Update Eclipse SDK using local files [message #117170] |
Wed, 27 August 2003 07:04  |
Is it possible to update the Eclipse SDK through the Update Manager
using locally downloaded newer version? More specifically I want to
update 2.1 to 2.1.1 and I've downloaded the 2.1.1 distribution
locally. I've some other third-party features installed which I
don't want to re-install if I go with a fresh 2.1.1 distribution.
Stanimir
Re: Update Eclipse SDK using local files [message #119032 is a reply to message #118944] |
Thu, 28 August 2003 16:19  |
Or use a tool to mirror features from update site.
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -update-home/doc/working/documentation/standalone_update.htm l
(at the bottom) describes how to use it (pass -command mirror).
Konrad Kolosowski
"Chris Laffra" <Chris_Laffra@oti.com> wrote in message
news:bili9c$se6$1@eclipse.org...
> You can open the site.xml with a browser and download it your machine,
> and then install the features from a local network?
> Open this in your browser and save locally:
> http://update.eclipse.org/updates/site.xml
> Then download the referenced features and plugins also, save them in
> the right location. Major puzzle. I admit.
> If you do this often and your organization is big enough, you may want to
> set
> up an internal mirror of eclipse.org. See:
> http://download.eclipse.org/downloads/mirrors/index.html
> Chris Laffra
> "Thierry Lach" <thierry.lach@bbdodetroit.com> wrote in message
> news:bilh0j$qpp$1@eclipse.org...
> > Having a snapshot of the update site would be a nice convenience - we've
> got
> > firewall issues that make it almost impossible for a java-based program
to
> > get through using http.
> > news:biius7$7je$1@eclipse.org...
> > > Update manager needs site.xml files to decribe the features to update.
> > > If there are any in the distribution you downloaded, you can locate
them
> > > with the Update Manager.
> > > Otherwise, you have to manual installation by copying your features
and
> > > plugins
> > > from 2.1 to 2.0.
> > > Chris
> > > "Stanimir Stamenkov" <stanio@yahoo.com> wrote in message
> > > news:biihja$nnk$1@eclipse.org...
> > > > dorian birsan wrote:
> > > > > I think you could have used the Update Manager to update your 2.1
> > > directly,
> > > > > without you having to download the zip file.
> > > > > I think it is also relatively safe to just unzip the new 2.1.1 on
> top
> > of
> > > > > your 2.1 install.
> > > > I have pretty slow dial-up connection that's why I prefer to
> > > > download the whole package to have it locally for further use.
> > > > Anyway, thank you for your reply, Dorian.
> > > > Stanimir
FUDForum. Page generated in 0.27701 seconds
