| help with COSMOS_DG_Constructing_a_Data_Manager [message #10784] |
Thu, 03 July 2008 20:03  |
We are trying to Run our MDR in Eclipse follwing the instructions in
http://wiki.eclipse.org/COSMOS_DG_Constructing_a_Data_Manage r.
We have followed all the steps in this document. However, when I
rightclick--> run on server, I get the following message in the console :
[INFO] Trouble processing wsdl file :No service was not found in the WSDL
file:/C:/eclipse-SDK-3.4M6-win32/eclipse/.metadata/.plugins/ org.eclipse.wst.server.core/tmp0/wtpwebapps/org.eclipse.cosm os.example.mdr/WEB-INF/services/StudentTeacherSample/META-IN F/
with targetnamespace http://cmdbf.org/schema/1-0-0/query
The wsdl does not open up.
We are new to SOA, and are not sure on what is causing this error. The
service element looks like this as of now in wsdl :
<wsdl:service name="newLine">
<wsdl:port name="MfloMDRQueryService" binding="tns:QueryBinding">
<soap:address location="TO_BE_GENERATED"/>
</wsdl:port>
</wsdl:service>
Are there additional steps( in addition to those listed in the
COSMOS_DG_Constructing_a_Data_Manager) that is needed to generate the
right wsdl file?
We tried generating the wsdl automatically by setting
<parameter name="useOriginalwsdl">false</parameter>. This geneartes a
wsdl, however I am not able to access the EPR from the client.
NithyaHello,
</wsdl:port>
</wsdl:service>
right wsdl file?
Nithya
| Re: help with COSMOS_DG_Constructing_a_Data_Manager [message #11835 is a reply to message #11762] |
Thu, 13 November 2008 23:22  |
Originally posted by: david_whiteman.us.ibm.com
Hi vinesh,
Have you confirmed that you are using the latest version of the code &
the documentation? The documentation found on the wiki pages is obsolete.
David
vinesh wrote:
> I've created a Student Teacher MDR by follwing the steps provided in the
> devguide, but when I run the same it is giving tthe follwoing error in
> the console
> Trouble processing wsdl file :No service was not found in the WSDL at
> .../org.eclipse.wst.server.core/tmp0/wtpwebapps/org.eclipse. cosmos.example.mdr/WEB-INF/services/StudentTeacherSample/MET A-INF/
> How can I resovle this issue, pls let me know.
> vinesh.
| Re: help with COSMOS_DG_Constructing_a_Data_Manager [message #571560 is a reply to message #10784] |
Sat, 05 July 2008 14:22  |
Hi Nithya,
Which build of COSMOS and which version of Eclipse do you have installed?
David
Nithya wrote:
> Hello,
> http://wiki.eclipse.org/COSMOS_DG_Constructing_a_Data_Manage r We have
> followed all the steps in this document. However, when I rightclick-->
> WSDL at
> </wsdl:port>
> </wsdl:service>
> right wsdl file?
> We tried generating the wsdl automatically by setting <parameter
> name="useOriginalwsdl">false</parameter>. This geneartes a wsdl, however
> Nithya
| Re: help with COSMOS_DG_Constructing_a_Data_Manager [message #571618 is a reply to message #10831] |
Sun, 06 July 2008 07:31  |
Nithya wrote:
> Hi David,
> I am using Eclipse SDK Version: 3.4.0 and Cosmos build:
> COSMOS-1.0.0-200804270312.
I'm not the best person to help you with your specific problem, but I
would suggest you update to the 1.0 M3 stable build of COSMOS. I know
there have been quality improvements in the COSMOS SDK since the build
that you are using, and you might try building a new MDR using that
COSMOS version so that the WSDLs are generated properly for you.
David
| Re: help with COSMOS_DG_Constructing_a_Data_Manager [message #572123 is a reply to message #10784] |
Thu, 13 November 2008 19:09  |
the console
..../org.eclipse.wst.server.core/tmp0/wtpwebapps/org.eclipse .cosmos.example.mdr/WEB-INF/services/StudentTeacherSample/ME TA-INF/
vinesh.
| Re: help with COSMOS_DG_Constructing_a_Data_Manager [message #572180 is a reply to message #11762] |
Hi vinesh,
David
> the console
> vinesh.
FUDForum. Page generated in 0.06677 seconds
