Home » Language IDEs » Java Development Tools (JDT) » launching runtime workbench crashes
launching runtime workbench crashes [message #118298] Wed, 19 November 2003 10:31
WinXP, R2.1
Possibly a known bug, but I don't know what it would be called: start
debug session (runtime workspace), and get a popup error saying
"Exception occurred during launch\n\nReason:\n Error within Debug UI:"
and this in the error log:
!SESSION Nov 19, 2003 10:24:23.836
java.fullversion=J2RE 1.4.0 IBM Windows 32 build cn140-20020902 (JIT
enabled: jitc)
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/Ekleipsis/eclipse/
!ENTRY org.eclipse.debug.ui 4 120 Nov 19, 2003 10:24:23.836
!MESSAGE Error logged from Debug UI:
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:283)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:357)
at org.eclipse.debug.ui.DebugUITools.launch(DebugUITools.java:4 94)
org.eclipse.debug.internal.ui.actions.RelaunchLastAction.run (RelaunchLastAction.java:56)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:207)
org.eclipse.ui.internal.WWinKeyBindingService.pressed(WWinKe yBindingService.java:214)
org.eclipse.ui.internal.WWinKeyBindingService$5.widgetSelect ed(WWinKeyBindingService.java:332)
org.eclipse.ui.internal.AcceleratorMenu$2.handleEvent(Accele ratorMenu.java:65)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va(Compiled
Code))
Code))
Code))
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java (Compiled
Code))
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a(Compiled
Code))
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:61)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:40)
at java.lang.reflect.Method.invoke(Method.java:335)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: org.eclipse.core.internal.runtime.AssertionFailedException:
assertion failed: Model is read-only
org.eclipse.core.runtime.model.PluginModelObject.assertIsWri teable(PluginModelObject.java(Compiled
Code))
Code))
org.eclipse.core.internal.plugins.Extension.assertIsWriteabl e(Extension.java:79)
org.eclipse.core.runtime.model.ExtensionModel.setSubElements (ExtensionModel.java:151)
org.eclipse.core.internal.plugins.PluginRegistry.loadConfigu rationElements(PluginRegistry.java:311)
org.eclipse.core.internal.plugins.Extension.getSubElements(E xtension.java:69)
org.eclipse.pde.internal.core.plugin.PluginExtension.load(Pl uginExtension.java:53)
org.eclipse.pde.internal.core.plugin.PluginBase.loadExtensio ns(PluginBase.java:201)
org.eclipse.pde.internal.core.plugin.PluginBase.load(PluginB ase.java:104)
at org.eclipse.pde.internal.core.plugin.Plugin.load(Plugin.java :37)
org.eclipse.pde.internal.core.plugin.ExternalPluginModelBase .load(ExternalPluginModelBase.java:69)
org.eclipse.pde.internal.core.RegistryLoader.processPluginMo del(RegistryLoader.java:81)
org.eclipse.pde.internal.core.RegistryLoader.reloadFromLive( RegistryLoader.java:100)
org.eclipse.pde.internal.core.ExternalModelManager.loadModel s(ExternalModelManager.java:226)
org.eclipse.pde.internal.core.ExternalModelManager.<init>(ExternalModelManager.java:71)
org.eclipse.pde.internal.core.PDECore.initializeModels(PDECo re.java:323)
org.eclipse.pde.internal.core.PDECore.getWorkspaceModelManag er(PDECore.java:294)
org.eclipse.pde.internal.ui.launcher.WorkbenchLaunchConfigur ationDelegate.getWorkspacePluginsToRun(WorkbenchLaunchConfig urationDelegate.java:363)
org.eclipse.pde.internal.ui.launcher.WorkbenchSourcePathProv ider.computeUnresolvedClasspath(WorkbenchSourcePathProvider. java:83)
org.eclipse.jdt.internal.launching.RuntimeClasspathProvider. computeUnresolvedClasspath(RuntimeClasspathProvider.java:53)
org.eclipse.jdt.launching.JavaRuntime.computeUnresolvedSourc eLookupPath(JavaRuntime.java:605)
org.eclipse.jdt.launching.sourcelookup.JavaSourceLocator.ini tializeDefaults(JavaSourceLocator.java:384)
org.eclipse.jdt.debug.ui.JavaUISourceLocator.initializeDefau lts(JavaUISourceLocator.java:279)
org.eclipse.debug.internal.core.LaunchConfiguration.initiali zeSourceLocator(LaunchConfiguration.java:183)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:155)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:676)
org.eclipse.debug.ui.DebugUITools.buildAndLaunch(DebugUITool s.java:538)
at org.eclipse.debug.ui.DebugUITools$2.run(DebugUITools.java:48 7)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
Previous Topic:Help Contents: Class org/eclipse/core/runtime/Preferences
Next Topic:Quick Fix does not work - help !
Current Time: Fri Jul 25 10:22:29 EDT 2025
Powered by FUDForum. Page generated in 0.05343 seconds
