Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Compare] Problem with getting RemoteRemoveModelElement vs. RemoteAddModelElement with 3 way compare
[Compare] Problem with getting RemoteRemoveModelElement vs. RemoteAddModelElement with 3 way compare [message #117536] |
Wed, 09 April 2008 16:40  |
I'm doing a 3 way headless comparison (match+diff). In my test, the
ancestor has no children, the "left" model has a new child and the
"right" model has a new (also different) child. These two new children
show up through the match as "UnMatchedElements" which I believe is
correct.
However, when I run the Diff, the unmatched element on the "left" shows
up as a "RemoteRemoveModelElement" instead of a "RemoteAddModelElement"
whereas the "right" element shows up correctly as a "AddModelElement".
This seems like a bug, though I may be missing something.
I've put the serialization of the match and the diff below. Please let
me know if there's more information that would help or if there's
something like a 'snippet' I can modify to show the problem. I am
running against HEAD from CVS for emf compare and Eclipse 3.4 M6.
Matt
Match Model:
<?xml version="1.0" encoding="Cp1252"?>
<match:MatchModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:match="http://www.eclipse.org/emf/compare/match/1.1"
leftModel="/objects/org.example.model.impl.AllObjectsContainedImpl@1487217"
rightModel="/objects/org.example.model.impl.AllObjectsContainedImpl@13a46b6"
originModel="/objects/org.example.model.impl.AllObjectsContainedImpl@65dbe8">
<matchedElements xsi:type="match:Match3Element"
similarity="0.8777120315581853">
<leftElement
href="/objects/org.example.model.impl.AllObjectsContainedImpl@1487217#/"/>
<rightElement
href="/objects/org.example.model.impl.AllObjectsContainedImpl@13a46b6#/"/>
<originElement
href="/objects/org.example.model.impl.AllObjectsContainedImpl@65dbe8#/"/>
</matchedElements>
<unMatchedElements xsi:type="match:RemoteUnMatchElement">
<element
href="/objects/org.example.model.impl.AllObjectsContainedImpl@1487217#RemoteAdd"/>
</unMatchedElements>
<unMatchedElements>
<element
href="/objects/org.example.model.impl.AllObjectsContainedImpl@13a46b6#LocalAdd"/>
</match:MatchModel>
Diff Model:
<diff:DiffModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:diff="http://www.eclipse.org/emf/compare/diff/1.1"
left="/objects/org.example.model.impl.AllObjectsContainedImpl@1487217"
origin="/objects/org.example.model.impl.AllObjectsContainedImpl@65dbe8"
right="/objects/org.example.model.impl.AllObjectsContainedImpl@13a46b6">
<ownedElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:AddModelElement">
<leftParent
<rightElement
</subDiffElements>
<subDiffElements xsi:type="diff:RemoteRemoveModelElement">
<leftParent
<rightElement
</subDiffElements>
<leftParent
</subDiffElements>
</ownedElements>
</diff:DiffModel>
Code snippet that runs the match/diff:
HashMap<String, Object> options = new HashMap<String, Object>();
GenericMatchEngine genericMatch = new GenericMatchEngine();
MatchModel match = genericMatch.resourceMatch(modelLeft.eResource(),
modelRight.eResource(), modelAncestor.eResource(),
options);
GenericDiffEngine diffEngine = new GenericDiffEngine();
final DiffModel diff = diffEngine.doDiff(match, true);
Re: [Compare] Problem with getting RemoteRemoveModelElement vs. RemoteAddModelElement with 3 way com [message #117554 is a reply to message #117536] |
Wed, 09 April 2008 17:34   |
While debugging through the code I found what may be the issue, it seems
in the GenericDiffEngine 'leftModel' is being left null instead of being
set to the "left" resource.
See: GenericDiffEngine->doDiffThreeWay (line 536).
At least for my case, changing lines 535 (changed 'toString' to 'path')
and 536 (added a 'getElement' call) seemed to fix the issue. The patch
is below.
If someone else can confirm this is a bug, I can follow up and file a
bugzilla.
Matt
### Eclipse Workspace Patch 1.0
#P org.eclipse.emf.compare.diff
Index: src/org/eclipse/emf/compare/diff/engine/GenericDiffEngine.ja va
RCS file:
/cvsroot/modeling/org.eclipse.emf/org.eclipse.emf.compare/pl ugins/org.eclipse.emf.compare.diff/src/org/eclipse/emf/compa re/diff/engine/GenericDiffEngine.java,v
retrieving revision 1.9
diff -u -r1.9 GenericDiffEngine.java
--- src/org/eclipse/emf/compare/diff/engine/GenericDiffEngine.ja va 3 Apr
2008 12:07:44 -0000 1.9
+++ src/org/eclipse/emf/compare/diff/engine/GenericDiffEngine.ja va 9 Apr
2008 21:18:39 -0000
@@ -532,8 +532,8 @@
// seeks left resource
Resource leftModel = null;
for (UnMatchElement element : unMatchedElements.keySet()) {
- if
(element.getElement().eResource().getURI().toString().equals (match.getLeftModel()))
- leftModel = element.eResource();
+ if
(element.getElement().eResource().getURI().path().equals(mat ch.getLeftModel()))
+ leftModel = element.getElement().eResource();
break;
> correct.
> Matt
> Match Model:
> <leftElement
> <rightElement
> <originElement
> </matchedElements>
> <element
> <unMatchedElements>
> <element
> </match:MatchModel>
> Diff Model:
> <leftParent
> <rightElement
> </subDiffElements>
> <leftParent
> <rightElement
> </subDiffElements>
> <leftParent
> </subDiffElements>
> </ownedElements>
> </diff:DiffModel>
> options);
Re: [Compare] Problem with getting RemoteRemoveModelElement vs. RemoteAddModelElement with 3 way com [message #117683 is a reply to message #117609] |
Thu, 10 April 2008 12:38  |
I created a bug for this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226565
Matt
laurent Goubet wrote:
> Matt,
> This indeed seems to be a bug I may have introduced when last
> refactoring the generic engine. I'll apply this patch after testing a
> little further.
> Thanks for the feedback.
> Laurent Goubet
> Obeo
>> seems in the GenericDiffEngine 'leftModel' is being left null instead
>> of being set to the "left" resource.
>> 'path') and 536 (added a 'getElement' call) seemed to fix the issue.
>> The patch is below.
>> bugzilla.
>> Thanks,
>> Matt
>> RCS file:
>> 3 Apr 2008 12:07:44 -0000 1.9
>> 9 Apr 2008 21:18:39 -0000
>> @@ -532,8 +532,8 @@
>> - if
>> + if
>> break;
>>> children show up through the match as "UnMatchedElements" which I
>>> believe is correct.
>>> shows up as a "RemoteRemoveModelElement" instead of a
>>> "RemoteAddModelElement" whereas the "right" element shows up
>>> correctly as a "AddModelElement". This seems like a bug, though I may
>>> let me know if there's more information that would help or if there's
>>> Thanks,
>>> Matt
>>> Match Model:
>>> <leftElement
>>> <rightElement
>>> <originElement
>>> </matchedElements>
>>> <element
>>> <unMatchedElements>
>>> <element
>>> </match:MatchModel>
>>> Diff Model:
>>> <leftParent
>>> <rightElement
>>> </subDiffElements>
>>> <leftParent
>>> <rightElement
>>> </subDiffElements>
>>> <leftParent
>>> </subDiffElements>
>>> </ownedElements>
>>> </diff:DiffModel>
>>> options);
Re: [Compare] Problem with getting RemoteRemoveModelElement vs. RemoteAddModelElement with 3 way com [message #616167 is a reply to message #117536] |
is below.
bugzilla.
Matt
RCS file:
2008 21:18:39 -0000
@@ -532,8 +532,8 @@
- if
+ if
break;
> correct.
> Matt
> Match Model:
> <leftElement
> <rightElement
> <originElement
> </matchedElements>
> <element
> <unMatchedElements>
> <element
> </match:MatchModel>
> Diff Model:
> <leftParent
> <rightElement
> </subDiffElements>
> <leftParent
> <rightElement
> </subDiffElements>
> <leftParent
> </subDiffElements>
> </ownedElements>
> </diff:DiffModel>
> options);
Re: [Compare] Problem with getting RemoteRemoveModelElement vs. RemoteAddModelElement with 3 way com [message #616186 is a reply to message #117609] |
Matt
> Matt,
> little further.
> Laurent Goubet
> Obeo
>> The patch is below.
>> bugzilla.
>> Thanks,
>> Matt
>> RCS file:
>> @@ -532,8 +532,8 @@
>> - if
>> + if
>> break;
>>> believe is correct.
>>> Thanks,
>>> Matt
>>> Match Model:
>>> <leftElement
>>> <rightElement
>>> <originElement
>>> </matchedElements>
>>> <element
>>> <unMatchedElements>
>>> <element
>>> </match:MatchModel>
>>> Diff Model:
>>> <leftParent
>>> <rightElement
>>> </subDiffElements>
>>> <leftParent
>>> <rightElement
>>> </subDiffElements>
>>> <leftParent
>>> </subDiffElements>
>>> </ownedElements>
>>> </diff:DiffModel>
>>> options);
Current Time: Fri Jul 25 00:42:38 EDT 2025
Powered by FUDForum. Page generated in 0.28149 seconds
