Home » Archived » BIRT » tempDir
tempDir [message #118500] Fri, 27 January 2006 05:32 Go to next message
Originally posted by: jan.tanis.coas.com
I'm using config.setTempDir(tempDir); to set the dir for the images, but
it still puts them in C:'documents and settings..... Any clue on this?
Regards, Jan.
Re: tempDir [message #120400 is a reply to message #118500] Mon, 30 January 2006 13:24 Go to previous messageGo to next message
Jan,
Use
HTMLRenderContext rc = HTMLRenderContext();
rc.setImageDirectory("yourlocation");
To handle the images
Jason
"Jan Tanis" <jan.tanis@coas.com> wrote in message
news:drcsre$56e$1@utils.eclipse.org...
> Regards, Jan.
Re: tempDir [message #120655 is a reply to message #120400] Tue, 31 January 2006 01:18 Go to previous messageGo to next message
Jason,
How do I append the HTMLRenderContext to the emitter? I assume that that
is not done automatically.
Regards, Jan.
Jason Weathersby wrote:
> Jan,
> Use
> Jason
>>Hi,
>>Regards, Jan.
Re: tempDir [message #121626 is a reply to message #120655] Tue, 31 January 2006 07:29 Go to previous messageGo to next message
Jan,
If you are running this with the API and
you have setup a IRunAndRenderTask task.
then it is just
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("image");
HashMap contextMap = new HashMap();
contextMap.put( HTMLRenderContext.CONTEXT_NAME, renderContext );
task.setContext( contextMap );
Jason
news:drmvgs$vua$1@utils.eclipse.org...
> Jason,
> Regards, Jan.
>> Jan,
>> Use
>> Jason
>>>Hi,
>>>Regards, Jan.
Re: tempDir [message #122402 is a reply to message #121626] Wed, 01 February 2006 01:24 Go to previous messageGo to next message
What is wrong with my package?
> Jan,
> then it is just
HTMLRenderContext.CONTEXT_NAME is not available
Can't do this, Eclipse says that this is not in the API
> Jason
>>Jason,
>>Regards, Jan.
>>>Jan,
>>>Use
>>>Jason
>>>>Hi,
>>>>Regards, Jan.
Regards, Jan.
Re: tempDir [message #122755 is a reply to message #122402] Wed, 01 February 2006 07:43 Go to previous messageGo to next message
Did you add the Jars from the Report Engine folder to your project?
Jason
news:drpk6o$g8f$1@utils.eclipse.org...
>> Jan,
>> then it is just
>> Jason
>>>Jason,
>>>Regards, Jan.
>>>>Jan,
>>>>Use
>>>>Jason
>>>>>Hi,
>>>>>but it still puts them in C:'documents and settings..... Any clue on
>>>>>this?
>>>>>Regards, Jan.
> Regards, Jan.
Re: tempDir [message #122947 is a reply to message #122755] Thu, 02 February 2006 01:03 Go to previous messageGo to next message
Hi Jason,
Yes, I did. It can find the needed classes. But the classes don't have
the functions you show.
Regards, Jan.
> Jason
>>Hi,
>>>Jan,
>>>then it is just
>>>Jason
>>>>Jason,
>>>>Regards, Jan.
>>>>>Jan,
>>>>>Use
>>>>>Jason
>>>>>>Hi,
>>>>>>this?
>>>>>>Regards, Jan.
>>Regards, Jan.
Re: tempDir [message #122959 is a reply to message #122402] Thu, 02 February 2006 04:00 Go to previous message
If you are using BIRT 2.0M2 or older version then
use following code:
task.setContext(contextMap);
For BIRT 2.0M3 and newer versions use following code:
HashMap appContext = new HashMap( );
appContext.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT,
renderContext );
task.setAppContext( appContext );
Bharat
Previous Topic:Creating report off an XML schema only
Next Topic:BIRT reports 1.1 and 2.0 mismatch
Current Time: Thu Nov 13 02:51:44 EST 2025
Powered by FUDForum. Page generated in 0.04957 seconds
