Home » Language IDEs » PHP Development Tools (PDT) » group indent with spaces
group indent with spaces [message #10689] Fri, 30 March 2007 09:28 Go to next message
Even with the "Indent using spaces" option, indenting multiple lines with
the tab key still uses tabs instead of spaces.
Single line indentation works fine.
Is there some other option to fix this? I tried all versions (20070214
upto the latest head).
Re: group indent with spaces [message #10754 is a reply to message #10689] Fri, 30 March 2007 10:29 Go to previous messageGo to next message
I have this problem too.
PDT - Nightly build (N20070325)
Eclipse (3.2.2r322_v20070104)
Windows XP
-Joshua-
"R. L. Bekkema" <rl.bekkema@gmail.com> wrote in message
news:75249e8587b42c958e3255d66233dc96$1@www.eclipse.org...
Re: group indent with spaces [message #10786 is a reply to message #10754] Fri, 30 March 2007 12:47 Go to previous messageGo to next message
Originally posted by: dominic.clifton.gr-tech.net
Has anyone opened a bug report for this? Either one of you two should do it
so that this doesn't get forgetten.
Dom
"Joshua Ross" <joshualross@gmail.com> wrote in message
news:euj6ms$ko2$1@build.eclipse.org...
> Windows XP
> -Joshua-
Re: group indent with spaces [message #11925 is a reply to message #10786] Sat, 31 March 2007 13:34 Go to previous messageGo to next message
Done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180357
-Joshua-
"Dominic Clifton" <dominic.clifton@gr-tech.net> wrote in message
news:eujevo$uo7$1@build.eclipse.org...
> it so that this doesn't get forgetten.
> Dom
>> Windows XP
>> -Joshua-
>>> with the tab key still uses tabs instead of spaces.
Re: group indent with spaces [message #541884 is a reply to message #10689] Tue, 22 June 2010 18:29 Go to previous message
Looks like this had already been reported (5 times). For some reason, though, the original ticket has been closed as WON'T FIX.
Too bad, it would be nice if this worked correctly.
Previous Topic:Debugging stopped working
Next Topic:Multiline / Block Search and Replace Project wide
Current Time: Tue Jul 22 01:49:26 EDT 2025
Powered by FUDForum. Page generated in 0.05432 seconds
