Home » Archived » BIRT » Engine logger
Engine logger [message #117518] Thu, 26 January 2006 09:04 Go to next message
Originally posted by: jan.tanis.coas.com
Hi All,
I've adjusted the example java class that calls the report engine, but i
noticed that it logs loads of information. Is there a way to avoid this
logging in a "quite" way, or actually *NONE* logging. How do I disable
logging from the engine?
Thanks, Jan.
Re: Engine logger [message #117711 is a reply to message #117518] Thu, 26 January 2006 12:41 Go to previous messageGo to next message
Jan Tanis wrote:
> Hi All,
> Thanks, Jan.
Check out EngineConfig.setLogConfig() function.
public void setLogConfig(String directoryName, Level level)
Level is a class defined by java.util.logging package.
Stanley Wang
BIRT Engine
Re: Engine logger [message #118446 is a reply to message #117711] Fri, 27 January 2006 03:46 Go to previous message
Thanks Stanley,
That works just fine :)
Best regards, Jan.
Stanley Wang wrote:
> Jan Tanis wrote:
>> Hi All,
>> i noticed that it logs loads of information. Is there a way to avoid
>> this logging in a "quite" way, or actually *NONE* logging. How do I
>> disable logging from the engine?
>> Thanks, Jan.
> Stanley Wang
> BIRT Engine
Previous Topic:Eclipse, BIRT, Oracle data set exception
Next Topic:no-break space and fonts
Current Time: Sun Jul 27 08:47:00 EDT 2025
Powered by FUDForum. Page generated in 0.04085 seconds
