0.2),then when click on finish my
server target is still Tomcat..
Help.
Re: JBoss 4.0.3 definitions [message #120466 is a reply to message #120070] Wed, 13 July 2005 09:14 Go to previous messageGo to next message
Hi Srgjan!
I am from Croatia so I do understand hvala. At this moment I am still
using 4.0.2 version of JBoss. At this moment I am very busy . I will
take a look at 4.0.3 as soon as I find time, but unless there is
something very different in 4.0.3, you should be able to use 4.0.2
definition for 4.0.3 version of JBoss.
Marko
> Hi Marko,
> Marko Mrvelj wrote:
>> Hi Srgjan!
>> Did you try it?
>>> using WTP M5 and eclipse 3.1;
Re: JBoss 4.0.3 definitions [message #120478 is a reply to message #120019] Wed, 13 July 2005 13:51 Go to previous messageGo to next message
Marko Mrvelj wrote:
>> Tjansk
> OK!
I've made the JBoss 4.0.x server definitions available as a separate
plugin, available at my website: http://www.davedunkin.com/
Just download org.jboss.ide.eclipse.serverdefinitions_0.7.0.jar and put
it in your plugins directory. No messing with the existing plugins is
required. The WTP team has said they won't include the JBoss 4 server
definitions in the main distribution, so a separate plugin is the way to go.
Dave
Re: JBoss 4.0.3 definitions [message #125267 is a reply to message #120478] Sun, 24 July 2005 06:57 Go to previous messageGo to next message
Originally posted by: mathias.kluba.laposte.net
Dave Dunkin a écrit :
> Marko Mrvelj wrote:
>>> Tjansk
>> OK!
> go.
> Dave
Really nice work :) I don't like to mess up my plugins.
Re: JBoss 4.0.3 definitions [message #137565 is a reply to message #120478] Thu, 08 September 2005 19:10 Go to previous messageGo to next message
Originally posted by: wolfgang.roeckelein.wiwi.uni-regensburg.de
Dave Dunkin wrote:
> Marko Mrvelj wrote:
>>> Tjansk
>> OK!
Unfortunatly this website seems to be gone.
does anybody have this file?
Wolfgang
Re: JBoss 4.0.3 definitions [message #137589 is a reply to message #137565] Fri, 09 September 2005 02:48 Go to previous messageGo to next message
Looks like you had temporary network problems. The site's up and
here's a direct link for you:
http://davedunkin.com/eclipse/org.jboss.ide.eclipse.serverde finitions_0.7.0.jar
- Nitin
Re: JBoss 4.0.3 definitions [message #137623 is a reply to message #137565] Fri, 09 September 2005 05:53 Go to previous messageGo to next message
Originally posted by: kuppai7.hotmail.com
Under which folder should we keep all these files
Re: JBoss 4.0.3 definitions [message #139922 is a reply to message #120478] Wed, 21 September 2005 09:12 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
--------------080502020500010202040203
Hi Dave,
I'm receiving a bunch of errors if I start my JBoss. See attached jboss log.
I use JBoss 4.0.2 with WTP 0.7.
I configured Eclipse to use JDK 1.4.2_09 (in
C:\Programme\Java\j2sdk1.4.2_09) and use it with the server declaration.
The JavaHome in my server declaration is also set to this path (it
complains if I use the JRE path).
On start the server tries to access files in
C:\Programme\Java\j2sdk1.4.2_09\lib which are found in
C:\Programme\Java\j2sdk1.4.2_09\jre\lib (e.g. ZoneInfoMappings).
What's wrong here ?
The server starts up and EJBs run fine. But when I try to invoke the
Hypersonic Database MAnager from the jmx-console this does not work (one
more ZoneInfo error in log).
Workaround is to copy the files from
C:\Programme\Java\j2sdk1.4.2_09\jre\lib to
C:\Programme\Java\j2sdk1.4.2_09\lib.
The file "jboss4.serverdef" contains some differences to some earlier
posts regarding JBoss 4 ("<classpath id="jboss">" element)
Best regards
Wolfgang
name="JBosslog.txt"
Content-Disposition: inline;
filename="JBosslog.txt"
ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:12:57,750 INFO [Server] Starting JBoss (MX MicroKernel)...
20:12:57,750 INFO [Server] Release ID: JBoss [Zion] 4.0.2 (build: CVSTag=JBoss_4_0_2 date=200505022023)
20:12:57,750 INFO [Server] Home Dir: C:\temp\jboss-4.0.2
20:12:57,750 INFO [Server] Home URL: file:/C:/temp/jboss-4.0.2/
20:12:57,750 INFO [Server] Library URL: file:/C:/temp/jboss-4.0.2/lib/
20:12:57,750 INFO [Server] Patch URL: null
20:12:57,765 INFO [Server] Server Name: default
20:12:57,765 INFO [Server] Server Home Dir: C:\temp\jboss-4.0.2\server\default
20:12:57,765 INFO [Server] Server Home URL: file:/C:/temp/jboss-4.0.2/server/default/
20:12:57,796 INFO [Server] Server Data Dir: C:\temp\jboss-4.0.2\server\default\data
20:12:57,796 INFO [Server] Server Temp Dir: C:\temp\jboss-4.0.2\server\default\tmp
20:12:57,796 INFO [Server] Server Config URL: file:/C:/temp/jboss-4.0.2/server/default/conf/
20:12:57,796 INFO [Server] Server Library URL: file:/C:/temp/jboss-4.0.2/server/default/lib/
20:12:57,796 INFO [Server] Root Deployment Filename: jboss-service.xml
20:12:57,796 INFO [Server] Starting General Purpose Architecture (GPA)...
20:12:58,171 INFO [ServerInfo] Java version: 1.4.2_09,Sun Microsystems Inc.
20:12:58,171 INFO [ServerInfo] Java VM: Java HotSpot(TM) Client VM 1.4.2_09-b05,Sun Microsystems Inc.
20:12:58,171 INFO [ServerInfo] OS-System: Windows XP 5.1,x86
20:12:58,875 INFO [Server] Core system initialized
20:13:01,406 INFO [Log4jService$URLWatchTimerTask] Configuring from URL: resource:log4j.xml
Warning: default mime table not found: C:\Programme\Java\j2sdk1.4.2_09\lib\content-types.properties
20:13:01,437 INFO [WebService] Using RMI server codebase: http://turbotante:8083/
20:13:01,609 INFO [NamingService] Started jndi bootstrap jnpPort=1099, rmiPort=1098, backlog=50, bindAddress=/0.0.0.0, Client SocketFactory=null, Server SocketFactory=org.jboss.net.sockets.DefaultSocketFactory@ad093076
20:13:06,390 INFO [Embedded] Catalina naming disabled
20:13:06,843 INFO [Http11Protocol] Initializing Coyote HTTP/1.1 on http-0.0.0.0-8080
20:13:06,843 INFO [Catalina] Initialization processed in 422 ms
20:13:06,843 INFO [StandardService] Starting service jboss.web
20:13:06,859 INFO [StandardEngine] Starting Servlet Engine: Apache Tomcat/5.5.9
20:13:06,875 INFO [StandardHost] XML validation disabled
20:13:06,906 INFO [Catalina] Server startup in 63 ms
20:13:07,015 INFO [TomcatDeployer] deploy, ctxPath=/invoker, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/http- invoker.sar/invoker.war/
20:13:07,156 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:07,281 INFO [WebappLoader] Dual registration of jndi stream handler: factory already defined
20:13:07,312 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:07,703 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:07,734 INFO [TomcatDeployer] deploy, ctxPath=/ws4ee, warUrl=file:/C:/temp/jboss-4.0.2/server/default/tmp/deploy/t mp51315jboss-ws4ee-exp.war/
20:13:07,843 INFO [TomcatDeployer] deploy, ctxPath=/, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss web-tomcat55.sar/ROOT.war/
20:13:08,031 INFO [TomcatDeployer] deploy, ctxPath=/jbossmq-httpil, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/jms/j bossmq-httpil.sar/jbossmq-httpil.war/
20:13:09,890 INFO [TomcatDeployer] deploy, ctxPath=/web-console, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/manag ement/console-mgr.sar/web-console.war/
20:13:10,453 INFO [MailService] Mail Service bound to java:/Mail
20:13:11,062 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss-ha-loc al-jdbc.rar
20:13:11,171 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss-ha-xa- jdbc.rar
20:13:11,265 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss-local- jdbc.rar
20:13:11,359 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss-xa-jdb c.rar
20:13:11,484 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jms/jms-ra.r ar
20:13:11,578 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/mail-ra.rar
20:13:12,171 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:12,875 INFO [WrapperDataSourceService] Bound connection factory for resource adapter for ConnectionManager 'jboss.jca:name=DefaultDS,service=DataSourceBinding to JNDI name 'java:DefaultDS'
20:13:13,125 INFO [A] Bound to JNDI name: queue/A
20:13:13,125 INFO [B] Bound to JNDI name: queue/B
20:13:13,125 INFO [C] Bound to JNDI name: queue/C
20:13:13,125 INFO [D] Bound to JNDI name: queue/D
20:13:13,125 INFO [ex] Bound to JNDI name: queue/ex
20:13:13,140 INFO [testTopic] Bound to JNDI name: topic/testTopic
20:13:13,140 INFO [securedTopic] Bound to JNDI name: topic/securedTopic
20:13:13,140 INFO [testDurableTopic] Bound to JNDI name: topic/testDurableTopic
20:13:13,140 INFO [testQueue] Bound to JNDI name: queue/testQueue
20:13:13,203 INFO [UILServerILService] JBossMQ UIL service available at : /0.0.0.0:8093
20:13:13,250 INFO [DLQ] Bound to JNDI name: queue/DLQ
20:13:13,406 INFO [ConnectionFactoryBindingService] Bound connection factory for resource adapter for ConnectionManager 'jboss.jca:name=JmsXA,service=ConnectionFactoryBinding to JNDI name 'java:JmsXA'
20:13:13,453 INFO [TomcatDeployer] deploy, ctxPath=/jmx-console, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/jmx-c onsole.war/
20:13:13,562 INFO [EARDeployer] Init J2EE application: file:/C:/temp/jboss-4.0.2/server/default/deploy/KuchenSingle .ear
20:13:13,578 WARN [MainDeployer] Found non-jar deployer for KuchenSingleEJB.jar: org.jboss.ejb.EJBDeployer@163956
20:13:13,765 INFO [EjbModule] Deploying KuchenSingle
20:13:14,531 INFO [EJBDeployer] Deployed: file:/C:/temp/jboss-4.0.2/server/default/tmp/deploy/tmp51361 KuchenSingle.ear-contents/KuchenSingleEJB.jar
20:13:14,562 INFO [EARDeployer] Started J2EE application: file:/C:/temp/jboss-4.0.2/server/default/deploy/KuchenSingle .ear
20:13:14,640 INFO [Http11Protocol] Starting Coyote HTTP/1.1 on http-0.0.0.0-8080
20:13:14,765 INFO [ChannelSocket] JK: ajp13 listening on /0.0.0.0:8009
20:13:14,765 INFO [JkMain] Jk running ID=0 time=0/15 config=null
20:13:14,781 INFO [Server] JBoss (MX MicroKernel) [4.0.2 (build: CVSTag=JBoss_4_0_2 date=200505022023)] Started in 16s:985ms
20:13:14,781 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:14,843 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
--------------080502020500010202040203--
Re: JBoss 4.0.3 definitions [message #143070 is a reply to message #139922] Tue, 11 October 2005 05:21 Go to previous message
--------------080009050400080702070602
Based on Dave's worked and what I found here in the group I modified the
serverdef plugin to work for me (Eclipse 3.1.1, WTP 1.0M8, JDK 1.4.2).
Maybe someone could take a look whether it makes sense.
See attached file.
Wolfgang
Content-Type: application/octet-stream;
name="org.jboss.ide.eclipse.serverdefinitions_0.7.0.jar"
Content-Disposition: attachment;
filename="org.jboss.ide.eclipse.serverdefinitions_0.7.0.jar "
UEsDBBQAAAAIAPlx7DLSJ2rFRAEAALAFAAAVAAAAYnVpbGRmaWxlcy9qYm9z czQueG1sxZRN
bsMgEIXXRModEOoqC5C6JrkLjictCBsLYydtlbsX/G/LIXWlqqwMvJk384kx L6xRcHY4Fxkc
SQqFNh9wc5CX0uQE4xQuotKuv6LqFYBeIfFXiSghlfZIKDntd9gv7oR9g3my MaITNUIlrE9d
uovUXvnylZm00kBD4J1ehSUnPF38UxZBWvrkjeUQ4Xf3aeYhQuZnXaXQ1XI4 sANhazq4LXWN
/1LL2VjCtBHmO5lKeWZqwA/bws509Zdga7C0qBIty/e2j96UsxZkt30GF9QG uOqf4aq/gat+
AxdFmAZMXoHiNBsZDjr0HCPq+0ArAGmLsNf4fKvwatHK/P0cWjjocfnvx6Tg R6TQ4g3OSVV5
bLhT0OBG9xULtjrxnLWR61MQq2A5AdsrUNEKcBhCFK1geC/bvWHpPcJH+x1n 3T86vLNvUEsD
BAoAAAAAAESmSjMAAAAAAAAAAAAAAAALAAAAYnVpbGRmaWxlcy9QSwMECgAA AAAARKZKMwAA
AAAAAAAAAAAAAAwAAABpY29ucy9vYmoxNi9QSwMEFAAAAAgA+XHsMgggH64R AQAAPAEAABUA
AABpY29ucy9vYmoxNi9qYm9zcy5naWZz93SzsEwUYBBguMrA8Pvbn1tXXiXl rJm/5jqD3bR3
3/8zBM8Mm3miYc89hyVnVt14ffnVl8mXnlx58zl8qdSs01l9hwJefLr9/fen y08W/Xm9/ve7
Q/9P+P3fqf5nPsOvc+3/JjP8OFT559OT7xvTfnx6/WWS0ede7S95DJ/cGd7p q7zPz/jU1vBY
gOuJnOS7lvpHDAzfTpz4cuL4////GcgFij9ZGBkYdIAQCEB+YmCLdJhW4KEj 1e/xMFFQQEWa
R4yRUUJFuC1l4wKJPrc178M1Gn06HptYPKpYcDDJIEh2WrTe+13zWi9yHK1v cBIVkVOQ1tHS
iJJVUtRR01TxlJGX1FHXVI1y0Z4zx5HBGgBQSwMECgAAAAAARKZKMwAAAAAA AAAAAAAAAAYA
AABpY29ucy9QSwMEFAAAAAgA+XHsMhLZ5rq7AAAAWwEAABQAAABNRVRBLUlO Ri9NQU5JRkVT
VC5NRo2QsQrCQBBE+4D/kMbOHNFGUGys1ULBPl7GsHLZ0907Qb/emJiIneXy hpnZ2RZMZ2jI
jhAlz4t0avJkHbl0yLYfOLBZT3ZFjUU6vrpYEb+PHhwe9ck7sp3AS2UuJ69q qISBdXRVGIXc
ISXOxBQaX12mSlw5hCZjFSQObkNwbubfWhtvC0fPIrSo65DscYskyDpNF90H Wi8wEjlQjcko
+WEXDZ9CpgJDyLbyP2SRvjW59PLeQ/y9+VTaRV5QSwMECgAAAAAARKZKMwAA AAAAAAAAAAAA
AAkAAABNRVRBLUlORi9QSwMEFAAAAAgAhKpKM3v23EzGAwAATREAABgAAABz ZXJ2ZXJzL2pi
b3NzNC5zZXJ2ZXJkZWblWF9v2zYQf3aBfgdB6B5N2l6GBYGlImswDEMLBE0H 9KEvtHS26VKk
QFK2gyLffSdSkmVFTmxjS4HWT9T9/d0d747J9O02E8EatOFKRuGYjMIAZKJS LhdR+M+nP4eX
4dv49auplebqDjRKfiyk5Rm8fhXgD7WRgcwoXFqbX1EKieC5AaL0gq6MpcYp 0QVI0Dyh3san
+xxuYM4lt+g3bNvaGt7Y2mw2ZPOrMzUZjcb084f3d8kSMjbk0lgmE6hVDb8y jvNeJcy6WM7H
E/QRvWOyNWlQOZUsgyj8+w9lTHBBRmQb7hK59oQyc7lWOWh7H/A0Cr33j0rZ G64hsUrfo7WB
YDMQUfjLdZ4L7gPwGNpSpU+LmKIw7VATJS1sbRRqX5uKnMKcFQLJqxliHFYY 6QFQ12mqwZg2
nC5jh8BYjTek697Ld72PJ7+j5xEZ9/nOlbaPXd566nn+LkeXo8NhvlNyzmtL tVeXoIsegdO9
V4c+AIlgxtwyu3wccJv1H9bZ86dlkmN/dt9SxW++lcSHKcVzm4N3Ov4LOwcZ 5bHFwlCsSpSI
l47dfFY+aOWk+sxUWog9/TKkeDUBIBuYTan7bJsvZoKbJV54xNbTJg9159Zc X6cHmkIu1D36
3xl4bBaNwRw0jjaIcRKQeirgRCDeHKkmAmHSNkqN1bZ+HfBeiE8GDKufLWCm f6CA8Vze67qZ
tFoh4DYE1705du/OhGtFUslOaY9E0zd79ioqbrf9ls0Yl+9KIy44b/0D0hBk w2mJb5T+iiOr
ye2hjM9KC4+E97t+oVl2rRdFBtKaeJgEnfq4EPaFWgbW2S1DHlhcjfHwphIl bnnWNYItBMPP
mRlPLrPysP1tPMHDzYqtGQGZKm0gJTgNTdQfxxfBZ19qwSnd83lEnZ6sT12K pjIqf64wd8vC
pmrzHYpzd0IxTs8TMU1gTyasydCuOd0CPKEvw94WT5llLYZjljS3q2YFFymZ cwFT2hB7hNdM
FBBTJ15KG+rXP8EHqNf0Ei0A9BCCI6HhFVqAJZUw2W3B53H64ddReRGAbmud BrBReRmA5ZY5
EWCt8hzAinwuzkKeU+tCvmi1OyCPrPc+yP+94l2Qx9W8A/LEqte/eqI1QnGz Bpr55wabGyDl
yBoMpkwnS76GoGRG4ZtvzdP+4PsGn/XzkD6rjeuA4sOfrJj2r/uznOGmpEIt LlbOjjPTmuYu
wEFfdM3sD4OjkNbiLbj7fgaHHFUPoiP84CrBDefHNxNi6L9PTFD115NLTPng 2Lq1JMAeRI5P
2+5/Q1ze/gVQSwMECgAAAAAARKZKMwAAAAAAAAAAAAAAAAgAAABzZXJ2ZXJz L1BLAwQUAAAA
CABdqkoznBKL9gkBAAAXAgAAEQAAAHBsdWdpbi5wcm9wZXJ0aWVzfZCxasMw EIb3QN7hJtMu
TodMAQ1uUgodiqGluyKfnQuyJE5ySN6+kuW6DpQu5qz7/u90cnroyLzLHgW8 okEmBR75ggx4
lb3TCA22ZCiQNX69cmwv1CCPiRelyXksLXexM5oO6BWTS7SoM+tn0ySehNEH rWUIJ4TufnSw
VpOJ0vXqfLTeb3kwgXr8vDkcJ789x1PYlk/l9Q9keQlYoDAxP5E87T/pL7F0 LpWZuOf31rTU
iY+8zN4W6XdgmcLw0Mfle6k38RnkoMNGav24S6tWzmlSI5WjB2JUwfJNLFpQ TN65G8N5btU0
jN6LqsjF3KgtB1Gk73yktPS+luEkin0qXSzhSzLJo8bdN1BLAwQUAAAACABB qEozI253GKcC
AAAWCwAACgAAAHBsdWdpbi54bWzNVslu2zAQPadA/4El0Fss2YlT9CDZQFyk TYH0kDjomZbG
Mg2JFEgqSfv1JSlZpGS3XpJDeTDkWR5neTNSNH0pcvQEQlLOYjwKhhgBS3hK WRbjx/nN4DOe
Tt6/i6aQ5LSU4Gwvta1VlXmVUaafEEIRvChgxgCVnDIVYy6yoPENnqUKJAgN ESRcQCAqpmgB
818lSKwBLASKPHEt0YemXai1g8qAgaDJBi1YL7iUY9y6MlJAjD/WYg/7h5Y7 qxRkImipbG7b
xl+c2vk8AUu5iPH3a23ti5sSDZ0syYmUe1OwVdFlA8FIHnytpQ/W5r6OxSFO 2qeo4GmVd+uF
kDJVjfH6AnThYYE9VROgNA2/OEej4NL8jHHYYu6HhPXbQxJxDGQUev2xMsug KGw5aCl1HCXr
55aRdeRO6IWHUHN9jJWoAHdUr253F+4A9vdZb90YVZTkD4ooHaVUvCwh7ZrI qiy5UPIeCq7g
G5dKh70kuewl5JX69vRRNGfXoLkC75wzc3JSsWQ142xJswMisKX1fSpBDKi5 owu8gBV5orwS
s9f27HqD1L2gs39cpt31Y45URKi5rhuvNEuvhvpog7NWy8tWObqqlZ73ishO pjvbWFfkjqdm
6HSXzlNYVBme+EYb1ocu1lavw+nOl7U8dMIq2jzdFiTzB4ya/14MB/DduvjJ 0cTkbH5lyBfr
0afQVjzI6NI3U5bB+/vco3D4P8fqxdhrT/RhMECPt2jGi5IzYEoOBltda2/c 271n+puI9EaQ
rDBYHm+iZSN04R/+yvZyPrE9DuCwzatz+edr9mcnUV1Z5M6GCCdlLPvb/cge v1miuzI04MeO
999WZC1LYWlfQnqbG3KeRX3xCR92yHkvaa5Xa7OoZD1EY3d1c2fYv3Synage lbD9kP0DUEsB
AhQAFAAAAAgA+XHsMtInasVEAQAAsAUAABUAAAAAAAAAAQAgAAAAAAAAAGJ1 aWxkZmlsZXMv
amJvc3M0LnhtbFBLAQIUAAoAAAAAAESmSjMAAAAAAAAAAAAAAAALAAAAAAAA AAAAEAAAAHcB
AABidWlsZGZpbGVzL1BLAQIUAAoAAAAAAESmSjMAAAAAAAAAAAAAAAAMAAAA AAAAAAAAEAAA
AKABAABpY29ucy9vYmoxNi9QSwECFAAUAAAACAD5cewyCCAfrhEBAAA8AQAA FQAAAAAAAAAA
ACAAAADKAQAAaWNvbnMvb2JqMTYvamJvc3MuZ2lmUEsBAhQACgAAAAAARKZK MwAAAAAAAAAA
AAAAAAYAAAAAAAAAAAAQAAAADgMAAGljb25zL1BLAQIUABQAAAAIAPlx7DIS 2ea6uwAAAFsB
AAAUAAAAAAAAAAEAIAAAADIDAABNRVRBLUlORi9NQU5JRkVTVC5NRlBLAQIU AAoAAAAAAESm
SjMAAAAAAAAAAAAAAAAJAAAAAAAAAAAAEAAAAB8EAABNRVRBLUlORi9QSwEC FAAUAAAACACE
qkoze/bcTMYDAABNEQAAGAAAAAAAAAABACAAAABGBAAAc2VydmVycy9qYm9z czQuc2VydmVy
ZGVmUEsBAhQACgAAAAAARKZKMwAAAAAAAAAAAAAAAAgAAAAAAAAAAAAQAAAA QggAAHNlcnZl
cnMvUEsBAhQAFAAAAAgAXapKM5wSi/YJAQAAFwIAABEAAAAAAAAAAQAgAAAA aAgAAHBsdWdp
bi5wcm9wZXJ0aWVzUEsBAhQAFAAAAAgAQahKMyNudxinAgAAFgsAAAoAAAAA AAAAAQAgAAAA
oAkAAHBsdWdpbi54bWxQSwUGAAAAAAsACwCZAgAAbwwAAAAA
--------------080009050400080702070602--
Previous Topic:EJB - Connection to a database
Next Topic:Tomcat failed to start
Current Time: Mon Oct 13 21:32:56 EDT 2025
Powered by FUDForum. Page generated in 0.06357 seconds
