Home » Eclipse Projects » Remote Application Platform (RAP) » Building on M4
Building on M4 [message #118523] Mon, 19 January 2009 00:40 Go to next message
I am trying to build my application using M4, but pde.exportFeatures
doesn't create any files and I cannot find error log or output.
Where I can find information about error?
Re: Building on M4 [message #118538 is a reply to message #118523] Mon, 19 January 2009 05:28 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
Hi Boris,
did you make sure that the ant script is running with "use same JRE as workspace" option?
Greetings,
Ben
Boris Stepanov schrieb:
Re: Building on M4 [message #118549 is a reply to message #118538] Mon, 19 January 2009 05:44 Go to previous messageGo to next message
Yes, this script built tens WARs already, but now it doesn't work. The
best way to understand error is take a look at error log, but I can't
find it.
Ben W. пишет:
> Hi Boris,
> workspace" option?
> Greetings,
> Ben
Re: Building on M4 [message #118938 is a reply to message #118549] Tue, 20 January 2009 17:14 Go to previous messageGo to next message
I have experienced the same error. It may be helpful to specify
"-verbose" in the Main->Arguments section of your External Tools
Configuration.
We found in our case that the org.eclipse.equinox.http.servletbridge
plugin was not in our M4 target platform.
Re: Building on M4 [message #118964 is a reply to message #118938] Tue, 20 January 2009 23:52 Go to previous message
Hi Austin,
I added "-verbose" as you describe, but it only shows information from
my ant task, but I need to see error infromation from pde.exportFeatures
task (this task executes in separate job).
I found the solution. I just tried to export my feature by hands from
"File->Export->Plug-in Development->Deployable features" and error
dialog was appeared. The problem is javax.servlet project was downloaded
from 2_4 branch (M4 works with 2_5), so I just switched branch to 2_5
and now my build script works good.
> Configuration.
Previous Topic:Recall of IEntryPoint.createUI() after saving editor
Next Topic:Workbench won't open with current CVS HEAD (19.01.2009 14:29 gmt+1)
Current Time: Tue Jul 22 13:59:09 EDT 2025
Powered by FUDForum. Page generated in 1.05403 seconds
