Home » Archived » BPMN Modeler » Deletion of Task
Deletion of Task [message #10822] Thu, 16 April 2009 09:11 Go to next message
Hi there,
I'm trying to delete the task that is automatically inserted on creation
of a pattern.
Currently I'm able to change the activitytype, id, name and so on, but I
did not found out how to delete it from the pool. Returning the vertices
of the pool and clearing the list does not make any difference...I also
tried calling removeAdapter, with the same result. Can someone give me a
hint how to delete it.
BTW: It would be better not to have the task anyway - is there a reason
why it is inserted there - if not is there a bug existing?
--Verena
Re: Deletion of Task [message #11262 is a reply to message #10822] Thu, 16 April 2009 09:36 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Verena wrote:
> Hi there,
> of a pattern.
You mean on creation of a new diagram, a pool and a task are present.
You just need to change the initial contents of the diagram, look at the
wizard code.
No. This was actually requested by users.
> --Verena
Re: Deletion of Task [message #11372 is a reply to message #11262] Wed, 22 April 2009 03:43 Go to previous message
Antoine Toulme wrote:
> Verena wrote:
>> Hi there,
>> of a pattern.
This is exactly what I meant - sorry.
> wizard code.
I found out how to do that thanks. An other Problem occured to me. I'd
probably better open a new thread for that since thi shas nothing to do
with the topic. Thanks for your help.
Previous Topic:Problems when connecting two elements
Next Topic:Change Labels of PopupBar
Current Time: Fri Nov 07 08:14:32 EST 2025
Powered by FUDForum. Page generated in 0.03656 seconds
