| Eclipse Installation [message #10668] |
Wed, 21 January 2009 22:01  |
I would like to use Eclipse on a couple of different computers.
Once I have configured the installation on one machine, can I just copy
that installation (the Eclipse folders) to another machine and use it?
Is ther an easy way to copy a configuration from one machine to another?
Ray
| Re: Eclipse Installation [message #10700 is a reply to message #10668] |
Thu, 22 January 2009 13:27  |
If you are wanting to use copies of the OSEE client to talk to the same
database, then yes, it should be as simple as copying the eclipse
installations to another machine. Zip/Unzip would probably work best.
If you want each instance to use it's own database, you would also need
to export the data from one database and import into the new database.
In posgres, it's a backup/restore.
> Ray
| Re: Eclipse Installation [message #571788 is a reply to message #10668] |
> Ray
FUDForum. Page generated in 0.24919 seconds
