Home » Eclipse Projects » Eclipse Platform » Update Eclipse SDK using local files
Update Eclipse SDK using local files [message #117170] Wed, 27 August 2003 07:04 Go to next message
Is it possible to update the Eclipse SDK through the Update Manager
using locally downloaded newer version? More specifically I want to
update 2.1 to 2.1.1 and I've downloaded the 2.1.1 distribution
locally. I've some other third-party features installed which I
don't want to re-install if I go with a fresh 2.1.1 distribution.
Stanimir
Re: Update Eclipse SDK using local files [message #117222 is a reply to message #117170] Wed, 27 August 2003 09:34 Go to previous messageGo to next message
Originally posted by: dorian.birsan.net
I think you could have used the Update Manager to update your 2.1 directly,
without you having to download the zip file.
I think it is also relatively safe to just unzip the new 2.1.1 on top of
your 2.1 install.
-Dorian
"Stanimir Stamenkov" <stanio@yahoo.com> wrote in message
news:bii36o$7mj$1@eclipse.org...
> Stanimir
Re: Update Eclipse SDK using local files [message #117330 is a reply to message #117222] Wed, 27 August 2003 11:10 Go to previous messageGo to next message
> your 2.1 install.
I have pretty slow dial-up connection that's why I prefer to
download the whole package to have it locally for further use.
Anyway, thank you for your reply, Dorian.
Stanimir
Re: Update Eclipse SDK using local files [message #117509 is a reply to message #117330] Wed, 27 August 2003 14:56 Go to previous messageGo to next message
Update manager needs site.xml files to decribe the features to update.
If there are any in the distribution you downloaded, you can locate them
with the Update Manager.
Otherwise, you have to manual installation by copying your features and
plugins
from 2.1 to 2.0.
Chris
news:biihja$nnk$1@eclipse.org...
directly,
> > your 2.1 install.
> Stanimir
Re: Update Eclipse SDK using local files [message #117802 is a reply to message #117509] Thu, 28 August 2003 02:59 Go to previous messageGo to next message
> plugins
> from 2.1 to 2.0.
Thank you, Chris. Seems this is the info I've needed. There's no
"site.xml" in the zipped builds so will have to do a manual
installation again.
Stanimir
Re: Update Eclipse SDK using local files [message #118933 is a reply to message #117509] Thu, 28 August 2003 14:18 Go to previous messageGo to next message
Having a snapshot of the update site would be a nice convenience - we've got
firewall issues that make it almost impossible for a java-based program to
get through using http.
"Chris Laffra" <Chris_Laffra@oti.com> wrote in message
news:biius7$7je$1@eclipse.org...
> plugins
> from 2.1 to 2.0.
> Chris
> directly,
of
> > > your 2.1 install.
> > Stanimir
Re: Update Eclipse SDK using local files [message #118944 is a reply to message #118933] Thu, 28 August 2003 14:39 Go to previous messageGo to next message
You can open the site.xml with a browser and download it your machine,
and then install the features from a local network?
Open this in your browser and save locally:
http://update.eclipse.org/updates/site.xml
Then download the referenced features and plugins also, save them in
the right location. Major puzzle. I admit.
If you do this often and your organization is big enough, you may want to
set
up an internal mirror of eclipse.org. See:
http://download.eclipse.org/downloads/mirrors/index.html
Chris Laffra
"Thierry Lach" <thierry.lach@bbdodetroit.com> wrote in message
news:bilh0j$qpp$1@eclipse.org...
got
> > plugins
> > from 2.1 to 2.0.
> > Chris
> > directly,
top
> of
> > > > your 2.1 install.
> > > Stanimir
Re: Update Eclipse SDK using local files [message #119032 is a reply to message #118944] Thu, 28 August 2003 16:19 Go to previous message
Or use a tool to mirror features from update site.
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -update-home/doc/working/documentation/standalone_update.htm l
(at the bottom) describes how to use it (pass -command mirror).
Konrad Kolosowski
news:bili9c$se6$1@eclipse.org...
> set
> Chris Laffra
> got
to
them
and
> > > plugins
> > > from 2.1 to 2.0.
> > > Chris
> > > directly,
> top
> > of
> > > > > your 2.1 install.
> > > > Stanimir
Previous Topic:accessing the message area?
Next Topic:Context-sensitive usage of the global save menu item
Current Time: Sat Nov 08 23:55:04 EST 2025
Powered by FUDForum. Page generated in 0.05218 seconds
