Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #117224] |
Sat, 27 December 2008 12:29  |
Hi, since last CVS update I'm getting this Exception and I don't what is
wrong. I think, I don't made any change on my code.
Can anybody explain this?
Roland
java.lang.IllegalArgumentException: Undefined key: 'text.SINGLE.padding'
at org.eclipse.rwt.internal.theme.Theme.getValue(Theme.java:257 )
at org.eclipse.rwt.internal.theme.Theme.getValue(Theme.java:229 )
org.eclipse.rwt.internal.theme.AppearancesUtil.substituteMac ros(AppearancesUtil.java:55)
org.eclipse.rwt.internal.theme.ThemeManager.createAppearance Theme(ThemeManager.java:966)
org.eclipse.rwt.internal.theme.ThemeManager.registerThemeFil es(ThemeManager.java:758)
org.eclipse.rwt.internal.theme.ThemeManager.registerResource s(ThemeManager.java:407)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.write Libraries(DisplayLCA.java:297)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCAFacade Impl.writeLibrariesInternal(DisplayLCAFacadeImpl.java:33)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCAFacade .writeLibraries(DisplayLCAFacade.java:36)
org.eclipse.rwt.internal.lifecycle.DisplayUtil.writeLibrarie s(DisplayUtil.java:66)
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getLibraries(LifeCycleServiceHandlerConfigurer.java:2 01)
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getTemplateOfStartupPage(LifeCycleServiceHandlerConfi gurer.java:61)
org.eclipse.rwt.internal.service.BrowserSurvey.renderScript( BrowserSurvey.java:89)
org.eclipse.rwt.internal.service.BrowserSurvey.sendBrowserSu rvey(BrowserSurvey.java:50)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:197)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:185)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:150)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:46 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.service(RWTLifeCycleServiceHandlerSync.java:34)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.ser vice(LifeCycleServiceHandler.java:157)
org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:101)
at org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:63)
org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:51)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118394 is a reply to message #118386] |
Tue, 13 January 2009 08:36   |
New Yop Javeloper wrote:
> Hi & thank you!
> I took a look to the upload widget source especially the *.js sources
> and I found what was the error.
> There's an error en the
> org.eclipse.rwt.widgets.internal.uploadkit.Upload.appearance s.js file.
> We have in the source code :
> return {
> padding :THEME_VALUE("text.SINGLE.padding"),
This is indeed an outdated version. The current version of this file reads:
"upload-field" : {
style : function( states ) {
var tv = new org.eclipse.swt.theme.ThemeValues( states );
return {
border : tv.getCssBorder( "Text", "border" ),
font : tv.getCssFont( "Text", "font" ),
padding : tv.getCssBoxDimensions( "Text", "padding" ),
textColor : states.disabled
? tv.getColor( "widget.graytext" )
: tv.getCssColor( "Text", "color" ),
backgroundColor : tv.getCssColor( "Text", "background-color" )
> that sould be replaced by :
> return {
> padding :THEME_VALUE('text.SINGLE.padding'),
No, it should not. You should get the actual version from CVS like Ivan
advised 5 postings before.
> It was just a simple quotes matter, doubles ones in the source having to
> be replaced by single one.
> I now have no error at lauching time but when seeked the upload wigets
> brings new problem that is explained here :
> http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg04480.html
> *.js files are not delivered to the client. I'm now learning more.
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118408 is a reply to message #118394] |
Tue, 13 January 2009 11:27   |
Yes everything works fine now!
it's just this psf file that brang the pain:
<psf version="2.0">
<provider id="org.eclipse.team.cvs.core.cvsnature">
<project
reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/tools,org.eclipse.orbit/org.apache.commons.fileupl oad,org.apache.commons.fileupload,v1_2 "/>
<project
reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/tools,org.eclipse.orbit/org.apache.commons.io,org. apache.commons.io,v1_3_2 "/>
<project
reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,org.eclipse.rap/sandbox/org.eclipse.rwt .widgets.upload,org.eclipse.rwt.widgets.upload "/>
<project
reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,org.eclipse.rap/sandbox/org.eclipse.rwt .widgets.upload.demo,org.eclipse.rwt.widgets.upload.demo "/>
</provider>
</psf>
Thank You All!
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118414 is a reply to message #118408] |
Tue, 13 January 2009 12:39   |
thanks for pointing this out. I updated the psf file.
Regards, Ralf
> <psf version="2.0">
> <project
> <project
> <project
> <project
> </provider>
> </psf>
> Thank You All!
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #119371 is a reply to message #118428] |
Fri, 23 January 2009 05:43  |
I agree with Andreas. Furthemore is there any plan to include the upload
widget in the rap project ?
Emmanuel
> Hi Ralf,
> to prevent further problems with the outdated upload widget, maybe the old
> code at cvsroot/technology should be removed.
> Your new *.psf file and a README with a comment could be placed instead.
> The same problem occured also for me and it works now with the new CVS
> location.
> Andreas
FUDForum. Page generated in 0.08976 seconds
