Home » Archived » BIRT » Scripted data set for Chart
Scripted data set for Chart [message #117804] Thu, 26 January 2006 13:32 Go to next message
Originally posted by: mlorenz.nc.rr.com
I can't find an example of using a scripted data set for a Chart. Does
one exist?
Re: Scripted data set for Chart - Anyone?? [message #118100 is a reply to message #117804] Thu, 26 January 2006 16:07 Go to previous messageGo to next message
Has anyone used a scripted data set with a Chart? If so, can you share
details? My charts are not working correctly and I don't see why.
I also get some strange errors when editing the chart that seem to be
related to my data set that it is bound to:
save in error
C:\Documents and Settings\lorenz\Local
Settings\Temp\BirtDataCache\session_0\metaData.data (The system cannot
find the
file specified)
at:
org.eclipse.birt.data.engine.executor.dscache.DataSetResultC ache$LoadUtil.init(DataSetResultCache.java:448)
org.eclipse.birt.data.engine.executor.dscache.DataSetResultC ache$LoadUtil.loadResultClass(DataSetResultCache.java:421)
org.eclipse.birt.data.engine.executor.dscache.DataSetResultC ache.loadResultClass(DataSetResultCache.java:237)
org.eclipse.birt.data.engine.executor.dscache.DataSetResultC ache.getResultClass(DataSetResultCache.java:170)
Re: Scripted data set for Chart - Anyone?? [message #118518 is a reply to message #118100] Fri, 27 January 2006 06:26 Go to previous messageGo to next message
Please check bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=124721 .
This looks very similar to your problem.
No there is no scripted dataset example available for chart. We'll try to
add one.
David
"Mark Lorenz" <mlorenz@nc.rr.com> wrote in message
news:4a5b051663a6f306e8b576b27d96ed0f$1@www.eclipse.org...
> save in error
> find the
> file specified)
> at:
Re: Scripted data set for Chart - David [message #118746 is a reply to message #118518] Fri, 27 January 2006 09:20 Go to previous messageGo to next message
Is it possible to get any example now? You must have used scripted data
set at some time for Chart testing... Doesn't have to be "documented"
Re: Scripted data set for Chart - David [message #118773 is a reply to message #118746] Fri, 27 January 2006 09:24 Go to previous messageGo to next message
Hi Mark,
I have an old example, I think it should be updated, but there you are.
David
news:4778b281982e4688905548103e9d1f35$1@www.eclipse.org...
Re: Scripted data set for Chart - David [message #118873 is a reply to message #118773] Fri, 27 January 2006 11:15 Go to previous messageGo to next message
Thanks David. Now, another favor - I only have web view into newsgroup,
so attachments are not usable. Can you resend to my email:
lorenzm@labcorp.com
Thanks again...Mark
Re: Scripted data set for Chart - David? [message #119198 is a reply to message #118873] Fri, 27 January 2006 15:50 Go to previous messageGo to next message
so attachments are not usable. Can you resend to my email?
Re: Scripted data set for Chart - David? [message #119365 is a reply to message #119198] Sat, 28 January 2006 05:28 Go to previous messageGo to next message
I sent it to your email, did you get it?
David
news:60a4d56ba15efc9f9f917bbf641359e0$1@www.eclipse.org...
Re: Scripted data set for Chart - David? [message #119903 is a reply to message #119365] Mon, 30 January 2006 10:16 Go to previous messageGo to next message
I got it now...I had not - it was filtered out. I got with my local
support they let it through.
Thanks a lot for following up - companies have gotten so focused on
getting rid of spam and keeping viruses out that unfortunately it is
sometimes difficult to get the real work done!
Mark
Re: Scripted data set for Chart - Anyone?? [message #151951 is a reply to message #118100] Fri, 07 April 2006 10:36 Go to previous message
Originally posted by: jeanmoura.gmail.com
Any luck with the BirtDataCache problem?
Previous Topic:Java collection data set
Next Topic:frameset problem
Current Time: Sat Nov 15 12:42:18 EST 2025
Powered by FUDForum. Page generated in 0.85001 seconds
