Restricitions about bmp files [message #117169] |
Wed, 08 February 2006 12:53  |
Originally posted by: alexandre.gzsistemas.com.br
--------------030808080602090902020709
What could be the restrictions to make some of my bmp to be considered
invalid images when I try to select them into a button in a toolbar ?
Attached are two of my bmp, one is considered valid and another invalid.
Thank you very much.
Content-Type: image/bmp;
name="valid.bmp"
Content-Disposition: inline;
filename="valid.bmp"
Qk1CAQAAAAAAAHYAAAAoAAAAEQAAABEAAAABAAQAAAAAAMwAAAAAAAAAAAAA ABAAAAAQAAAA
AAAAAAAAvwAAvwAAAL+/AL8AAAC/AL8Av78AAMDAwACAgIAAAAD/AAD/AAAA //8A/wAAAP8A
/wD//wAA////AN3d3d3d3d3d0AAAAN3d3d3d3d3d0AAAAN3d3d3d3d3d0AAA ANAAAAAAAAAA
0AAAAND////////w0AAAAND//0RET//w0AAAAND////////w0AAAAND//0RE RP/w0AAAAND/
///////w0AAAAND//////xHw0AAAANDwAA///xHw0AAAAND////////w0AAA ANAAAAAAAAAA
0AAAAN3d3d3d3d3d0AAAAN3d3d3d3d3d0AAAAN3d3d3d3d3d0AAAAN3d3d3d 3d3d0AAAAA==
name="invalid.bmp"
filename="invalid.bmp"
Qk1CAgAAAAAAAEIAAAAoAAAAEAAAABAAAAABABAAAwAAAAACAAAAAAAAAAAA AAAAAAAAAAAA
AHwAAOADAAAfAAAAH3wffB98H3wffB98H3wffOB/H3wffB98H3wffB984H8f fOB/4H8ffO89
7z3vPeB/4H/vPe897z3vPeB/4H8ffB98H3zgfwAAAAAAAAAAAAAAAAAAAAAA AAAA4H8ffB98
H3wffB98AAD/f/9//3//f/9//3//f/9/AADvPR98H3wffB98H3wAAP9//3// f/9//3//f/9/
/38AAO89H3wffB98H3wffAAA/3//f/9//3//f/9//3//fwAA7z0ffB98H3wf fB98AAD/f/9/
/3//f/9//3//f/9/AADvPR98H3zgf+B/4H8AAP9//3//f/9//3//f/9//38A AOB/4H8ffB98
4H/gfwAA/3//f/9//3//f/9//3//fwAA4H/gf+B/H3wffB98AAD/f/9//3// fwAAAAAAAAAA
AAAffB98H3wffB98H3wAAP9//3//f/9/AAD/f/9/AAAffB98H3wffB98H3wf fAAA/3//f/9/
/38AAP9/AADgfx98H3wffB98H3wffB98AAD/f/9//3//fwAAAAAffOB/4H8f fB98H3wffB98
4H8AAAAAAAAAAAAAAAAffB98H3zgf+B/H3wffB984H/gfx98H3wffB984H/g fx98H3wffB98
4H/gfx984H8ffB98H3wffB98H3zgfx98H3wffB98H3wffB984H8=
--------------030808080602090902020709--
Re: Restricitions about bmp files [message #117242 is a reply to message #117206] |
Thu, 09 February 2006 07:56  |
Rich Kulp escreveu:
> What does the message say?
>> just an interrogation character and a message in red appears below the
>> image icons. The valid.bmp I can see and select. The invalid.bmp can't
>> be selected.
>> I would like to understand what makes the bmp invalid.
Hi Rich,
I've posted this question at swt newsgroup too, where Carolyn MacLeod is
helping me. She detected that swt doesn't read the image, probably
because there is a problem to decode de image as it is. Below is her post:
I looked at your invalid.bmp, and you are correct, SWT does not read it.
Please open a new bug report in Bugzilla (Eclipse, Platform, Compoent:
SWT) for this.
Please attach your invalid.bmp.
Please mention that it is a 16 bit depth BMP with "BI_BITFIELDS"
compression, which SWT does not currently support.
(i.e. it isn't compressed, actually, but BI_BITFIELDS means that the
palette info is stored in a different place than usual, so we need to
decode it differently).
Also, please let me know which application you used to create this BMP -
I am just curious.
I'll report this problem at Bugzilla.
Sorry if my duplicated post is improper behavior. I just thought that it
could be related both to swt and ve.
Thank you.
Re: Restricitions about bmp files [message #611986 is a reply to message #117169] |
Wed, 08 February 2006 13:41  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
What does invalid mean? Do you get a message? What are the symptoms?
Rich Kulp
Re: Restricitions about bmp files [message #611987 is a reply to message #117182] |
Wed, 08 February 2006 15:32  |
Rich Kulp escreveu:
In the image selection Dialog box the image doesn't appear. I can see
be selected.
Re: Restricitions about bmp files [message #611988 is a reply to message #117194] |
Wed, 08 February 2006 15:47  |
> be selected.
Rich Kulp
Re: Restricitions about bmp files [message #611991 is a reply to message #117206] |
Rich Kulp escreveu:
>> be selected.
Hi Rich,
SWT) for this.
I am just curious.
Thank you.
FUDForum. Page generated in 0.04787 seconds
