| Need help migrating from Delphi to Eclipse [message #116766] | Fri, 11 November 2005 04:17  |  |
| Eclipse User  |  |  |  |  | Originally posted by: bsmith.nospam.com
 I used Delphi extensively for a number of years.  I'm looking to migrate
 to Eclipse.  My Delphi applications use dbExpress to connect with a
 MySQL database.  The applications use controls like TListView and
 TRichEdit.  I'm very interested in creating similar Windows applications
 with Eclipse.  The CDT add-on caught my eye.
 In Delphi if I want to create the most basic application I would create
 a new application, add a button then in the button's OnClick event I
 would add some code like ShowMessage('Hello world');
 How can you do this with Eclipse and CDT?  I saw a way to create a
 sample application but it looks like it creates a hello world DOS
 console application.  Is there a visual forms designer like Delphi has?
 Any advice would be appreciated.
| Re: Need help migrating from Delphi to Eclipse [message #116778 is a reply to message #116766] | Fri, 11 November 2005 04:48   |  |
| Eclipse User  |  |  |  |  | Hello Bill,
 until now, indeed CDT offers only a IDE which you can use to create C++
 applications the old way. That means if you want to create applications with
 window, buttons, listboxes etc. there is no visual tool (up to now) under
 Eclipse and its plugins available and you must use the WINDOWS API to create
 your windows, buttons, etc.
 Eclipse is JAVA based and there you can use e.g. the Visual Editor plugin to
 create windows applications similar to Delphi.
 So if you come from Delphi why not switch to JAVA instead to C++? Then you
 can get the full advantages of Eclipse and it's plugins.
 But my recommedation is to look behind JAVA first, to understand how JAVA
 applications work, how the event handling works, etc. Then if you are able
 to create JAVA applications just using a simple text editor, you can use the
 Visual Editor under Eclipse to accelerate the development process.
 hth,
 Mr. Burns
| Re: Need help migrating from Delphi to Eclipse [message #116894 is a reply to message #116778] | Fri, 11 November 2005 08:37  |  |
| Eclipse User  |  |  |  |  | Originally posted by: radoslawg.xxxx.xx
 Mr. Burns napisał(a):
 > Hello Bill,
 Well.. You can ofcourse use any GUI framework you can find with CDT.
 There is no limitation to Windows API. For free GUIs I recommend
 wxWindows or (more direct) GTK+.
 Radek.
FUDForum. Page generated in 0.06542 seconds
