Home » Language IDEs » C / C++ IDE (CDT) » CDT 2.0.1 is now available
CDT 2.0.1 is now available [message #118608] Wed, 01 September 2004 13:40 Go to next message
Originally posted by: ddaoust.ca.ibm.com
CDT 2.0.1 is now available for download. You can find the update site and
zip files at:
http://update.eclipse.org/tools/cdt/releases/new
A list of defects that have been addressed can be extracted from Bugzilla
(there is a shortcut to the query on the "New" section of the CDT home
page.)
http://www.eclipse.org/cdt
The CDT development teams appreciate the feedback that we have been getting
(both in bugzilla and on this newsgroup). If you would like to contribute
to the CDT, as a user, a tester, a developer, or if you just wish to have
your least favorite bug removed, please look at the FAQ on how to contribute
to the CDT.
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/user/faq.html?cvsroot=Tools_Project
- Dave
David Daoust
CDT Development Manager
IBM - Rational Software
Re: CDT 2.0.1 is now available [message #118943 is a reply to message #118608] Thu, 02 September 2004 09:40 Go to previous messageGo to next message
Originally posted by: dejan.nu6.org
There is no new CDT 2.0.1 in Eclipse updates... why?
Dejan Lekic
developer, sysadmin and DBA
http://dejan.lekic.org
Re: CDT 2.0.1 is now available [message #119111 is a reply to message #118943] Thu, 02 September 2004 14:31 Go to previous messageGo to next message
Because you don't want to use it (I think). I tried it today (using the
zip) and it hangs even if you are scrolling a file of 88 lines or give
in text. It lasts not even two hours on my PC, would have been one, but
it hangs to often. ;o)
Re: CDT 2.0.1 is now available [message #119124 is a reply to message #119111] Thu, 02 September 2004 14:44 Go to previous messageGo to next message
Edzard,
I think maybe you corrupted your install. We haven't seen anything
remotely like that in our testing.
If Eclipse/CDT is crashing as frequently as you say, it will leave
behind a log file in the '.metadata' directory of your worskpace with a
stack trace.
Why not start with a clean Eclipse 3.0 install, install CDT 2.0.1 from
the update site, and try again. If the problem persists, look for the
stack dump and put it in a bugzilla report along with the steps to
duplicate the problem.
Sean
Re: CDT 2.0.1 is now available [message #119273 is a reply to message #119124] Fri, 03 September 2004 05:22 Go to previous messageGo to next message
Hello Sean,
no, it is not crashing, it hangs, gets stuck, hooks (I'm not native
english speaker). For example, when typing in text (I'm fast ;o) the
text doesn't appear for a moment and then I can see it coming (typing a
little faster than me ;o). Similar the scrolling - taking the scrollbar
by mouse and moving the text up and down it stops for a moment and then
goes on. This is different to CDT 2.0.0.
I ordered a faster PC (not only for Eclipse ;o) and will try to use
features, when working on it. But in the moment CDT 2.0.0 is good
enough, I learned how to use it and there are several things I like.
Ed
Re: CDT 2.0.1 is now available [message #119354 is a reply to message #119273] Fri, 03 September 2004 11:13 Go to previous messageGo to next message
I've got the same problem!
My Eclipse (and with it the rest of the computer) gets stuck nearly
every ten minutes and nothing happens until i quit it (the 'x' button
works).
I've already tried a clean install and tried also on another pc.
(on a XP 2400+, 512 MB Ram, WinXP SP2 and a Duron 700, 256 MB RAM, WinXP
SP1 (both via ZIP and/or Updater)
On both PC's CDT's behaviour stays the same.
I don't know what to do next.
(when I close Eclipse i get a window with a error message, but I can't
remember what. I'll writ it down the next time I see it!)
Daniel
Re: CDT 2.0.1 is now available [message #119366 is a reply to message #119354] Fri, 03 September 2004 11:38 Go to previous messageGo to next message
> works).
> Daniel
Maybe I found the Solution for at least my problem (maybe everyone else
knows that already):
I didn't use the same workspace as the old version, instead I used a new
directory and imported my code.
Since I did this everything seems to work fine.
Daniel
Re: CDT 2.0.1 is now available [message #119419 is a reply to message #119366] Sat, 04 September 2004 05:16 Go to previous messageGo to next message
Hmm, seems that this is not working really good;
I got the following message window when closing eclipse manually:
> JVM terminated. Exit code=1073807364
> D:\WINDOWS\system32\javaw.exe
> -cp E:\eclipse\startup.jar org.eclipse.core.launcher.Main
> -os win32
> -ws win32
> -arch x86
> -showsplash E:\eclipse\eclipse.exe -showsplash 600
> -exitdata E:\eclipse\eclipse.exe -exitdata 238_48
> -vm D:\WINDOWS\system32\javaw.exe
> -vmargs
I don't know if I've made a mistake or if this is the programs fault.
Daniel
Re: CDT 2.0.1 is now available [message #119445 is a reply to message #119419] Sat, 04 September 2004 12:53 Go to previous messageGo to next message
I still don't have it in Eclipse updates... :(
Kind regards
Dejan
Dejan Lekic
Re: CDT 2.0.1 is now available [message #119458 is a reply to message #119445] Sat, 04 September 2004 12:56 Go to previous messageGo to next message
*g* you are kidding, aren't you? The zip-file works... (Programmers
should be pragmatical ;o)
Re: CDT 2.0.1 is now available [message #119470 is a reply to message #119458] Sat, 04 September 2004 14:03 Go to previous messageGo to next message
No, I am not kidding. I simply do not want to bother with downloading stuff
anytime something newer comes out. If there is clean, safe way to have
software updates - like Eclipse does - I would allways use it.
Best regards
Dejan
Dejan Lekic
Re: CDT 2.0.1 is now available [message #119483 is a reply to message #119470] Sat, 04 September 2004 15:52 Go to previous messageGo to next message
maybe you are right and there is a way, to use this software updates
right now. I'm more pessimistic and regard it as another bug - with
lowest priority, because it affects the user only once for a couple of
weeks. Momentary the recommended clean and safe way seems to be a clean
installation. That doesn't affekt me, because I'm using windows and the
recommended way to react for problems... ;o)
This is not a perfekt world and resources are low, so I hope CDT
developers will do things first, that bother everytime using CDT.
Ed
Re: CDT 2.0.1 is now available [message #119492 is a reply to message #119445] Sat, 04 September 2004 18:57 Go to previous messageGo to next message
In general, a comment that translates to "it is broken" (without any detail)
is ignored by anybody that could help you.
If you were to provide the steps that you did, followed by what actually
happens, and then tell us what is different from what you expect, you are
likely to get help.
For example,
I installed eclipse-SDK-3.0-win32.zip into c:\eclipse which was a new
empty directory
I then started eclipse, selected a new workspace.
From the help menu, I select SoftwareUpdates->Find and Install
Select Search for new features to install
Add a new remote site http://update.eclipse.org/tools/cdt/releases/new
(I called it CDT)
I expanded this new site and selected CDT 2.0.1
Then I selected the Eclipse C/C++ Development Tools
After accepting all the legal mumbo jumbo, Everything installed
I did this before sending the initial posting about 2.0.1 and I did it again
before responding to this post.
There is a funny artical written on how to get help in an open source
environment "How to ask questions the smart way" by Eric Raymond. (This
is mentioned in the FAQ). The people who work on the CDT are not as
behaviorially challanged as the examples in the article (my opinion -- it is
likely that I am biased), but there is a lot of good advice that applies
anyway.
- Dave
"Dejan Lekic" <dejan@nu6.org> wrote in message
news:chcrg3$q3a$1@eclipse.org...
> Kind regards
> Dejan
> Dejan Lekic
> http://dejan.lekic.orgN
Re: CDT 2.0.1 is now available [message #119515 is a reply to message #119492] Mon, 06 September 2004 04:26 Go to previous messageGo to next message
Hello David,
this was the point I got stuck, before trying the zip. This way really
seems to be much better, because in the moment it looks like my problem
of getting stuck while editing is gone. Famous!
Ed
Re: CDT 2.0.1 is now available [message #119524 is a reply to message #119470] Mon, 06 September 2004 04:27 Go to previous messageGo to next message
Hello Dejan,
now I see you are right.
Ed
Re: CDT 2.0.1 is now available [message #119588 is a reply to message #119492] Mon, 06 September 2004 09:29 Go to previous messageGo to next message
David, i didn't quite understand why you are telling ME this? I didn't say I
had any particular problem. Simply, I said there there is no new 2.0.1 in
Eclipse/CDT automatic updates...
Kind regards
Dejan
Dejan Lekic
Re: CDT 2.0.1 is now available [message #119601 is a reply to message #119588] Mon, 06 September 2004 10:13 Go to previous messageGo to next message
But there is a CDT 2.0.1 update site. (it was in my original post, it is on
the download page, ....)
I was saying that I have no idea why YOU have a problem doing this. It
works for me. If you want anybody to help, YOU need to explain what you
did, and what didn't work.
If you don't have a problem, I don't understand why you sent the original
post. Did you want someone to do something? If so, who? and what?
- Dave
news:chho9h$8i6$1@eclipse.org...
I
> Kind regards
> Dejan
> Dejan Lekic
Re: CDT 2.0.1 is now available [message #119613 is a reply to message #119601] Mon, 06 September 2004 10:48 Go to previous messageGo to next message
It's not a problem - I have working CDT. I simply do not have ability to
update CDT to 2.0.1 . You know, option doesn't appear. But that is not a
big issue. CDT I have works pretty fine...
Kind regards
Dejan
Dejan Lekic
Re: CDT 2.0.1 is now available [message #119777 is a reply to message #119613] Tue, 07 September 2004 10:49 Go to previous messageGo to next message
Hi Dejan,
I think Dave's concern is whether or not the update site is somehow
broken and if it is, we want to make sure other users don't encounter
the same problem. Basically, we are trying to press you into service as
a tester. If you could tell us the steps you take that end up with no
2.0.1 update available, we would appreciate it because as far as we can
tell from our side, there is nothing wrong.
Sean
> Kind regards
> Dejan
Re: CDT 2.0.1 is now available [message #119787 is a reply to message #119419] Tue, 07 September 2004 10:54 Go to previous messageGo to next message
So Daniel,
Your work-around of creating a new workspace does not solve the problem?
Just out of curiosity, what was the last version of the CDT you were
using (i.e. was it a 1.2 -> 2.0.1 upgrade, or a 2.0 -> to 2.0.1
upgrade). As well, what version of Eclipse are you running with?
Finally, do you have a .log file in your .metadata directory? If so, it
should have a stack trace which may help pin-point the problem.
>> else knows that already):
>> -os win32
>> -ws win32
>> -arch x86
>> -vmargs
> Daniel
Re: CDT 2.0.1 is now available [message #119928 is a reply to message #119787] Tue, 07 September 2004 14:37 Go to previous messageGo to next message
Sean Evoy wrote:
> So Daniel,
The last Version of CDT I was using was: 2.0
At the time of my last post I used Eclipse 3.0 and now I'm using
Version: 3.1.0
Build id: 200409011200
I'm using jre 1.4.2.
Since Installing 3.1.0 the problem occurs not so often but is not gone
completely
I did a search with google and it seems that something is causing
javaw.exe to shut down.
I found this explanation for a (maybe??) similar error with another
eclipse plugin:
> When opening a pre-existing html page, clicking o­n the visual designer tab causes Eclipse to hang indefinitely, then crash o­n forced exit with an javaw.exe error (exit code: 1073807364). I'm running Eclipse 3.0, workbench version 3.7.2.00 Build id: 200407091200-3.8-Beta2. Please advise
> There is a known bug with 3.8 Beta 2 in the visual design where a certain set of HTML will cause the designer to go into an infinite loop
I do not know if this has something to do with my problem, because I'm
rather new to programming and specially with java!!
There is no log-file in my .metadata directory
Thanks for your help,
Daniel
Re: CDT 2.0.1 is now available [message #119953 is a reply to message #119366] Tue, 07 September 2004 14:51 Go to previous messageGo to next message
Daniel,
I wonder if you still have the old workspace kicking around if you could
check whether the option:
Windows > Preferences > C/C++ > Search > Enable external search markers
is set. Thanks,
Sean
>> works).
>> WinXP SP1 (both via ZIP and/or Updater)
>> Daniel
> Daniel
Re: CDT 2.0.1 is now available [message #120053 is a reply to message #119953] Wed, 08 September 2004 02:52 Go to previous messageGo to next message
Sean Evoy wrote:
> Daniel,
> is set. Thanks,
> Sean
Sean:
The External search markers is not set.
I deleted my old workspace when "installing" a new.
I wonder if my problem is similar to (or the same as) exquisitus' and
Per Arnold Blasmo's (in the 'crash in version 2.0.1 thread)???
Sometimes (or most of the time?, i can't tell exactly) the problem
occurs when indexing.
But then it doesn't happen very often since I installed eclipse 3.1
(though it is still annoying)
Daniel
Re: CDT 2.0.1 is now available [message #120203 is a reply to message #120053] Wed, 08 September 2004 21:06 Go to previous messageGo to next message
If you can raise a defect w/a code example or project that causes the
problem, I'll take a look at it this week.
JC
"Daniel Jeller" <djeller@chello.at> wrote in message
news:chm9vf$r70$1@eclipse.org...
> Sean Evoy wrote:
> > Daniel,
> > is set. Thanks,
> > Sean
> Sean:
> Daniel
Re: CDT 2.0.1 is now available [message #120316 is a reply to message #120203] Wed, 08 September 2004 22:36 Go to previous messageGo to next message
> JC
Thanks for your help!
I'll try to get some code with an reproducable error.
But I don't know if I'm able to do reproduce the error, because im not
getting it that often than when I first wrote a post in this thread.
Daniel
Re: CDT 2.0.1 is now available [message #120895 is a reply to message #120316] Mon, 13 September 2004 14:58 Go to previous messageGo to next message
Sorry, it seems, I'm not able to get this error reproducable.
should i raise a bug anyways??
Daniel
Re: CDT 2.0.1 is now available [message #121027 is a reply to message #120895] Tue, 14 September 2004 23:04 Go to previous message
Sure, just be clear in the defect that its not easily reproducible.
JC
news:ci4qcc$8iv$1@eclipse.org...
> Daniel
Previous Topic:Using CDT only for a C++ Editor, no compiling
Next Topic:replacement for MS-Visual Studio
Current Time: Sun Nov 30 00:50:30 EST 2025
Powered by FUDForum. Page generated in 0.06284 seconds
