Home » Eclipse Projects » GEF » View & Model separation (Logic example)
View & Model separation (Logic example) [message #118469] |
Thu, 19 February 2004 13:29  |
Originally posted by: bharath.starthis.com
Hi Devs,
In the GEF Logic example, is the class "LogicDiagram" created in order to
separate the view logic from the business logic?
I am trying to separate model information from view information (I have
them in the same package, like the WORKFLOW example). I know this is an
EMF based question, I'm asking it here because its a part GEF Logic
example which people here seem to be very familiar with.
Thanks much!
Bharath.
Re: View & Model separation (Logic example) [message #118479 is a reply to message #118469] |
Thu, 19 February 2004 14:42   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Bharath wrote:
> Hi Devs,
Logicdiagram class really contains no logic. Its just the model which
represents what is to be shown. The so called view logic you refer to
is closest matched by the LogicDiagramEditPart.
The closest example of a 'business logic' class could be LEDEditPolicy.
What do you mean model 'information' from view 'information?' There is
only 1 information. So called view-information I presume is info used
to display your model data, but that can be created at runtime and is
only involved with presentation? I think the EditPart is the home of
this, and the EditPolicy is one means of making it more dynamic.
> Thanks much!
> Bharath.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: View & Model separation (Logic example) [message #118573 is a reply to message #118508] |
Fri, 20 February 2004 10:57   |
Hi Phil,
For some strange reason, I could not find the thread for that date. I
shall however keep looking. Anyway, my understanding is that, to separate
view information, I should have a class called "Logic Diagram" in a
separate model which extends "LogicSubPart" (the corresponding business
model). Once I generate code for this view model, I should see
"LogicDiagramFactory" class which will help me create diagram objects.
The strange thing is, in "LogicSubPart", I find the attributes "location"
and "size". This simply means that the view information is still not
isolated from the model, right? Why do I need the "LogicDiagram" class in
that case?
Please correct me if I am thinking on the wrong lines & Thanks for your
help!
Bharath.
Phil Williams wrote:
> There is a thread from 1/27/04 entitled "separate view model and
> business model" that discusses this further. You might want to check it
> out.
> Phil
> Bharath wrote:
> >Hi Gilbert,
> >I thought so too. I am trying to change my model design by isoating view
> >information from business logic but I'm having several problems. Thanks
> >for your comments, I know that I'm thinking on the right lines now.
> >Cheers.
> >CL [dnoyeb] Gilbert wrote:
> >>Bharath wrote:
> >>>Hi Devs,
> >>>Thanks much!
> >>>Bharath.
Re: View & Model separation (Logic example) [message #118696 is a reply to message #118573] |
Fri, 20 February 2004 15:44  |
If you want stuff split into business and diagram models, you need to do all
of this in your model. There are no GEF concepts which map directly onto
this problem. Read the GEF tutorial which talks about split models,
specifically class diagrams.
"Bharath" <bharath@starthis.com> wrote in message
news:c15app$64h$1@eclipse.org...
> Hi Phil,
> that case?
> help!
Current Time: Mon Oct 20 07:53:25 EDT 2025
Powered by FUDForum. Page generated in 0.05254 seconds
