| Error launching builder (make -k clean all ) [message #118586] |
Wed, 01 September 2004 12:06  |
Originally posted by: hmetu.gmx.net
Hi!
While trying to make, my console indicates the following error-message
"Error launching builder (make -k clean all )(Exec error:Launching failed)".
I have read C/C++ Development User Guide and was made to understand that I
have to indicate the build command. I am working with MinGW, so I entered my
build command (under Project-Properties-C++...) mingw32-make and restarted
eclipse, but to no avail, although I the path of mingw/bin is correctly set.
Am I still missing something?
Harp
| Re: Error launching builder (make -k clean all ) [message #119314 is a reply to message #118627] |
Fri, 03 September 2004 08:13  |
Thanks Sean!, you got it right!
I did install msys, tried the batch as you said, changed the build command
from make to mingw32-make (under window->preferences->c/c++->new make
projects), went to project->properties->active configuration and clicked on
"manage". A dialog was brought up where I could uncheck the "Use default
command" into "mingw32-make -k" instead of the former "make -k" (which was
there originally). With these, the build was able to work...
Quite grateful!
Harp
"Sean Evoy" <sevoy@ca.ibm.com> wrote in message
news:ch520c$bjr$1@eclipse.org...
> Harp,
> So it looks like you have resolved the installer problems you were
> experiencing. That's good. I'd recommend getting MSYS if you plan on
> using MinGW. Even the MinGW guys recognize that the win32 version of
> make that they ship is troublesome, and let's not even start with the
> problems that using the Win32 command shell introduce. Do yourself an
> enormous favour and install MSYS.
> Back to the problem. How do you know that Eclipse is running in an
> environment that has the path to the make utility? The easiest way to
> confirm this is to create a batch file
> @echo off
> set PATH=C:\msys\1.0\bin;C:\mingw\bin;%PATH%
> start <path to eclipe>\eclipse -data <path to workspace>
> That way at least, you are assured that the PATH is correct and we can
> eliminate that as a cause.
> Sean
> Harp wrote:
> > Hi!
failed)".
I
entered my
restarted
set.
> > Thanks
> > Harp
FUDForum. Page generated in 0.03511 seconds
