Home » Modeling » GMF (Graphical Modeling Framework) » Missing "Layout Constraints" in properties view
Missing "Layout Constraints" in properties view [message #119087] Fri, 13 April 2007 05:48 Go to next message
Originally posted by: snej_NO-SPAM_.esuark.de
Hi there,
i know that i have previously used the layout constraints in the
advanced Tab of the properties view so i could set the position of a
node "by hand".
I just tried it again and i can't find this feature any more.
I lately updated to gmf 1.0.3, could this be the rason?
And if it is so, how could i get the layout constraints back?
Thanks in advance
jens k.
Re: Missing "Layout Constraints" in properties view [message #146537 is a reply to message #119087] Tue, 14 August 2007 09:46 Go to previous messageGo to next message
> node "by hand".
I think i meant Gmf 2.0 ... So is there an easy way to get the layout
constraints back?
I experience that in the gmfgen file a new item appears "Property Sheet"
.... Could i add the constrains with that? Are the layout constraints a
"Standard Property Tab" or similar?
regards
jens
Re: Missing "Layout Constraints" in properties view [message #146544 is a reply to message #146537] Tue, 14 August 2007 10:33 Go to previous messageGo to next message
With a little trial and error i discovered it by myself ... It was the
GenStandartPropertyTab with the id "advanced" which provides the "layout
constrains" ...
End of soliloquy
jens
Re: Missing "Layout Constraints" in properties view [message #147708 is a reply to message #146544] Fri, 24 August 2007 04:59 Go to previous message
> constrains" ...
Well, i managed to add this GenStandartPropertyTab, but it is deleted
after every .gmfmap to gmfgen file transform. Is there a possibility to
make it persist?
regards
jens
Previous Topic:What is the proper way to add a compartment title?
Next Topic:Add a filter to a context Menu
Current Time: Thu Jul 24 10:37:55 EDT 2025
Powered by FUDForum. Page generated in 0.03137 seconds
