Home » Language IDEs » Java Development Tools (JDT) » CVS Add Directory Problem
CVS Add Directory Problem [message #116699] Thu, 13 November 2003 16:43 Go to next message
Originally posted by: groberts.seabase.com
Hi All,
I am having a problem with either the CVS plugin or with CVS itself.
Here's the setup:
I have two users UA and UB.
I have two repositories RA and RB.
The users have the same version of eclipse and the same os.
The repositories are on two different machines. Both machines have the
same version of Linux, have the same version of CVS, have the same project
imported. File and permissions are also the same.
Here's the problem:
If UA adds a directory and a file within it to RA, then UB runs
Team/Synchronize against RA everything works. That is, Team>Synchronize
shows that the directory and file have been added. UB can then run an
update and life is good.
Do the same thing with RB. That is, UA adds and UB synchs and
Team>Synchronize shows the message that the workspace and the repository
are in synch. They of course are not in synch. Running update -d from the
command line will bring them into synch.
I'll summarize:
With RA, UA adds, UB synchs, and Team>Synchronize shows a difference.
With RB, UA adds, UB synchs, and Team>Synchronize shows NO difference.
Can anyone account for this difference in behavior between RA and RB?
It is as if eclipse is setting the update -d flag is when using RA but not
setting it when using RB.
Re: CVS Add Directory Problem [message #117032 is a reply to message #116699] Fri, 14 November 2003 14:02 Go to previous messageGo to next message
Can you provide more versions info about CVS/Eclipse platform?
Geoffry Roberts wrote:
> Hi All,
> Here's the setup:
> Here's the problem:
> I'll summarize:
> Thanks
Re: CVS Add Directory Problem [message #117107 is a reply to message #117032] Fri, 14 November 2003 17:08 Go to previous message
Versions are
Linux: 2.4.7-10 (kernel)
CVS: 1.11.1p1
eclipse: 2.12
Another bit of information that may matter is that RA has entries in
CVSROOT/modules and RB does not.
Thanks for responding.
> > Hi All,
> > Here's the setup:
> > Here's the problem:
> > I'll summarize:
> > Thanks
Previous Topic:Tab settings for different file types
Next Topic:run from java cmd
Current Time: Thu Jun 19 16:41:42 EDT 2025
Powered by FUDForum. Page generated in 0.03012 seconds
