Home » Language IDEs » ServerTools (WTP) » eclipse 3.1 + geronimo plugin + wtp m4
eclipse 3.1 + geronimo plugin + wtp m4 [message #116608] Wed, 06 July 2005 08:09 Go to next message
Originally posted by: oggokoko.gmail.com
Hi guys,
i installed the eclipse 3.1 production release with wtp M4 and geronimo
plugin. Now in the j2ee navigator on every click I'm getting “An error has
accurred. See the log for more details.”. And in the log i have the
following error :
!ENTRY org.eclipse.jface 4 2 2005-07-06 14:06:13.860
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.jdt.internal.ui.actions.ActionMessages.getString (Ljava/lang/String;)Ljava/lang/String;
org.eclipse.jst.common.navigator.internal.actions.OpenAction . <init>(OpenAction.java:78)
org.eclipse.jst.common.navigator.internal.actions.OpenEditor ActionGroup. <init>(OpenEditorActionGroup.java:66)
org.eclipse.jst.common.navigator.internal.actions.NavigateAc tionGroup. <init>(NavigateActionGroup.java:52)
org.eclipse.jst.common.navigator.internal.actions.OpenAction sExtension.init(OpenActionsExtension.java:72)
org.eclipse.wst.common.navigator.internal.provisional.views. NavigatorActionService.initialize(NavigatorActionService.jav a:379)
org.eclipse.wst.common.navigator.internal.provisional.views. NavigatorActionService.getActionProviderInstance(NavigatorAc tionService.java:280)
org.eclipse.wst.common.navigator.internal.provisional.views. NavigatorActionService.fillActionBars(NavigatorActionService .java:229)
org.eclipse.wst.common.navigator.internal.provisional.views. CommonNavigatorManager.selectionChanged(CommonNavigatorManag er.java:97)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:1784)
org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.java:1027)
org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer.java:1053)
org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:209)
at org.eclipse.jface.util.OpenStrategy.access$3(OpenStrategy.ja va:204)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:364)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
If someone has a workaround for this problem, please let me know. Thanx in
advance.
Cheers
oggo
Re: eclipse 3.1 + geronimo plugin + wtp m4 [message #116863 is a reply to message #116608] Wed, 06 July 2005 12:40 Go to previous messageGo to next message
oggo wrote:
> Hi guys, i installed the eclipse 3.1 production release with wtp M4 and
> geronimo plugin. Now in the j2ee navigator on every click I'm getting
> �An error has accurred. See the log for more details.�. And in the log i
> have the following error :
> !STACK 0
> in advance.
> Cheers oggo
WTP M4 can only be used with Eclipse 3.1M6. For the Eclipse 3.1
production release, you must use M5 (or newer).
- Nitin
Re: eclipse 3.1 + geronimo plugin + wtp m4 [message #117205 is a reply to message #116863] Thu, 07 July 2005 03:56 Go to previous messageGo to next message
sure, but when i use wtp M5 there is a problem creating geronimo server
:-( do you have some experience configuring geronimo in eclipse
environment?
Re: eclipse 3.1 + geronimo plugin + wtp m4 [message #117233 is a reply to message #116608] Thu, 07 July 2005 04:34 Go to previous message
hi again,
i found out my problem. it's a bit stupid from my side, but first i
installed wtp m5 and geronimo plugin, at there was some conflict, then i
tried with wtp m4 amd geronimo plug in ... and finaly i discovered, that i
need only wtp m5 and no geronimo plugin. i hope with this posting will
help to another starters like me.
cheers
oggo
Previous Topic:Eclipse 3.1 + Webtool M5 : Issues with java/web src dir for web module config
Next Topic:Installing Eclipse with a whitespace in the path
Current Time: Tue Nov 04 05:51:04 EST 2025
Powered by FUDForum. Page generated in 0.03519 seconds
