Home » Archived » Visual Editor (VE) » VE not working (IllegalAccessException)
VE not working (IllegalAccessException) [message #116630] Thu, 02 February 2006 04:00 Go to next message
Originally posted by: cc.yahoo.it
Hi all,
I've installed VE 1.2M1 on:
- JDK 5.0 update 6
- Eclipse-SDK-3.2M4 (file )
- EMF build 2.2.0M4 (file emf-sdo-runtime-2.2.0M4.zip)
- GEF Build 3.2M4 (file GEF-runtime-3.2M4.zip)
When I create a visual class that extends the Class Composite, the Visual
Editor windows opens without showing the Composite area in which I should
put my widgets
I noticed that if I move the mouse over the area where the Composite should
be I obtain a the following error displayed inside a tooltip:
IllegalAccessException (Class
org.eclipse.jem.internal.proxy.initparser.tree.ExpressionPro cesser cannot
access a member of class org.eclipse.swt.widgets.Composite with modifier...)
I opened the .log file and I read the following errors:
!SESSION 2006-02-01
17:11:51.463 -----------------------------------------------
eclipse.buildId=I20051215-1506
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -consolelog
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-01 17:15:37.027
!MESSAGE
+++ Warning +++: Wed Feb 01 17:15:37 CET 2006 Project
(IrriGraph2D)-Beaninfo:err>
java.lang.NoClassDefFoundError:
org/eclipse/jem/internal/proxy/vm/remote/RemoteVMApplication
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-01 17:15:39.381
!MESSAGE IWAV0138E Remote VM terminated too soon. See .log file for trace of
output. For VM "Project (IrriGraph2D)-Beaninfo".
IWAV0072I Remote VM terminated before any commands can be sent. Following
are the error and output streams.
-- Error Stream --
Exception in thread "main"
-- Output Stream --
-- End of Stream Output --
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-01 17:15:39.411
!MESSAGE No Server to retrieve a connection.
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-01 17:15:39.421
!MESSAGE
+++ Warning +++: Wed Feb 01 17:15:39 CET 2006 Project
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-02-01 17:15:39.441
!MESSAGE IWAV0155E Introspection failed on class "java.lang.Object." msg="."
!STACK 0
java.lang.IllegalStateException: IWAV0171E Could not create a socket
connection to remote vm.
org.eclipse.jem.internal.proxy.remote.REMProxyFactoryRegistr y.createConnection(REMProxyFactoryRegistry.java:439)
org.eclipse.jem.internal.proxy.remote.REMProxyFactoryRegistr y.getFreeConnection(REMProxyFactoryRegistry.java:374)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:364)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:267)
org.eclipse.jem.internal.proxy.remote.awt.REMRegisterAWT.reg isterAWT(REMRegisterAWT.java:31)
org.eclipse.jem.internal.proxy.remote.LocalProxyLaunchDelega te.launch(LocalProxyLaunchDelegate.java:412)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:558)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:463)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:330)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.cr eateRegistry(BeaninfoNature.java:474)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.doCreateRegistry(CreateRegistryJobHandler.java:159)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.processCreateRegistry(CreateRegistryJobHandler.java: 114)
org.eclipse.jem.internal.beaninfo.adapters.UICreateRegistryJ obHandler.processCreateRegistry(UICreateRegistryJobHandler.j ava:52)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.createRegistry(CreateRegistryJobHandler.java:80)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.ge tRegistry(BeaninfoNature.java:455)
Could you help me in solving this problem?
Thank you very much in advance.
Re: VE not working (IllegalAccessException) [message #116652 is a reply to message #116630] Thu, 02 February 2006 07:24 Go to previous messageGo to next message
> !STACK 0
It looks like you're having trouble creating a network connection to the
remote VMs. Do you have a firewall or other software installed that will
prevent tcp/ip connections to localhost (127.0.0.1)?
- Jeff
Re: VE not working (IllegalAccessException) [message #116666 is a reply to message #116652] Thu, 02 February 2006 08:32 Go to previous messageGo to next message
Hi Jeff,
I disabled firewall and re-installed eclipse SDK and Visual Editor. After
that, I followed the steps below:
1. I created a Java project
2. I configured the project build path in order to add the
"org.eclipse.swt.win32.win32.x86_3.2.0.v3218.jar" library
3. I imported into the project the files swt-gdip-win32-3218.dll and
swt-win32-3218.dll (these dlls are necessary for the development of my
visual class)
4. I created my visual class extending Composite (through the wizard)
After few seconds, during Visual Editor window loading, I received a pop-up
window saying:
An internal error occurred during: "Create Remote VM for Visual Editor for
Java"
So I didn't solve my problem disabling the firewall. Here attached the .log
file, I hope it could help you!
"Jeff Myers" <jeff.myers@eclipse.org> wrote in message
news:drstm5$30d$2@utils.eclipse.org...
>> msg="."
>> !STACK 0
> - Jeff
  • Attachment: .log
    (Size: 302.57KB, Downloaded 268 times)
Re: VE not working (IllegalAccessException) [message #116694 is a reply to message #116666] Thu, 02 February 2006 08:54 Go to previous messageGo to next message
Let's try a different set of steps.
1. Create a Java Project.
2. Create a Visual Class, extending Composite through the wizard.
3. Profit!
The New Visual Class wizard will handle configuring your project to use
the SWT libraries for you. VE won't work properly if you add the SWT
jars to your project manually.
- Jeff
ccc wrote:
> Hi Jeff,
> visual class)
> window saying:
> Java"
>>> msg="."
>>> !STACK 0
>> - Jeff
Re: VE not working (IllegalAccessException) [message #116744 is a reply to message #116694] Thu, 02 February 2006 09:18 Go to previous messageGo to next message
Hi Jeff,
I've done what you suggested, but now I keep on seeing nothing on the Visual
Editor Windows and get the following error:
Help please!!! :-)
!SESSION 2006-02-02
15:10:06.753 -----------------------------------------------
This is a continuation of log file C:\eclipse 3.2M4\.metadata\.bak_3.log
Created Time: 2006-02-02 15:13:18.649
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-02-02 15:13:18.649
"org.eclipse.swt.widgets.Widget." msg="."
!STACK 0
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoProxyCons tants. <init>(BeaninfoProxyConstants.java:58)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoProxyCons tants.getConstants(BeaninfoProxyConstants.java:45)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getProxyConstants(BeaninfoClassAdapter.java:1177)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:731)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:429)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:416)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:637)
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEAnnotat ions(JavaClassImpl.java:387)
org.eclipse.ve.internal.cde.emf.ClassDecoratorTypeIterator.f indDecorator(ClassDecoratorTypeIterator.java:37)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.findN ext(ClassDecoratorIterator.java:76)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.findN ext(ClassDecoratorIterator.java:78)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.next( ClassDecoratorIterator.java:61)
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecoratorWithFeature(ClassDecoratorFeatureAccess.java:44)
org.eclipse.ve.internal.cde.emf.ClassDescriptorDecoratorPoli cy.findDecorator(ClassDescriptorDecoratorPolicy.java:128)
org.eclipse.ve.internal.cde.emf.ClassDescriptorDecoratorPoli cy.getModelAdapterClassname(ClassDescriptorDecoratorPolicy.j ava:195)
org.eclipse.ve.internal.cde.emf.DefaultModelAdapterFactory.c reateAdapter(DefaultModelAdapterFactory.java:106)
org.eclipse.ve.internal.cde.emf.DefaultModelAdapterFactory.c reateAdapter(DefaultModelAdapterFactory.java:95)
org.eclipse.ve.internal.cde.emf.DefaultModelAdapterFactory.g etAdapter(DefaultModelAdapterFactory.java:61)
org.eclipse.ve.internal.cde.emf.AbstractEMFContainerPolicy.g etTrueChild(AbstractEMFContainerPolicy.java:259)
org.eclipse.ve.internal.java.vce.SubclassCompositionContaine rPolicy.getTrueChild(SubclassCompositionContainerPolicy.java :44)
org.eclipse.ve.internal.cde.emf.AbstractEMFContainerPolicy.g etTrueChildren(AbstractEMFContainerPolicy.java:307)
org.eclipse.ve.internal.cde.emf.AbstractEMFContainerPolicy.g etDeleteDependentCommand(AbstractEMFContainerPolicy.java:597 )
org.eclipse.ve.internal.cde.core.ContainerPolicy.getDeleteDe pendentCommand(ContainerPolicy.java:244)
org.eclipse.ve.internal.cde.core.ContainerPolicy.getCommand( ContainerPolicy.java:389)
org.eclipse.ve.internal.cde.core.VisualInfoXYLayoutEditPolic y.getDeleteDependantCommand(VisualInfoXYLayoutEditPolicy.jav a:136)
org.eclipse.gef.editpolicies.LayoutEditPolicy.getCommand(Lay outEditPolicy.java:184)
org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy.get Command(ConstrainedLayoutEditPolicy.java:154)
org.eclipse.ve.internal.cde.core.XYLayoutEditPolicy.getComma nd(XYLayoutEditPolicy.java:255)
org.eclipse.ve.internal.cde.core.VisualInfoXYLayoutEditPolic y.getCommand(VisualInfoXYLayoutEditPolicy.java:209)
org.eclipse.gef.editparts.AbstractEditPart.getCommand(Abstra ctEditPart.java:489)
org.eclipse.ve.internal.cde.core.DefaultComponentEditPolicy. createDeleteCommand(DefaultComponentEditPolicy.java:33)
org.eclipse.gef.editpolicies.ComponentEditPolicy.getDeleteCo mmand(ComponentEditPolicy.java:67)
org.eclipse.gef.editpolicies.ComponentEditPolicy.getCommand( ComponentEditPolicy.java:56)
org.eclipse.ve.internal.java.core.CutJavaBeanAction.calculat eEnabled(CutJavaBeanAction.java:56)
org.eclipse.gef.ui.actions.WorkbenchPartAction.isEnabled(Wor kbenchPartAction.java:111)
org.eclipse.ui.texteditor.RetargetTextEditorAction.setAction (RetargetTextEditorAction.java:188)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$4.focusGained(JavaVisualEditorPart.java:2507)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:105)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:914)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:919)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 1939)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2101)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:382 1)
at org.eclipse.swt.widgets.Canvas.WM_SETFOCUS(Canvas.java:296)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3277 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3963 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:704)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:2295)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:75 0)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setFocus(JavaVisualEditorPart.java:2814)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:304)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 116)
at org.eclipse.ui.internal.WorkbenchPage$3.run(WorkbenchPage.ja va:571)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:785)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:566)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2962)
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:2534)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:251)
at org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:88)
at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:2 16)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:10 49)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:16 86)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3253 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1538)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1700 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:77)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3299 )
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:2160)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2900)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1762)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1726)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-02-02 15:13:18.669
"org.eclipse.swt.widgets.Control." msg="."
!STACK 0
!ENTRY org.eclipse.ui 4 4 2006-02-02 15:13:18.769
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-02-02 15:13:18.769
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:3283)
at org.eclipse.swt.SWT.error(SWT.java:3206)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3262)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2908)
Caused by: java.lang.NullPointerException
org.eclipse.ve.internal.java.core.BeanPropertyDescriptorAdap ter.isReadOnly(BeanPropertyDescriptorAdapter.java:390)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:802 )
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:916)
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 20 more
news:drt2u2$cej$1@utils.eclipse.org...
> 3. Profit!
> the SWT libraries for you. VE won't work properly if you add the SWT jars
> - Jeff
> ccc wrote:
>> Hi Jeff,
>> visual class)
>> pop-up window saying:
>> for Java"
>> .log file, I hope it could help you!
>>>> msg="."
>>>> !STACK 0
>>> - Jeff
Re: VE not working (IllegalAccessException) [message #116758 is a reply to message #116744] Thu, 02 February 2006 09:31 Go to previous messageGo to next message
I cleaned my project and the new problem disappeared!
I noticed that the error:
Java"
now occurs randomly when I close eclipse (after leaving Visual Editor Window
opened) and reopen it.
Any ideas?
"ccc" <cc@yahoo.it> wrote in message news:drt4cj$fq8$1@utils.eclipse.org...
> Hi Jeff,
> Visual Editor Windows and get the following error:
> Help please!!! :-)
> !SESSION 2006-02-02
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 20 more
>> 3. Profit!
>> - Jeff
>> ccc wrote:
>>> Hi Jeff,
>>> After that, I followed the steps below:
>>> visual class)
>>> for Java"
>>>>> msg="."
>>>>> !STACK 0
>>>> the
>>>> will
>>>> - Jeff
Re: VE not working (IllegalAccessException) [message #116771 is a reply to message #116758] Thu, 02 February 2006 09:41 Go to previous message
> Java"
> Any ideas?
Hmmm... does your .log have anything new when this error occurs? It's
possible that it's trying to start up a new VM when you're shutting down
Eclipse and getting confused. If this is the case, please open a bug in
bugzilla: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=VE
- Jeff
Re: VE not working (IllegalAccessException) [message #611944 is a reply to message #116630] Thu, 02 February 2006 07:24 Go to previous message
> !STACK 0
- Jeff
Re: VE not working (IllegalAccessException) [message #611947 is a reply to message #116652] Thu, 02 February 2006 08:32 Go to previous message
Hi Jeff,
visual class)
window saying:
Java"
>> msg="."
>> !STACK 0
> - Jeff
  • Attachment: .log
    (Size: 302.57KB, Downloaded 191 times)
Re: VE not working (IllegalAccessException) [message #611948 is a reply to message #116666] Thu, 02 February 2006 08:54 Go to previous message
3. Profit!
- Jeff
ccc wrote:
> Hi Jeff,
> visual class)
> window saying:
> Java"
>>> msg="."
>>> !STACK 0
>> - Jeff
Re: VE not working (IllegalAccessException) [message #611952 is a reply to message #116694] Thu, 02 February 2006 09:18 Go to previous message
Hi Jeff,
Help please!!! :-)
!SESSION 2006-02-02
!STACK 0
!STACK 0
!STACK 0
... 20 more
> 3. Profit!
> - Jeff
> ccc wrote:
>> Hi Jeff,
>> visual class)
>> for Java"
>>>> msg="."
>>>> !STACK 0
>>> - Jeff
Re: VE not working (IllegalAccessException) [message #611953 is a reply to message #116744] Thu, 02 February 2006 09:31 Go to previous message
Java"
Any ideas?
> Hi Jeff,
> Help please!!! :-)
> !SESSION 2006-02-02
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 20 more
>> 3. Profit!
>> - Jeff
>> ccc wrote:
>>> Hi Jeff,
>>> visual class)
>>> for Java"
>>>>> msg="."
>>>>> !STACK 0
>>>> the
>>>> will
>>>> - Jeff
Re: VE not working (IllegalAccessException) [message #611954 is a reply to message #116758] Thu, 02 February 2006 09:41 Go to previous message
> Java"
> Any ideas?
- Jeff
Previous Topic:Support for Other Layout Managers
Next Topic:VE JMenu RollOverIcon
Current Time: Fri Nov 07 23:57:46 EST 2025
Powered by FUDForum. Page generated in 0.09202 seconds
