| SQLResultRunnable for UserDefinedFunction (UDF) [message #10829] |
Wed, 19 April 2006 07:56  |
Originally posted by: anil.samuel.gmail.com
DTP - 0.9.0.200604141
I am using the default Run action for Routine class, which uses
RoutineEditor. This causes
org.eclipse.datatools.sqltools.routineeditor.launching.SPLau nchConfigurationDelegate
to handle the launching, where this issue is.
Issue is that current implementation uses
org.eclipse.datatools.sqltools.sqleditor.result.SimpleSQLRes ultRunnable
to handle the UDF type launching. If this was changed to be similar to
the case of Stored Procedure, then the plugin provider can provide a
org.eclipse.datatools.sqltools.core.services.ExecutionServic e instance
to handle it.
Any thoughts ?
Anthos
| Re: SQLResultRunnable for UserDefinedFunction (UDF) [message #11542 is a reply to message #11469] |
Thu, 27 April 2006 01:01  |
Hi Hui
I am working on extending DTP for Oracle DB connectivity.
I am planning to use
?=schema.function(?,..)
in case of UDF.
Did that make sense ?
Anthos
Hui Cao wrote:
> Hi Anthos,
> This sounds good, and I'll look into it. BTW, the Derby catalog loader
> can't populate Derby Function objects well, as mentioned in BZ:129334.
> Just curious, what kind of customization do you plan to do in the case
> of UDF?
> Regards
> Hui Cao
> DTP SQL Dev Tools committer
> Sybase Inc
| Re: SQLResultRunnable for UserDefinedFunction (UDF) [message #573005 is a reply to message #10829] |
Mon, 24 April 2006 02:17  |
Anil Samuel wrote:
> Hi
> to handle it.
> Any thoughts ?
> Regards
> Anthos
Hi Anthos,
Just curious, what kind of customization do you plan to do in the case of
UDF?
Hui Cao
Sybase Inc
| Re: SQLResultRunnable for UserDefinedFunction (UDF) [message #573078 is a reply to message #11469] |
Hi Hui
in case of UDF.
Anthos
Hui Cao wrote:
> Hi Anthos,
> of UDF?
> Regards
> Hui Cao
> Sybase Inc
FUDForum. Page generated in 0.03573 seconds
