Customizing New Connection Wizard [message #10743] |
Wed, 13 June 2007 16:48  |
Hello!
I am in the process of researching everything that needs to be done to
create a custom RSE service. I understand how create the service itself
after looking at the SSH, FTP, and dstore implementations, but now I have
a question about UI customization for the service.
In the New Connection Wizard, which lists all available connection types,
say you select "SSH Only" and click Next. Is the following wizard page
customizable? In my case, the connection I'm creating will not have a host
name and instead the user will need to select a virtual machine.
Thanks!
Re: Customizing New Connection Wizard [message #10806 is a reply to message #10775] |
Thu, 14 June 2007 07:37  |
Hi Troy,
> I see from the post "How to open a new connection wizard for a particular
> system type?" that it is indeed possible to customize the new connection
> wizard.
> Are there any example classes in the RSE source tree that customize the
> new connection wizard? My searches have come up empty.
The extension point you are looking for is
org.eclipse.ui.newConnectionWizards. The plugin org.eclipse.rse.discovery
contains a example of contributing a wizard for a specific system type. See
the extension point documentation for details on the extension point
attributes.
Best regads, Uwe
Uwe Stieber, Member of Technical Staff - Sys, Wind River
Re: Customizing New Connection Wizard [message #568286 is a reply to message #10743] |
Wed, 13 June 2007 18:04  |
wizard.
Thanks!
Troy
Re: Customizing New Connection Wizard [message #568304 is a reply to message #10775] |
Hi Troy,
> wizard.
attributes.
Best regads, Uwe
FUDForum. Page generated in 0.04394 seconds
