invalid feature Component/bounds [message #119084] |
Mon, 27 February 2006 17:18  |
I have a plugin that I am trying to convert from VE 1.0 to 1.1. As I am
initializing bean proxies I get an IllegalArgumentException "The feature
"bounds" is not a valid feature" during the useComponentSize call in
this method of ComponentProxyAdapter. The 1.0 didn't have the
postInstantiateStuff method so I don't know what to do or change.
private void postInstantiateStuff(IExpression expression, IProxy newbean) {
getComponentManager().setComponentBeanProxy(newbean, expression,
getModelChangeController());
if (ffHost != null) {
// Now finish the instantiation on the freeform.
try {
// try {
// .. do freeform stuff ..
expression.createTry();
ffProxy = ffHost.add(this, newbean, expression);
// Set the initial use component size.
ffProxy.useComponentSize(newbean,
getEObject().eIsSet(sfComponentBounds) ||
getEObject().eIsSet(sfComponentSize), expression);
Andy Arhelger
Re: invalid feature Component/bounds [message #119110 is a reply to message #119084] |
Mon, 27 February 2006 18:31   |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Your visual component must be a subclass of awt.Component AND your
beaninfo must not hide or remove the "bounds" property. If it wasn't a
subclass of Component or you hid the "bounds" property, then this will fail.
> try {
> // try {
> Andy Arhelger
Rich Kulp
Re: invalid feature Component/bounds [message #119369 is a reply to message #119329] |
Tue, 28 February 2006 13:44  |
That would cause the problem. And why it won't work. To use
ComponentProxyAdapter it must be a subclass of awt.Component.
> Yes, we must. I am not the original author of this so am trying to learn
> as I go here.
> In the bean override file we specify a beanProxyClassName. I assume this
> is how the proxy gets associated with the bean?
> Rich Kulp wrote:
>> If it wasn't a subclass of awt.Component, then how do it get to have a
>> ComponentProxyAdapter? Did you force this?
Rich Kulp
Re: invalid feature Component/bounds [message #612195 is a reply to message #119084] |
> try {
> // try {
> Andy Arhelger
Rich Kulp
Re: invalid feature Component/bounds [message #612204 is a reply to message #119110] |
Tue, 28 February 2006 09:59  |
Thanks. Hmmm.... It isn't a subclass of awt.Component and I am not sure I want it to be.
It actually represents a generic control object. I can try making it a subclass of
awt.Component and see what conflicts I get.
> fail.
>> am initializing bean proxies I get an IllegalArgumentException "The
>> feature "bounds" is not a valid feature" during the useComponentSize
>> call in this method of ComponentProxyAdapter. The 1.0 didn't have the
>> newbean) {
>> try {
>> // try {
>> Andy Arhelger
Re: invalid feature Component/bounds [message #612213 is a reply to message #119278] |
Tue, 28 February 2006 12:13  |
Yes, we must. I am not the original author of this so am trying to learn as I go here.
In the bean override file we specify a beanProxyClassName. I assume this is how the proxy
Re: invalid feature Component/bounds [message #612216 is a reply to message #119329] |
> as I go here.
Rich Kulp
FUDForum. Page generated in 0.26429 seconds
