Home » Language IDEs » C / C++ IDE (CDT) » GDB crashes while debugging class templates
GDB crashes while debugging class templates [message #118275] Tue, 31 August 2004 10:02 Go to next message
Originally posted by: ebascon.hotmail.com
Hi everybody:
I do not know if this is a CDT/Mingw issue or just a Mingw issue.
I tried to debug a class template using eclipse, but I was not able to step
into a class template because the gdb crashed with the following message:
Cannot find class name: MyClassTemplate<CHAR> in RTTI.
Any suggestions or workarounds?
Ernesto
Re: GDB crashes while debugging class templates [message #118300 is a reply to message #118275] Tue, 31 August 2004 10:28 Go to previous message
Originally posted by: alain.nowhere.ca
Ernesto Bascón wrote:
> Hi everybody:
Beside firing a PR to cygwin/Mingw not really. Try a newer version
of gdb (6.x),with a new gcc compiler(3.x series). It does seem to work
better
> Ernesto
Previous Topic:CDT on Run-time Workspace
Next Topic:Command line too long
Current Time: Sat Jul 26 03:06:31 EDT 2025
Powered by FUDForum. Page generated in 0.24448 seconds
