Home » Eclipse Projects » GEF » Randys patch?
Randys patch? [message #10640] Fri, 21 June 2002 04:01 Go to next message
Originally posted by: g.wagenknecht.intershop.de
Hi!
Some time ago Randy provided a patch for eclipse to move the perspective
colum to the toolbar and to reduce the line numbers to 4 digits.
Does this patch works with F3? Can someone post it again here or a download
link?
Gunnar
Re: Randys patch? [message #10673 is a reply to message #10640] Fri, 21 June 2002 04:06 Go to previous messageGo to next message
Gunnar Wagenknecht wrote:
> Hi!
And quite a few other things.
> link?
Did not try it with F3, but there should not be any API changes. Search
the news or mmoebius.gmxhome.de somewhere on resources.
martin
Re: Randys patch? [message #10705 is a reply to message #10640] Fri, 21 June 2002 09:41 Go to previous messageGo to next message
Works in F3 for me (Win2K). Attached. :-)
Instructions: put uipatch.jar in %ECLIPSE_HOME%\plugins\org.eclipse.ui_2.0.0
and modify plugin.xml:
<runtime>
<library name="uipatch.jar">
<export name="*"/>
</library>
<library name="workbench.jar">
<export name="*"/>
</library>
</runtime>
Christopher Bradford
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:aeul3g$7mq$1@rogue.oti.com...
> Hi!
download
> link?
> Gunnar
  • Attachment: uipatch.jar
    (Size: 146.97KB, Downloaded 112 times)
Re: Randys patch? [message #10764 is a reply to message #10640] Fri, 21 June 2002 11:05 Go to previous messageGo to next message
Originally posted by: none.ibm.com
There are changes between F2 and F3 that affected my patch. WorkbenchWindow
changed a lot, and I have to modify that class for a couple of reasons to
make the shortcut bar layout properly.
I tried changing Coolbars back to Toolbars, but this had a side-effect on
the Menu for some reason.
Here it is for F3. Enjoy at your own risk :-)
    (Size: 148.68KB, Downloaded 116 times)
Re: Randys patch? [message #10795 is a reply to message #10764] Fri, 21 June 2002 11:17 Go to previous messageGo to next message
"Randy Hudson" <none@ibm.com> schrieb im Newsbeitrag
news:aeve23$jmq$1@rogue.oti.com...
Thanks!
Re: Randys patch? [message #14002 is a reply to message #10764] Fri, 19 July 2002 14:34 Go to previous message
It seems to be giving me problems in 2.0. Anyone else having problems?
Randy, is there an updated version for 2.0 (in the works)?
"Randy Hudson" <none@ibm.com> wrote in message
WorkbenchWindow
Previous Topic:Reorganize Newsgroups
Next Topic:Unification of Marquee and selection tool
Current Time: Sat Jul 05 09:17:00 EDT 2025
Powered by FUDForum. Page generated in 0.16080 seconds
