Home » Language IDEs » ServerTools (WTP) » [WTP0.7M5] Server Explorer vs. MySQL 4.1
[WTP0.7M5] Server Explorer vs. MySQL 4.1 [message #117753] Thu, 07 July 2005 17:04 Go to next message
Originally posted by: jens.ja-web.de
I tried the server explorer view but it does not like my local MySQL 4.1
database instance.
The connection setup seems fine.
I can open the created Connection without errors.
I can open a SQL Scrapbook and execute queries against the choosen database.
The Server explorer shows a Tree of server, schema, database, elements
for the open connection but it does not show any entries in the Folder
"Tables" or "Views"
When I try to open the "Tables" Folder I get an exeption that starts like
java.sql.SQLException: Column 'Type' not found.
at com.mysql.jdbc.ResultSet.findColumn(ResultSet.java:910)
at com.mysql.jdbc.ResultSet.getString(ResultSet.java:4942)
org.eclipse.wst.rdb.internal.core.connection.ResultSetAdapte r.getString(ResultSetAdapter.java:255)
org.eclipse.wst.rdb.internal.mysql.catalog.MySqlCatalogSchem a.loadTables(MySqlCatalogSchema.java:93)
org.eclipse.wst.rdb.internal.mysql.catalog.MySqlCatalogSchem a.getTables(MySqlCatalogSchema.java:57)
org.eclipse.wst.rdb.internal.core.containment.SchemaContainm entProvider.getContainedElements(SchemaContainmentProvider.j ava:25)
driver for the connection is mysql-connector-java-3.1.10-bin.jar
any ideas what's wrong here?
Jens
Re: [WTP0.7M5] Server Explorer vs. MySQL 4.1 [message #117900 is a reply to message #117753] Fri, 08 July 2005 06:09 Go to previous messageGo to next message
Originally posted by: ossipetz.myrealbox.com
> database instance.
you probably updated your db from an earlier version?
if so you must follow the update instructions from 4.0 to 4.1 since this
table changed. there is a tool which 'repairs' theses tables if this is
the case but i dont remember. but its in the update instructions :)
good luck!
Re: [WTP0.7M5] Server Explorer vs. MySQL 4.1 [message #120413 is a reply to message #117753] Wed, 13 July 2005 05:07 Go to previous message
Hi Jens,
I get the same exception like you when I click to see the db-tables. The
connection to the db is made correctly. I use MYSQL 4.1 and WTP 1.0M5. I
didn't upgrade from MYSQL 4.0. Did you resolve the problem? Please let me
know!
Matthias
"Jens Ansorg" <jens@ja-web.de> schrieb im Newsbeitrag
news:dak5d5$ld7$1@news.eclipse.org...
> database instance.
database.
> "Tables" or "Views"
> at
> at
> at
> at
ontainedElements(SchemaContainmentProvider.java:25)
> Jens
Previous Topic:Hang's on build new Projekt
Next Topic:problem with tomcat on eclipse 3.1
Current Time: Sun Jul 27 04:26:20 EDT 2025
Powered by FUDForum. Page generated in 0.04836 seconds
