Home » Eclipse Projects » Eclipse Platform » Looking for advice on plugin 'library' projects
| Looking for advice on plugin 'library' projects [message #10651] |
Thu, 24 April 2003 10:55  |
Originally posted by: bob.objfac.com
I have a number of projects that exist just to produce jar files used by
plugins.
In order to conveniently debug in the runtime-workspace, I have made each of
these projects individual plugins. The plugins compile with them through
project dependencies and locate them during debugging through
<requires><import> elements in the manifest.
However, to build a plugin for production, I must manually produce a
build.xml script that compiles each of these 'library' projects into jar
files, copies the jars into the output plugin folder and rewrites the
plugin.xml to change the dependencies to <runtime><library> form.
What I would greatly prefer is a way to set up these projects in a more
natural way, so that the output of each 'library' project is one or more jar
files that are automagically folded into the plugins that depend on them at
debug time, and for which Eclipse will write the build.xml file(s) to
assemble the plugins for production.
Is there a better way to do this?
Bob
| Re: Looking for advice on plugin 'library' projects [message #20598 is a reply to message #10651] |
Mon, 28 April 2003 19:03   |
Originally posted by: John_Arthorne.oti.com_
If you're just going with multiple projects as a means of organizing
code, you may want to consider using multiple source folders in a single
project. You can then setup build.properties to generate one JAR per
source folder, one JAR for all source folder, or some other combination.
This can work well even in large projects. For example, the entire
java UI in Eclipse is in a single project that is broken into several
source folders.
I definitely would NOT recommend creating multiple plugins purely as a
means of organizing development. If you can't conceive of the pieces
being deployed seperately, then keep them in one plugin. That will make
the install story much easier for your users, and avoid plugin registry
bloat.
> plugins.
> Bob
| Re: Looking for advice on plugin 'library' projects [message #22899 is a reply to message #20598] |
Tue, 29 April 2003 14:32  |
"John Arthorne" <John_Arthorne@oti.com_> wrote in message
news:3EADB342.2070005@oti.com_...
> source folders.
I see your point and thanks.
That approach seems to have some drawbacks, though. It is important to me to
keep these "sub-projects" distinct and control the dependencies between
them. Very reluctant doesn't begin to express how I would feel about mixing
something like Xalan (built from source) together with my own code in CVS.
Not to mention that it might very well be used by multiple projects. Nor do
I want to be the one that introduces a separate Xalan plugin. Other IDEs
have a post-build integration process (sometimes called "deployment") that
allows complex applications to be assembled from the build results of
individual, separate projects. I wish Eclipse had this notion.
But it is easier to work with a tool than fight it. Pointers on how to deal
with the Team/CVS issues are welcome. I see that I can check out into a
folder, but how is the overall project, the part that contains the folders,
plugin.xml, etc., checked in and out?
> bloat.
That's a misunderstanding. I don't deploy them as separate plugins; the fact
that they are plugins at all is purely so I can run/debug with PDE. I would
much prefer that these projects just build library jars. If you can suggest
a way to have separate projects build library jars that can be used by a
plugin launched with PDE without any manual steps, that would solve my
problem!
Bob
Current Time: Sun Nov 02 22:17:10 EST 2025
Powered by FUDForum. Page generated in 0.06259 seconds
