Home » Language IDEs » ServerTools (WTP) » EJB Creation - Way to remove the client jar from being created?
EJB Creation - Way to remove the client jar from being created? [message #119259] Mon, 11 July 2005 06:36 Go to next message
Is there anyway to stop WTP from generating an client module? This breaks
deployment to Geronimo as it does not understand that the ejb-client-jar
should be used, unless it is part of an EAR File. Since EAR Files are not
recognised at present, it means you cannot deploy via Eclipse nor the
command line a generated EJB jar file.
Also any ideas on when EAR Modules will be recognised within a server?
Re: EJB Creation - Way to remove the client jar from being created? [message #119271 is a reply to message #119259] Mon, 11 July 2005 06:55 Go to previous message
Scrap what I said, Found an option set by default and have progressed a
little further.
"Nicholas Irving" <nirving@darkedges.com> wrote in message
news:dati35$god$1@news.eclipse.org...
Previous Topic:Problems starting and deploying to WLS 8.1
Next Topic:How should I structure my code for webtools?
Current Time: Sat Nov 08 22:35:29 EST 2025
Powered by FUDForum. Page generated in 0.04538 seconds
