| tooltips don't show correctly on resource editors? (+ how to move between editors) [message #117229] |
Sat, 15 November 2003 12:56  |
Hi, If I have several editors open at once.. the headers get crunched
like so:
Ab.[]|Ca[]|Ab.[]|Ab.[]|Ca[]|Ab.[]|
where the | indicate the tab boundaries.. is there anyway to get Eclipse
to show in the tooltips the full name when I mouse over the header? (Is
there also a buffer-list a-la emacs which shows all the resource editors
opened, say alphabetically, or in the order opened, and would allow me
to select it).
I also miss c-x b, or c-m l.. (say you are editing in a file, and you
click "go to declaration" on some other class's method -- is there a way
to "get back to where you were"..)?
Thanks.
| Re: tooltips don't show correctly on resource editors? (+ how to move between editors) [message #117456 is a reply to message #117229] |
Mon, 17 November 2003 02:51   |
Works for me in M4.
(Additionally, you can configure the workbench to autoclose editors on a
LRU basis, see Prefs, Workbench->Editors. This will avoid your tabs
getting too narrow).
> (Is
> to select it).
Try Ctrl+Shift+W (or configure your own key binding for it) for a
dialog, or use Ctrl+(Shift+)F6 for a lightweight chooser.
Use "Go back / forward" (Alt+ARROW_LEFT / RIGHT) to navigate locations.
HTH
-tom
| Re: tooltips don't show correctly on resource editors? (+ how to move between editors) [message #117574 is a reply to message #117456] |
Mon, 17 November 2003 09:08  |
Thanks Tom. I'm using WSAD -- so may be the version of eclipse in there
broke the tooltips.
Thanks for the tips.
> Works for me in M4.
>> (Is
>> to select it).
> HTH
> -tom
FUDForum. Page generated in 0.06535 seconds
