Home » Eclipse Projects » Eclipse Platform » Problem to access Help from Eclipse
Problem to access Help from Eclipse [message #119225] Fri, 29 August 2003 07:56 Go to next message
I am trying to access Eclipse 2.1 Help --> Help Contents.
However nothing happens when I try it.
Have I missed some settings???
All help is greatly appreciated.
//Mikael
Re: Problem to access Help from Eclipse [message #119289 is a reply to message #119225] Fri, 29 August 2003 13:05 Go to previous messageGo to next message
Originally posted by: dorian.birsan.net
Take a look at the eclipse readme, there is a section on troubleshooting
help. You may need to set the proxy bypass or disabled automatic detection.
-Dorian
"Mikael Petterson" <mikael.petterson@ericsson.com> wrote in message
news:binf2a$hl2$1@eclipse.org...
> //Mikael
Re: Problem to access Help from Eclipse [message #119325 is a reply to message #119225] Fri, 29 August 2003 13:09 Go to previous message
I got a similar problem some time ago. Something was messed up by a
project while accessing CVS.
Close Eclipse, delete .metadata from eclipse/workspace/, restart Eclipse
(unless you want to reinstall Eclipse).
You have to import your projects in the workspace after this.
It worked for me.
Emil
Mikael Petterson wrote:
> //Mikael
Previous Topic:Format code function
Next Topic:Adding actions to JDT CompilationUnit editor context menu
Current Time: Fri Nov 07 16:10:47 EST 2025
Powered by FUDForum. Page generated in 0.04045 seconds
