Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Merging UML models
Merging UML models [message #119142] |
Sat, 19 April 2008 05:07  |
Good day,
I'm trying to modify the standalone example by Cedric Brun (ExampleLauncher.java) to merge two UML models. I've managed to get
it to output the result.emfdiff difference file (while ignoring XMI IDs). When I try to merge, I get a
java.lang.NullPointerException at MergeService.merge(diff.getOwnedElements(), true); (see details below). Any ideas?
Sam
Here's the error:
Exception in thread "main" java.lang.NullPointerException
at org.eclipse.emf.compare.diff.merge.service.MergeFactory.getB estMerger(MergeFactory.java:109)
at org.eclipse.emf.compare.diff.merge.service.MergeFactory.crea teMerger(MergeFactory.java:79)
at org.eclipse.emf.compare.diff.merge.service.MergeService.doMe rge(MergeService.java:143)
at org.eclipse.emf.compare.diff.merge.service.MergeService.merg e(MergeService.java:109)
at org.eclipse.emf.compare.examples.standalone.ExampleLauncher. main(ExampleLauncher.java:77)
Here's the essential code:
if (args.length == 2 && new File(args[0]).canRead() && new File(args[1]).canRead()) {
// Creates the resourceSet where we'll load the models
final ResourceSet resourceSet = new ResourceSetImpl();
UMLPackage umlPackage = UMLPackage.eINSTANCE;
resourceSet.getPackageRegistry().put(umlPackage.getNsURI(), umlPackage);
try {
// Loads the two models passed as arguments
final EObject model1 = ModelUtils.load(new File(args[0]), resourceSet);
final EObject model2 = ModelUtils.load(new File(args[1]), resourceSet);
Map<String,Object> options = new HashMap<String,Object>();
options.put(MatchOptions.OPTION_IGNORE_XMI_ID, true);
// Creates the match then the diff model for those two models
final MatchModel match = MatchService.doMatch(model1, model2, options);
final DiffModel diff = DiffService.doDiff(match, false);
MergeService.merge(diff.getOwnedElements(), true); // line 77: java.lang.NullPointerException
// Prints the results
try {
System.out.println(ModelUtils.serialize(match));
System.out.println(ModelUtils.serialize(diff));
} catch (IOException e) {
e.printStackTrace();
// Serializes the result as "result.emfdiff" in the directory this class has been called from.
System.out.println("saving emfdiff as \"result.emfdiff\""); //$NON-NLS-1$
final ModelInputSnapshot snapshot = DiffFactory.eINSTANCE.createModelInputSnapshot();
snapshot.setDate(Calendar.getInstance().getTime());
snapshot.setMatch(match);
snapshot.setDiff(diff);
ModelUtils.save(snapshot, "result.emfdiff"); //$NON-NLS-1$
// shouldn't be thrown
} catch (InterruptedException e) {
Re: Merging UML models [message #119414 is a reply to message #119338] |
Mon, 21 April 2008 15:28   |
Laurent,
Thanks for the reply.
I've updated to the latest build and I got the same error with different
line numbers. Please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=228087
Sam
laurent Goubet wrote:
> Sam,
> I wonder... Are you using EMF Compare's latest build or the code from
> CVS? We fixed some problems within the merging API and some of the
> lines from your stack no longer match with code lines so this issue
> could already be fixed.
> Could you update to the latest version of EMF Compare (we have a new
> build ready if you use the built version) and check if the problem still
> happens?
> If the exception is still thrown, could you provide us the models you
> compare (either through bugzilla (preferred) or mail)? This is a
> potential problem of the generic differencing engine and we'd need to
> confirm it.
> Laurent Goubet
> Obeo
> Sam Sabra a écrit :
>> Good day,
>> (ExampleLauncher.java) to merge two UML models. I've managed to get it
>> When I try to merge, I get a java.lang.NullPointerException at
>> below). Any ideas?
>> Thanks,
>> Sam
>> Here's the error:
>> at
>> at
>> at
>> at
>> at
>> try {
>> models
>> model2, options);
>> try {
>> //$NON-NLS-1$
Re: Merging UML models [message #119638 is a reply to message #119478] |
Tue, 22 April 2008 22:47   |
Laurent,
Thank you for handling this quickly, excellent response time! Looking
forward to the next integration build.
Sam
> Sam,
> Thanks for the feedback, this was indeed a bug on our side. This has
> been fixed on CVS and will be included in the next integration build.
> Laurent Goubet
> Obeo
> Sam Sabra a écrit :
>> Laurent,
>> different line numbers. Please see
>> Regards,
>> Sam
>>> Sam,
>>> still happens?
>>> confirm it.
>>> Laurent Goubet
>>> Obeo
>>> Sam Sabra a écrit :
>>>> Good day,
>>>> IDs). When I try to merge, I get a java.lang.NullPointerException at
>>>> below). Any ideas?
>>>> Thanks,
>>>> Sam
>>>> Here's the error:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> umlPackage);
>>>> try {
>>>> two models
>>>> false);
>>>> try {
>>>> //$NON-NLS-1$
Re: Merging UML models [message #119844 is a reply to message #119638] |
Thu, 24 April 2008 05:38   |
Hi Sam,
The new build is available here :
http://www.eclipse.org/modeling/emft/downloads/?project=comp are
regards,
Cédric
Sam Sabra wrote:
> Laurent,
> Best regards,
> Sam
>> Sam,
>> Laurent Goubet
>> Obeo
>> Sam Sabra a écrit :
>>> Laurent,
>>> Regards,
>>> Sam
>>>> Sam,
>>>> still happens?
>>>> confirm it.
>>>> Laurent Goubet
>>>> Obeo
>>>> Sam Sabra a écrit :
>>>>> Good day,
>>>>> below). Any ideas?
>>>>> Thanks,
>>>>> Sam
>>>>> Here's the error:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> umlPackage);
>>>>> try {
>>>>> two models
>>>>> false);
>>>>> try {
>>>>> //$NON-NLS-1$
Re: Merging UML models [message #122682 is a reply to message #119844] |
Mon, 19 May 2008 12:38   |
Hi Sam, Cedric,
I was having the same problem, and got the latest from the EMFT site. I
now have a new error, a ConcurrentModificationException which is a bit of
a mystery as there is nothing concurrent in what I am doing? The error is
below, I am working with EMF Compare 0.8.0v20080506. Any ideas?
Mark
java.util.ConcurrentModificationException
org.eclipse.emf.common.util.BasicEList$EIterator.checkModCou nt(BasicEList.java:1378)
org.eclipse.emf.common.util.BasicEList$EIterator.doNext(Basi cEList.java:1332)
org.eclipse.emf.common.util.BasicEList$EIterator.next(BasicE List.java:1312)
org.eclipse.emf.compare.diff.merge.service.MergeService.merg e(MergeService.java:132)
at test.Test.main(Test.java:39)
Cédric Brun wrote:
> Hi Sam,
> regards,
> Cédric
> Sam Sabra wrote:
>> Laurent,
>> Best regards,
>> Sam
>>> Sam,
>>> Laurent Goubet
>>> Obeo
>>> Sam Sabra a écrit :
>>>> Laurent,
>>>> Regards,
>>>> Sam
>>>>> Sam,
>>>>> still happens?
>>>>> confirm it.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>> Sam Sabra a écrit :
>>>>>> Good day,
>>>>>> below). Any ideas?
>>>>>> Thanks,
>>>>>> Sam
>>>>>> Here's the error:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> umlPackage);
>>>>>> try {
>>>>>> two models
>>>>>> false);
>>>>>> try {
>>>>>> "result.emfdiff""); //$NON-NLS-1$
>>>>>> //$NON-NLS-1$
Re: Merging UML models [message #122697 is a reply to message #122692] |
Tue, 20 May 2008 07:09   |
Hi Laurent,
Ok - I think I am nearly there - and thanks again for all your help. I
have the code running ok (well appears to be), but the models do not
change - there is no merge of one model into another (am I missing
something)?
I have pasted the code below and I think it should work as when i iterate
the diffElements I get:
org.eclipse.emf.compare.diff.metamodel.impl.DiffGroupImpl@12b3d53
(conflicting: false, kind: Addition)
Any ideas - thanks :)?
Mark
ps If you want to see the models I can paste the XMI in.
try {
EPackage model = (EPackage)ModelUtils.load(new
File("/home/mmelia/workspace3/AATest/model/A.ecore"), new
ResourceSetImpl());
EPackage.Registry.INSTANCE.put("http://dcu.ie/#A", model);
Resource model1 = ModelUtils.load(new
File("/home/mmelia/workspace3/AATest/model/B.ecore"), new
ResourceSetImpl()).eResource();
Resource model2 =
ModelUtils.load(URI.createFileURI("/home/mmelia/workspace3/AATest/model/C.ecore "),new
final MatchModel match = MatchService.doResourceMatch(model1, model2,
null);
// Detects differences
final DiffModel diff = DiffService.doDiff(match);
// Merges all differences from model1 to model2
EList<DiffElement> el = new BasicEList
<DiffElement>(diff.getOwnedElements());
MergeService.merge(el, true);
Iterator itr = el.iterator();
while(itr.hasNext()){
Object diffElement = itr.next();
DiffElement d = (org.eclipse.emf.compare.diff.metamodel.DiffElement)
diffElement;
System.out.println("here "+ d);
while(d.eContents().iterator().hasNext()){
EObject o = (EObject)d.eContents().iterator().next();
System.out.println(o);
} catch (Exception exception) {
exception.printStackTrace();
> Mark,
> Here is the javadoc for MergeService#merge(List, boolean) which you are
> calling in your code :
> * Merges a list of DiffElements in the direction specified by
> <code>leftToRight</code>.
> * <p>
> * Will notify the list of its merge listeners before, and after the
> operation.
> * </p>
> * @param elements
> * {@link DiffElement}s containing the information to merge.
> * @param leftToRight
> * <code>True</code> if the changes must be applied from the
> left to the right model,
> * <code>False</code> when they have to be applied the other
> way around.
> * @throws ConcurrentModificationException
> * Could be thrown if the list you give is directly a
> reference from the meta model such as
> * {@link DiffModel#getOwnedElements()} or {@link
> DiffElement#getSubDiffElements()}. Copy the
> * list before merging it.
> So yes, a ConcurrentModificationException *can* be thrown as the model
> will be modified when using merge operations. Simply create a new List
> containing all the elements to be merged to avoid these exceptions.
> Laurent Goubet
> Obeo
> Mark Melia a écrit :
>> Hi Sam, Cedric,
>> of a mystery as there is nothing concurrent in what I am doing? The
>> error is below, I am working with EMF Compare 0.8.0v20080506. Any ideas?
>> Mark
>> at
>> at
>> at
>> at
>> Cédric Brun wrote:
>>> Hi Sam,
>>> regards,
>>> Cédric
>>> Sam Sabra wrote:
>>>> Laurent,
>>>> Best regards,
>>>> Sam
>>>>> Sam,
>>>>> Laurent Goubet
>>>>> Obeo
>>>>> Sam Sabra a écrit :
>>>>>> Laurent,
>>>>>> Regards,
>>>>>> Sam
>>>>>>> Sam,
>>>>>>> still happens?
>>>>>>> confirm it.
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>> Sam Sabra a écrit :
>>>>>>>> Good day,
>>>>>>>> below). Any ideas?
>>>>>>>> Thanks,
>>>>>>>> Sam
>>>>>>>> Here's the error:
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> umlPackage);
>>>>>>>> try {
>>>>>>>> true);
>>>>>>>> two models
>>>>>>>> false);
>>>>>>>> try {
>>>>>>>> //$NON-NLS-1$
Re: Merging UML models [message #122710 is a reply to message #122704] |
Tue, 20 May 2008 08:31   |
Hi Laurent,
Thanks for that, it now saves a new model, but the model seems to just be
model1 copied to model2. I am wondering if I am using the right classes,
as I see there are two MergeService classes for EMF compare. I have copied
my import statements - are all these the correct classes to be using?
Apologies for not getting this - and thanks for your patience.
Mark
import org.eclipse.emf.compare.diff.merge.service.MergeService;
import org.eclipse.emf.compare.diff.metamodel.DiffElement;
import org.eclipse.emf.compare.diff.metamodel.DiffModel;
import org.eclipse.emf.compare.diff.service.DiffService;
import org.eclipse.emf.compare.match.metamodel.MatchModel;
import org.eclipse.emf.compare.match.service.MatchService;
import org.eclipse.emf.compare.util.ModelUtils;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.common.util.BasicEList;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.URI
> Mark,
> You will need to save the merged model. Simply put the following line
> before the end of your try/catch :
> model2.save(Collections.emptyMap());
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> something)?
>> iterate the diffElements I get:
>> Mark
>> public static void main(String[] args) {
>> try {
>> ResourceSetImpl());
>> ResourceSetImpl()).eResource(); Resource model2 =
>> MatchService.doResourceMatch(model1, model2, null);
>> DiffElement d =
>> (org.eclipse.emf.compare.diff.metamodel.DiffElement) diffElement;
>>> Mark,
>>> are calling in your code :
>>> * <p>
>>> operation.
>>> * </p>
>>> * @param elements
>>> the left to the right model,
>>> other way around.
>>> Laurent Goubet
>>> Obeo
>>>> Hi Sam, Cedric,
>>>> I now have a new error, a ConcurrentModificationException which is a
>>>> bit of a mystery as there is nothing concurrent in what I am doing?
>>>> The error is below, I am working with EMF Compare 0.8.0v20080506. Any
>>>> ideas?
>>>> Mark
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Cédric Brun wrote:
>>>>> Hi Sam,
>>>>> regards,
>>>>> Cédric
>>>>> Sam Sabra wrote:
>>>>>> Laurent,
>>>>>> Best regards,
>>>>>> Sam
>>>>>>> Sam,
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>> Sam Sabra a écrit :
>>>>>>>> Laurent,
>>>>>>>> Regards,
>>>>>>>> Sam
>>>>>>>>> Sam,
>>>>>>>>> from
>>>>>>>>> new
>>>>>>>>> still happens?
>>>>>>>>> models you
>>>>>>>>> need to
>>>>>>>>> confirm it.
>>>>>>>>> Laurent Goubet
>>>>>>>>> Obeo
>>>>>>>>> Sam Sabra a écrit :
>>>>>>>>>> Good day,
>>>>>>>>>> get
>>>>>>>>>> XMI
>>>>>>>>>> below). Any ideas?
>>>>>>>>>> Thanks,
>>>>>>>>>> Sam
>>>>>>>>>> Here's the error:
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> umlPackage);
>>>>>>>>>> try {
>>>>>>>>>> true);
>>>>>>>>>> two models
>>>>>>>>>> false);
>>>>>>>>>> try {
>>>>>>>>>> the
>>>>>>>>>> //$NON-NLS-1$
Re: Merging UML models [message #122715 is a reply to message #122710] |
Tue, 20 May 2008 08:42  |
--------------070007000108040507010903
Mark,
Obviously, if you copy *all* changes from model1 to model2 ... you will
get a copy of model1 as output. You have to filter out the differences
you want merged. If you simply wish to copy additions, only merge
AddModelElements, for deletions, RemoveModelElements... you will have to
take a look at the list of DiffElement you're merging to obtain the
expected result.
Cheers
Laurent Gobet
Obeo
Mark Melia a
Re: Merging UML models [message #617860 is a reply to message #119142] |
Mon, 21 April 2008 04:15  |
--------------020606000705040607050701
Sam,
happens?
confirm it.
Laurent Goubet
Obeo
Sam Sabra a
Re: Merging UML models [message #617866 is a reply to message #119338] |
Laurent,
Sam
> Sam,
> happens?
> confirm it.
> Laurent Goubet
> Obeo
> Sam Sabra a écrit :
>> Good day,
>> below). Any ideas?
>> Thanks,
>> Sam
>> Here's the error:
>> at
>> at
>> at
>> at
>> at
>> try {
>> models
>> model2, options);
>> try {
>> //$NON-NLS-1$
Re: Merging UML models [message #617871 is a reply to message #119414] |
Tue, 22 April 2008 07:51  |
--------------080609070400090401000107
Sam,
Laurent Goubet
Obeo
Sam Sabra a
Re: Merging UML models [message #617883 is a reply to message #119478] |
Laurent,
Sam
> Sam,
> Laurent Goubet
> Obeo
> Sam Sabra a écrit :
>> Laurent,
>> Regards,
>> Sam
>>> Sam,
>>> still happens?
>>> confirm it.
>>> Laurent Goubet
>>> Obeo
>>> Sam Sabra a écrit :
>>>> Good day,
>>>> below). Any ideas?
>>>> Thanks,
>>>> Sam
>>>> Here's the error:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> umlPackage);
>>>> try {
>>>> two models
>>>> false);
>>>> try {
>>>> //$NON-NLS-1$
Re: Merging UML models [message #617899 is a reply to message #119638] |
Hi Sam,
regards,
Cédric
Sam Sabra wrote:
> Laurent,
> Best regards,
> Sam
>> Sam,
>> Laurent Goubet
>> Obeo
>> Sam Sabra a écrit :
>>> Laurent,
>>> Regards,
>>> Sam
>>>> Sam,
>>>> still happens?
>>>> confirm it.
>>>> Laurent Goubet
>>>> Obeo
>>>> Sam Sabra a écrit :
>>>>> Good day,
>>>>> below). Any ideas?
>>>>> Thanks,
>>>>> Sam
>>>>> Here's the error:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> umlPackage);
>>>>> try {
>>>>> two models
>>>>> false);
>>>>> try {
>>>>> //$NON-NLS-1$
Re: Merging UML models [message #618070 is a reply to message #119844] |
Hi Sam, Cedric,
Mark
Cédric Brun wrote:
> Hi Sam,
> regards,
> Cédric
> Sam Sabra wrote:
>> Laurent,
>> Best regards,
>> Sam
>>> Sam,
>>> Laurent Goubet
>>> Obeo
>>> Sam Sabra a écrit :
>>>> Laurent,
>>>> Regards,
>>>> Sam
>>>>> Sam,
>>>>> still happens?
>>>>> confirm it.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>> Sam Sabra a écrit :
>>>>>> Good day,
>>>>>> below). Any ideas?
>>>>>> Thanks,
>>>>>> Sam
>>>>>> Here's the error:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> umlPackage);
>>>>>> try {
>>>>>> two models
>>>>>> false);
>>>>>> try {
>>>>>> //$NON-NLS-1$
Re: Merging UML models [message #618072 is a reply to message #122682] |
Tue, 20 May 2008 03:08  |
--------------060403030008040902080707
Mark,
* <p>
operation.
* </p>
* @param elements
way around.
Laurent Goubet
Obeo
Mark Melia a
Re: Merging UML models [message #618073 is a reply to message #122692] |
Hi Laurent,
something)?
Mark
try {
ResourceSetImpl());
Resource model2 =
null);
diffElement;
> Mark,
> * <p>
> operation.
> * </p>
> * @param elements
> way around.
> Laurent Goubet
> Obeo
>> Hi Sam, Cedric,
>> Mark
>> at
>> at
>> at
>> at
>> Cédric Brun wrote:
>>> Hi Sam,
>>> regards,
>>> Cédric
>>> Sam Sabra wrote:
>>>> Laurent,
>>>> Best regards,
>>>> Sam
>>>>> Sam,
>>>>> Laurent Goubet
>>>>> Obeo
>>>>> Sam Sabra a écrit :
>>>>>> Laurent,
>>>>>> Regards,
>>>>>> Sam
>>>>>>> Sam,
>>>>>>> still happens?
>>>>>>> confirm it.
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>> Sam Sabra a écrit :
>>>>>>>> Good day,
>>>>>>>> below). Any ideas?
>>>>>>>> Thanks,
>>>>>>>> Sam
>>>>>>>> Here's the error:
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> umlPackage);
>>>>>>>> try {
>>>>>>>> true);
>>>>>>>> two models
>>>>>>>> false);
>>>>>>>> try {
>>>>>>>> //$NON-NLS-1$
Re: Merging UML models [message #618074 is a reply to message #122697] |
Tue, 20 May 2008 07:24  |
--------------010308070404050207040107
Mark,
Laurent Goubet
Obeo
Mark Melia a
Re: Merging UML models [message #618075 is a reply to message #122704] |
Hi Laurent,
Mark
> Mark,
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> something)?
>> Mark
>> try {
>> ResourceSetImpl());
>> DiffElement d =
>>> Mark,
>>> * <p>
>>> operation.
>>> * </p>
>>> * @param elements
>>> other way around.
>>> Laurent Goubet
>>> Obeo
>>>> Hi Sam, Cedric,
>>>> ideas?
>>>> Mark
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Cédric Brun wrote:
>>>>> Hi Sam,
>>>>> regards,
>>>>> Cédric
>>>>> Sam Sabra wrote:
>>>>>> Laurent,
>>>>>> Best regards,
>>>>>> Sam
>>>>>>> Sam,
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>> Sam Sabra a écrit :
>>>>>>>> Laurent,
>>>>>>>> Regards,
>>>>>>>> Sam
>>>>>>>>> Sam,
>>>>>>>>> from
>>>>>>>>> new
>>>>>>>>> still happens?
>>>>>>>>> models you
>>>>>>>>> need to
>>>>>>>>> confirm it.
>>>>>>>>> Laurent Goubet
>>>>>>>>> Obeo
>>>>>>>>> Sam Sabra a écrit :
>>>>>>>>>> Good day,
>>>>>>>>>> get
>>>>>>>>>> XMI
>>>>>>>>>> below). Any ideas?
>>>>>>>>>> Thanks,
>>>>>>>>>> Sam
>>>>>>>>>> Here's the error:
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> umlPackage);
>>>>>>>>>> try {
>>>>>>>>>> true);
>>>>>>>>>> two models
>>>>>>>>>> false);
>>>>>>>>>> try {
>>>>>>>>>> the
>>>>>>>>>> //$NON-NLS-1$
Re: Merging UML models [message #618076 is a reply to message #122710] |
Mark,
expected result.
Cheers
Laurent Gobet
Obeo
Mark Melia a
Current Time: Tue Jul 22 00:42:24 EDT 2025
Powered by FUDForum. Page generated in 0.13166 seconds
