Home » Eclipse Projects » Equinox » Deploying sample.http.war.feature
Deploying sample.http.war.feature [message #118229] Mon, 29 September 2008 09:53 Go to next message
I'm running through the instructions on "Equinox in a Servlet Container"
found at http://www.eclipse.org/equinox/server/http_in_container.php and I'm
trying to deploy the sample-http example referenced on that page. I have
been able to build and deploy the bridge.war example successfully, but I
seem to be missing some pieces on how to use that example to apply it to
sample-http. I've noticed a few other posts in the past that indicate
similar problems, but I didn't find any that clearly described a sample-http
war's relationship to the servlet bridge. Does anyone have a modified
sample-http project and war.feature that successfully deploys it? I've been
trying to use these instructions along with those found at
http://rapblog.innoopract.com/2007/12/rap-deployment-part-2- deploying-your.html
to no avail.
Any help would be much appreciated,
Scott
Re: Deploying sample.http.war.feature [message #118607 is a reply to message #118229] Mon, 29 September 2008 10:02 Go to previous messageGo to next message
This is what I have done so far. Maybe someone could point out a flaw in
how I'm approaching the problem. I've got the attached ant script in
sample.http/scripts/webappBuilder.xml and the attached feature.xml in a
separate sample.http.war.feature.
> I'm
> sample-http
> been
> to no avail.
> Scott
[Updated on: Thu, 15 January 2015 13:50] by Moderator
Re: Deploying sample.http.war.feature [message #118786 is a reply to message #118607] Wed, 01 October 2008 11:46 Go to previous message
With some help from a co-worker I've been able to fix the two projects
sample.http and sample.http.war.feature so I can generate a WAR file. To
try it out, import these projects, right-click on
sample.http/scripts/webappBuilder.xml and select "Run As > Ant Build" from
the context menu.
Scott
>> I'm
>> sample-http
>> been
>> to no avail.
>> Scott
Previous Topic:problem to load references in a p2 repository
Next Topic:Proper way to retrieve path to my log
Current Time: Sun Jul 27 12:45:44 EDT 2025
Powered by FUDForum. Page generated in 0.03986 seconds
