Home » Archived » Test and Performance Tools Platform (TPTP) » Logging in AGR
Logging in AGR [message #118553] Thu, 22 November 2007 10:56 Go to next message
I am using TPTP (4.4.1) with AGR (4.1) on Eclipse 3.3.1.1, and would
like to add reporting for unresolved widgets. I am following the guide
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html,
section 2.4.2, but there are inconsistencies with the documentation and
reality.
The first two points in the guide are:
1. Add a new test case: Open the test suite > Switch to the 'Test
Cases' page > Click on 'Add'
2. Start a fresh workbench: Start a workbench with a different
workspace > Click on the 'Window' menu > Preferences... > Select
Profiling and Logging > Check the option 'Enable logging' > OK
There is no Add button on the test cases page, and no 'Enable Logging'
option in the preference page described.
I would appreciate some help in getting started.
I would also like to report this as a bug against the documentation but
there is no option for AGR in bugzilla. Where should I report problems?
Channing
Re: Logging in AGR [message #118560 is a reply to message #118553] Fri, 23 November 2007 06:34 Go to previous messageGo to next message
Hi Channing,
You are using a dated version of the AGR documentation. For 4.4.x,
please see:
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html
If you still find an issue with the documentation, please open a defect
against the Test.Doc component:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20T esting
Currently, there is no logging infrastructure for unresolved widgets.
The only notification is the error dialog and an entry in the test execution
file (e.g. *.execution).
Paul
"Channing Walton" <channingwalton@mac.com> wrote in message
news:fi48qv$93d$1@build.eclipse.org...
> I am using TPTP (4.4.1) with AGR (4.1) on Eclipse 3.3.1.1, and would like
> to add reporting for unresolved widgets. I am following the guide at
> reality.
> 1. Add a new test case: Open the test suite > Switch to the 'Test Cases'
> 2. Start a fresh workbench: Start a workbench with a different workspace >
> Click on the 'Window' menu > Preferences... > Select Profiling and Logging
> Channing
Re: Logging in AGR [message #118564 is a reply to message #118560] Fri, 23 November 2007 10:41 Go to previous message
Thanks Paul, I'll have a look at the new documentaton.
Channing
Paul Slauenwhite wrote:
> Hi Channing,
> please see:
Previous Topic:TPTP closes eclipse
Next Topic:Compatibility with JRE 1.5
Current Time: Sat Nov 08 15:09:19 EST 2025
Powered by FUDForum. Page generated in 0.03373 seconds
