| P2 Automatic Updates - problem with org.eclipse.equinox.p2.metadata.repository? [message #119268] |
Fri, 10 October 2008 12:19  |
I am working with a P2 enabled RCP app with the "Automatically find new
updates and notify me" + "Look for updates each time platform is started"
preferences selected.
On start up of the app these actions are not taking place. However, if I
go to the Help -> Software Updates... Available Software tab and do a
Refresh, the updates are being found and install properly so there is
nothing wrong with the update site or the connectivity.
Carefully watching netstat on startup of the RCP app reveals that no
communication with the update site server is taking place on startup.
I've noticed that if I go to the
p2\org.eclipse.equinox.p2.metadata.repository\cache there is a file named
content-1974464048.xml. If I delete this file, the selected preferences
do trigger and work on subsequent start up of the RCP app.
The timestamp and contents within file content-1974464048.xml do get
updated when I install updates using the refresh option described above.
However, the file name never changes. Shouldn't an entirely new file be
created with a new name?
No errors in the log of my RCP app.
I've build this RCP app with Ganymede 3.4.1
The plugins in my bundle pool are as follows...
javax.servlet.jsp_2.0.0.v200806031607.jar
javax.servlet_2.4.0.v200806031604.jar
org.apache.ant_1.7.0.v200803061910
org.apache.commons.el_1.0.0.v200806031608.jar
org.apache.commons.logging_1.0.4.v20080605-1930.jar
org.apache.jasper_5.5.17.v200806031609.jar
org.apache.lucene.analysis_1.9.1.v20080530-1600.jar
org.apache.lucene_1.9.1.v20080530-1600.jar
org.eclipse.ant.core_3.2.0.v20080529.jar
org.eclipse.core.commands_3.4.0.I20080509-2000.jar
org.eclipse.core.contenttype_3.3.0.v20080604-1400.jar
org.eclipse.core.databinding_1.1.1.M20080827-0800b.jar
org.eclipse.core.expressions_3.4.0.v20080603-2000.jar
org.eclipse.core.filesystem.win32.x86_1.1.0.v20080604-1400.j ar
org.eclipse.core.filesystem_1.2.0.v20080604-1400.jar
org.eclipse.core.jobs_3.4.0.v20080512.jar
org.eclipse.core.net.win32.x86_1.0.0.I20080521.jar
org.eclipse.core.net_1.1.0.I20080604.jar
org.eclipse.core.resources.compatibility_3.4.0.v20080604-140 0.jar
org.eclipse.core.resources.win32.x86_3.4.0.v20071204.jar
org.eclipse.core.resources_3.4.1.R34x_v20080902.jar
org.eclipse.core.runtime.compatibility.auth_3.2.100.v2007050 2.jar
org.eclipse.core.runtime.compatibility.registry_3.2.200.v200 80610
org.eclipse.core.runtime.compatibility_3.2.0.v20071008.jar
org.eclipse.core.runtime_3.4.0.v20080512.jar
org.eclipse.core.variables_3.2.100.v20080529-1300.jar
org.eclipse.debug.core_3.4.0.v20080612.jar
org.eclipse.ecf.filetransfer_2.0.0.v20080611-1715.jar
org.eclipse.ecf.identity_2.0.0.v20080611-1715.jar
org.eclipse.ecf.provider.filetransfer_2.0.0.v20080611-1715.j ar
org.eclipse.ecf_2.0.0.v20080611-1715.jar
org.eclipse.emf.codegen_2.4.0.v200808251517.jar
org.eclipse.emf.common.ui_2.4.0.v200808251517.jar
org.eclipse.emf.common_2.4.0.v200808251517.jar
org.eclipse.emf.ecore.change_2.4.0.v200808251517.jar
org.eclipse.emf.ecore.xmi_2.4.1.v200808251517.jar
org.eclipse.emf.ecore_2.4.1.v200808251517.jar
org.eclipse.emf.edit.ui_2.4.1.v200808251517.jar
org.eclipse.emf.edit_2.4.1.v200808251517.jar
org.eclipse.emf_2.4.0.v200808251517.jar
org.eclipse.equinox.app_1.1.0.v20080421-2006.jar
org.eclipse.equinox.common_3.4.0.v20080421-2006.jar
org.eclipse.equinox.frameworkadmin.equinox_1.0.2.R34x_v20080 911.jar
org.eclipse.equinox.frameworkadmin_1.0.2.R34x_v20080910.jar
org.eclipse.equinox.http.jetty_1.1.0.v20080425.jar
org.eclipse.equinox.http.registry_1.0.100.v20080427-0830.jar
org.eclipse.equinox.http.servlet_1.0.100.v20080427-0830.jar
org.eclipse.equinox.jsp.jasper.registry_1.0.0.v20080427-0830 .jar
org.eclipse.equinox.jsp.jasper_1.0.100.v20080427-0830.jar
org.eclipse.equinox.launcher.win32.win32.x86_1.0.101.R34x_v2 0080731
org.eclipse.equinox.launcher_1.0.101.R34x_v20080819.jar
org.eclipse.equinox.p2.artifact.repository_1.0.2.R34x_v20080 808-1156.jar
org.eclipse.equinox.p2.console_1.0.0.v20080514-1900.jar
org.eclipse.equinox.p2.core_1.0.0.v20080530-1237.jar
org.eclipse.equinox.p2.director.app_1.0.1.R34x_v20080729.jar
org.eclipse.equinox.p2.directorywatcher_1.0.2.v20080806-1619 .jar
org.eclipse.equinox.p2.director_1.0.0.v20080604.jar
org.eclipse.equinox.p2.engine_1.0.1.R34x_v20080827.jar
org.eclipse.equinox.p2.exemplarysetup_1.0.0.v20080427-2136.j ar
org.eclipse.equinox.p2.extensionlocation_1.0.2.R34x_v2008082 5.jar
org.eclipse.equinox.p2.garbagecollector_1.0.1.R34x_v20080818 .jar
org.eclipse.equinox.p2.jarprocessor_1.0.0.v20080514-1900.jar
org.eclipse.equinox.p2.metadata.generator_1.0.1.R34x_v200808 19.jar
org.eclipse.equinox.p2.metadata.repository_1.0.0.v20080604.j ar
org.eclipse.equinox.p2.metadata_1.0.0.v20080514-1900.jar
org.eclipse.equinox.p2.reconciler.dropins_1.0.2.R34x_v200809 09.jar
org.eclipse.equinox.p2.touchpoint.eclipse_1.0.2.R34x_v200809 10.jar
org.eclipse.equinox.p2.touchpoint.natives_1.0.0.v20080505-18 50.jar
org.eclipse.equinox.p2.ui.admin.rcp_1.0.0.v20080604.jar
org.eclipse.equinox.p2.ui.admin_1.0.0.v20080522-1735.jar
org.eclipse.equinox.p2.ui.sdk_1.0.1.R34x_v20080818.jar
org.eclipse.equinox.p2.ui_1.0.1.R34x_v20080909.jar
org.eclipse.equinox.p2.updatechecker_1.0.0.v20080427-2136.ja r
org.eclipse.equinox.p2.updatesite_1.0.1.R34x_v20080808-1156. jar
org.eclipse.equinox.preferences_3.2.201.R34x_v20080709.jar
org.eclipse.equinox.registry_3.4.0.v20080516-0950.jar
org.eclipse.equinox.security.ui_1.0.0.v20080603-1810.jar
org.eclipse.equinox.security.win32.x86_1.0.0.v20080529-1600. jar
org.eclipse.equinox.security_1.0.1.R34x_v20080721.jar
org.eclipse.equinox.simpleconfigurator.manipulator_1.0.2.R34 x_v20080911.jar
org.eclipse.equinox.simpleconfigurator_1.0.0.v20080604.jar
org.eclipse.help.appserver_3.1.300.v20080507.jar
org.eclipse.help.base_3.3.101.M20080728_34x.jar
org.eclipse.help.ui_3.3.101.M20080715_34x.jar
org.eclipse.help.webapp_3.3.101.M20080805_34x.jar
org.eclipse.help_3.3.101.v20080702_34x.jar
org.eclipse.jdt.compiler.apt_1.0.100.v20080513-1235.jar
org.eclipse.jdt.compiler.tool_1.0.100.v_883_R34x.jar
org.eclipse.jdt.core_3.4.2.v_883_R34x.jar
org.eclipse.jdt.debug_3.4.0.v20080604
org.eclipse.jdt.launching_3.4.1.v20080729_r341.jar
org.eclipse.jface.databinding_1.2.1.M20080827-0800a.jar
org.eclipse.jface.text_3.4.1.r341_v20080827-1100.jar
org.eclipse.jface_3.4.1.M20080827-2000.jar
org.eclipse.osgi.services_3.1.200.v20071203.jar
org.eclipse.osgi_3.4.2.R34x_v20080826-1230.jar
org.eclipse.pde.runtime_3.4.0.v20080723-1000.jar
org.eclipse.swt.win32.win32.x86_3.4.1.v3449c.jar
org.eclipse.swt_3.4.1.v3449c.jar
org.eclipse.text_3.4.0.v20080605-1800.jar
org.eclipse.ui.forms_3.3.101.v20080708_34x.jar
org.eclipse.ui.ide_3.4.1.M20080903-2000.jar
org.eclipse.ui.navigator.resources_3.3.101.M20080910-0800.ja r
org.eclipse.ui.navigator_3.3.101.M20080827-0800.jar
org.eclipse.ui.net_1.0.0.I20080605.jar
org.eclipse.ui.views.log_1.0.0.v20080803-1700.jar
org.eclipse.ui.views.properties.tabbed_3.4.1.M20080730-0800. jar
org.eclipse.ui.views_3.3.0.I20080509-2000.jar
org.eclipse.ui.win32_3.2.100.v20080408-0800.jar
org.eclipse.ui.workbench.texteditor_3.4.1.r341_v20080827-110 0.jar
org.eclipse.ui.workbench_3.4.1.M20080827-0800a.jar
org.eclipse.ui_3.4.1.M20080910-0800.jar
org.eclipse.update.configurator_3.2.201.R34x_v20080819.jar
org.mortbay.jetty_5.1.14.v200806031611.jar
org.sat4j.core_2.0.0.v20080602.jar
org.sat4j.pb_2.0.0.v20080602.jar
| Re: P2 Automatic Updates - temp solution [message #119498 is a reply to message #119335] |
Mon, 13 October 2008 18:29  |
This is a temporary hack I but in my RCP application's Activator which is
solving my Automatic Updates problem. It's also solving a problem with my
P2 repository growing quite large due to caching of launcher executables in
/p2/org.eclipse.equinox.p2.core/cache
* This is a hack to remove P2 caches. Needed to ensure that
* Automatic Updates will recognize new content on the update site.
* May be able to remove this after P2 infrastructure hardens.
* A complete description may be found at
* http://www.eclipse.org/newsportal/article.php?id=5309&
* group=eclipse.technology.equinox#5309
* TODO: Revisit
private void delP2Caches() {
File p2Dir = null;
IPath p2Path =
ResourcesPlugin.getWorkspace().getRoot().getLocation()
.append("../p2/org.eclipse.equinox.p2.metadata.repository/cache ");
p2Dir = p2Path.toFile();
if (p2Dir.exists()) {
Activator.deleteDirs(p2Dir);
p2Path = ResourcesPlugin.getWorkspace().getRoot().getLocation()
.append("../p2/org.eclipse.equinox.p2.core/cache");
private static void deleteDirs(File directory) {
if (directory.isDirectory()) {
String[] subdirs = directory.list();
for (int i=0; i < subdirs.length; i++) {
File f = new File(directory, subdirs[i]);
Activator.deleteDirs(f);
f.delete();
Logger.log(Activator.PLUGIN_ID, "deleteDirs",
"Deleting " + f, null, IStatus.INFO);//$NON-NLS-1$
FUDForum. Page generated in 0.03233 seconds
