Home » Eclipse Projects » Remote Application Platform (RAP) » List of founded bugs
List of founded bugs [message #118435] Wed, 14 January 2009 06:28 Go to next message
Hello
I found some problems in M4 build. I made a snippet that can be used to
reproduce this bugs. I can create tickets in issue-system if it necessary
and attach my snippet.
My snippet is a workbench with only one window with TableViewer inside.
TableViewer contains three columns. The first one with TextCellEditor. The
second one with ComboBoxCellEditor and the last one with
CheckBoxCellEditor. The header is visible. The application called
"TableViewer Demo Application".
This is a list of founded problems.
1. qx.ui.form.TextField: Element must be visible (looks like known bug)
1) Open TableViewer Demo Application. There are a TableViewer in the
window. The first column of the TableViewer has a TextCellEditor on it.
2) Activate CellEditor in some cell of the first column. Start editing.
Press Enter.
There will be an error:
Could not evaluate javascript response:
qx.ui.form.TextField: Element must be visible!
3) Reopen the application
4) Very fast click several times on one of the cells of first column.
There will be the same error:
Reproducible both in IE 7 and Firefox 3.0
2. Wrong selection behaviour (looks like known bug)
window.
2) Select some row by mouse. Select another row. Repeat this several times.
You will see that sometimes the selection will not be changed when the
CellEditor of the clicked row will be activated.
3. Problems with editing with ComboBoxCellEditor
window.
2) Try to edit values in the second column of the table viewer. Try to do
this several times.
Sometimes you will not be able to submit value from drop-down-lict by
double-clicking.
Sometimes the drop-down-lict will disappear immediately after activation.
4. TextChanged event does not occure when the text of TextCellEditor
changes in Firefox 3.0
1) Open TableViewer Demo Application with Firefox 3.0. There are a
TableViewer in the window.
2) Change the text of some cell in first column
3) Deactivate cell editor of this cell by clicking another cell.
The text of the cell will not be changed. The ICellModifier#modify will
not be executed.
Reproducible only in Firefox 3.0
5. Rows can disappear when resizing the main container after scrolling its
content
1) Open TableViewer Demo Application with IE 7. There are a TableViewer in
the window.
2) Scroll down the content of the TableViewer.
3) Resize the window. Set height to really big value.
Some rows that was hidden after scrolling will disappear. The vertical
scroll will be locked.
The same bug is actual for columns and horizontal scrolling.
Reproducible only in IE 7.0
6. Wrong row appearance after resizing column
the window.
2) Resize first column.
The last row will have wrong appearance. The text from the second and
third cells will
not be moved with the second and third column.
7. Header row can be "erased" when scrolling
the window.
2) Resize window. Decrease width of the window by dragging right border of
the window to the left.
3) Scroll content to the right.
Look at the header row. There is a white rectangle in the top right corner
of the TableViewer instead of
the text from header row.
8. Drop-down-list of the ComboBoxCellEditor should not be transparent for
key events
the window.
2) Activate some ComboBoxCellEditor. Open its drop-down-list;
3) Try to navigate with keys "up" and "down".
You will see that seletion in TableViewer changes when changes selection
position in drop-down-menu.
Re: List of founded bugs [message #118487 is a reply to message #118435] Thu, 15 January 2009 06:10 Go to previous messageGo to next message
Hi Igor,
thanks for your investigation. Your assumptions about known bugs are
right. Feel free to file bugs for the remaining issues. You may want
to read "RAP Bug reporting how to" afore:
http://wiki.eclipse.org/RAP_Bug_Reporting_Howto
Cheers
Rüdiger
Igor Pavlenko wrote:
> Hello
> necessary and attach my snippet.
> The second one with ComboBoxCellEditor and the last one with
> Press Enter.
> window.
> window.
> do this several times.
> double-clicking.
> not be executed.
> its content
> in the window.
> in the window.
> third cells will
> in the window.
> of the window to the left.
> corner of the TableViewer instead of
> for key events
> in the window.
Re: List of founded bugs [message #118528 is a reply to message #118487] Mon, 19 January 2009 02:26 Go to previous message
Hello
It seems, last for issues was not in official bugs list yet. I posted
those to bugzilla.
Best regards, Igor
Previous Topic:TextCellEditor in M4
Next Topic:RAP integration into WebSphere Portal
Current Time: Wed Sep 03 08:16:03 EDT 2025
Powered by FUDForum. Page generated in 0.08957 seconds
