| [Teneo] Still newbie questions [message #119171] |
Sat, 19 April 2008 08:04  |
Originally posted by: tom.eiswind.de
Hi I try to get started, but I dont get it. Maybe someone can give me a
pointer. I have a simple model
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="mango"
nsURI="http://mango.ecorediag/1.0" nsPrefix="mango">
<eClassifiers xsi:type="ecore:EClass" name="ValueList"
eSuperTypes="#//BaseEntity">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference"
name="defaultValue" eType="#//Value"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="values"
upperBound="-1"
eType="#//Value"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BaseEntity">
<eAnnotations source="teneo.jpa">
<details key="appinfo" value="@MappedSuperclass"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="text"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Value"
</eClassifiers>
</ecore:EPackage>
but it seems to ignore the MappedSuperclass annotation as it generates
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD
3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping auto-import="false">
<class name="mango.impl.BaseEntityImpl" entity-name="BaseEntity"
abstract="false" lazy="false" discriminator-value="BaseEntity"
table="`baseentity`">
<meta attribute="eclassName">BaseEntity</meta>
<meta attribute="epackage">http://mango.ecorediag/1.0</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="text" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`text`"/>
</property>
</class>
<subclass name="mango.impl.ValueListImpl" entity-name="ValueList"
abstract="false" lazy="false" extends="BaseEntity"
discriminator-value="ValueList">
<meta attribute="eclassName">ValueList</meta>
<property name="name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`name`"/>
</property>
<many-to-one name="defaultValue" entity-name="Value"
foreign-key="valuelist_defaultvalue" lazy="false" insert="true"
update="true" not-null="false">
name="`value_defaultvalue_e_id`"/>
</many-to-one>
<list name="values" table="`valuelist_values`" lazy="true">
<key update="true">
<column name="`valuelist_e_id`" not-null="true" unique="false"/>
</key>
<list-index column="`valuelist_values_idx`"/>
<many-to-many entity-name="Value" unique="true"
foreign-key="valuelist_values">
<column name="`value_e_id`" not-null="true" unique="false"/>
</many-to-many>
</list>
</subclass>
<class name="mango.impl.ValueImpl" entity-name="Value" abstract="false"
lazy="false" discriminator-value="Value" table="`value`">
<meta attribute="eclassName">Value</meta>
</id>
</version>
</property>
</class>
</hibernate-mapping>
| Re: [Teneo] Still newbie questions [message #119272 is a reply to message #119208] |
Sun, 20 April 2008 01:22  |
Hi Thomas,
teneo.jpa should also work. Did you regenerate the java model code after setting the annotation?
gr. Martin
Thomas wrote:
> I see I had to use teneo.hibernate instead of teneo.jpa
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] Still newbie questions [message #617855 is a reply to message #119208] |
Hi Thomas,
gr. Martin
The Netherlands
FUDForum. Page generated in 0.04599 seconds
