Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Hibernate Paging
Hibernate Paging [message #119092] |
Fri, 18 April 2008 20:03  |
The Hibernate product supports paging feature.
In my database I've 11,000 parts, when the user is looking for a part
that start with 'A', he might end with 1,000 part numbers in one query!
How can I enable paging with TENEO and retrieve a page at a time?
Yigal
Re: Hibernate Paging [message #119298 is a reply to message #119235] |
Sun, 20 April 2008 01:41  |
Hi Yigal,
No the hibernateresource does not support maxresults at least afaik it is not possible to pass the
maxresults in the hql-string itself, but it needs to be set on the query object. So in this case I
would override HibernateResource with your own implementation, you only need to override the
loadUsingDefinedQueries method which is fairly simple to do.
Then you also need to implement and register your own ResourceFactory.
gr. Martin
Yigal wrote:
> I built the architecture around HibernateResource, so I would prefer to
> continue using that.
> I know about the hibernate queries, I just wanted to know if TENEO and
> resource supports the maxResults?
> Thanks
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> Do you mean the setMaxResults on the query? See comments below.
>> gr. Martin
>> MT>> It depends on what you do. Are you using resources or direct
>> hibernate queries? With direct
>> hibernate queries you can use the maxResults. Using the
>> HibernateResource it is more difficult (but not impossible) as the
>> resource api in itself does not support paging. Let me know what you
>> plan to do and then I can comment in more detail.
>>> Thanks
>>> Yigal
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Hibernate Paging [message #617842 is a reply to message #119092] |
Sat, 19 April 2008 02:14  |
Hi Yigal,
gr. Martin
MT>> It depends on what you do. Are you using resources or direct hibernate queries? With direct
hibernate queries you can use the maxResults. Using the HibernateResource it is more difficult (but
not impossible) as the resource api in itself does not support paging. Let me know what you plan to
> Thanks
> Yigal
The Netherlands
Re: Hibernate Paging [message #617852 is a reply to message #119103] |
Sat, 19 April 2008 13:45  |
Yigal
Martin Taal wrote:
> Hi Yigal,
> gr. Martin
>> Thanks
>> Yigal
Re: Hibernate Paging [message #617857 is a reply to message #119235] |
Hi Yigal,
gr. Martin
> Thanks
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> gr. Martin
>>> Thanks
>>> Yigal
The Netherlands
Current Time: Sat Jul 26 14:43:33 EDT 2025
Powered by FUDForum. Page generated in 0.03799 seconds
