Home » Eclipse Projects » GEF » Placing child edit part on contents edit part.
Placing child edit part on contents edit part. [message #117348] Thu, 12 February 2004 11:50 Go to next message
Originally posted by: bharath.starthis.com
I am trying to place a child edit part on my contents edit part but the
edit part's visual (defined using figure.java) gets placed on the top left
corner of the screen. I believe it has to do with the
setLayoutConstraint() method or the validate() method in figure.java, but
I am not sure.
In other words, if i click on an entry in my palette to add a visual
(rectangle, in my case), the rectangle appears on the screen but shows up
in the top left corner and not on the position where I place it. It also
hides the border of the layout.
Thanks in advance!
Re: Placing child edit part on contents edit part. [message #117376 is a reply to message #117348] Thu, 12 February 2004 13:06 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Bharath wrote:
| Hi,
| I am not sure.
| Thanks in advance!
sounds like you are using the wrong layout manager. what is the type of
the edit part you are adding a child too?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAK8ClVbJM14DSCi0RAr3WAJ0bWpe/BG6qZDAooyIJVK31UfDjQACg y3VF
4FLf+wd+MtucY8kg7K6Q1Xk=
=K6dI
-----END PGP SIGNATURE-----
Re: Placing child edit part on contents edit part. [message #117414 is a reply to message #117376] Thu, 12 February 2004 13:16 Go to previous messageGo to next message
Hi Gilbert,
I fixed the problem by removing the connection edit part (which I call
'link') between this edit part and another edit part. I have two different
edit parts (source, target) which have to connected by an edge and I need
a separate edit part for the edge itself. In that case, for the source
edit part, I return "null" for the getconnectioncompletecommand() because
it is ONLY a source and connections ONLY ORIGINATE from it. However, this
logic gives me problems. Am I thinking in the right direction?
Thanks for your reply.
> Hash: SHA1
> Bharath wrote:
> | Hi,
> | I am not sure.
> | Thanks in advance!
> Respectfully,
> CL Gilbert
> =K6dI
Re: Placing child edit part on contents edit part. [message #117929 is a reply to message #117414] Tue, 17 February 2004 00:04 Go to previous message
Hash: SHA1
Bharath wrote:
| Hi Gilbert,
you should never return null. if connections only originate from it,
somehow have the connection action determine wether or not it is safe to
start a connection from that part. If its that part, the connection
action should reject the connection start.
Respectfully,
CL Gilbert
iD8DBQFAMaDaVbJM14DSCi0RAuESAKDTR3ktEjTJ9+5ZfKjqILsnWhN1ugCd GPXD
/aBllUCGKrM0YZ1ps+yT9kM=
=+DVw
Previous Topic:My Figures cannot move....
Next Topic:Container EditPart.
Current Time: Sun Aug 31 13:16:45 EDT 2025
Powered by FUDForum. Page generated in 0.09718 seconds
