Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] newbee question .. MappingException: Could not determine type for:
[Teneo] newbee question .. MappingException: Could not determine type for: [message #116598] Thu, 03 April 2008 07:52 Go to next message
Originally posted by: psanampu.cisco.com
hi,
I have just started with the library tutorial on elver.org. The library xsd
is attached.
I have done the following things:
1) created model and edit plugins for the library xsd
2) setup a hsql server instance , created a library db and modified the
hibernate properties accordingly.
3) I am using the versions we got from the eclipsecon2008 Teneo session in
model-driven-dev tutorial on first day.
[ except hsql related, which I took the latest from hsql.org ] .
here is the test method I am invoking from a view class of another plugin ..
public String testAddBook(){
final String dataStoreName = "LibraryDataStore";
final Session session = StoreController.getInstance().getSession();
final Transaction tx = session.getTransaction();
session.beginTransaction();
//Create and populate Library
Library library = LibraryFactory.eINSTANCE.createLibrary();
library.setName("My Library");
// Make it persistent.
session.save(library);
// Create a writer...
Writer writer = LibraryFactory.eINSTANCE.createWriter();
writer.setName("JRR Tolkien");
// ...and one of his books.
Book book = LibraryFactory.eINSTANCE.createBook();
book.setAuthor(writer);
book.setPages(305);
book.setTitle("The Hobbit");
book.setCategory(BookCategory.SCIENCE_FICTION);
// Add the Writer and Book to the Library. They are made
// persistent automatically because the Library is itself
// already persistent.
library.getWriters().add(writer);
library.getBooks().add(book);
//Commit Transaction and close Session
//The Library is not stored in the database until you commit the
Transaction:
session.getTransaction().commit();
session.close();
During database schema update call, I am getting the following error .
org.eclipse.emf.teneo.hibernate.mapping.ENumUserType, at table: book, for
columns: [org.hibernate.mapping.Column(category)]
org.hibernate.MappingException: Could not determine type for:
at org.hibernate.mapping.SimpleValue.getType(SimpleValue.java:2 69)
at org.hibernate.mapping.SimpleValue.isValid(SimpleValue.java:2 53)
at org.hibernate.mapping.Property.isValid(Property.java:185)
at org.hibernate.mapping.PersistentClass.validate(PersistentCla ss.java:440)
at org.hibernate.mapping.RootClass.validate(RootClass.java:192)
at org.hibernate.cfg.Configuration.validate(Configuration.java: 1108)
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1293)
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:172)
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:86)
at test.StoreController.initializeDataStore(StoreController.jav a:65)
at test.StoreController.getDataStore(StoreController.java:31)
at test.StoreController.getSession(StoreController.java:26)
at test.TestTeneo.testAddBook(TestTeneo.java:46)
What am I missing ?
Appreciate your help
Prasad
  • Attachment: library.xsd
    (Size: 1.54KB, Downloaded 333 times)
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #116703 is a reply to message #116598] Thu, 03 April 2008 08:00 Go to previous messageGo to next message
Hi Prasad,
How does the StoreController initialize the Teneo datastore, can you post that part of the code?
gr. Martin
prasad wrote:
> hi,
> is attached.
> book.setPages(305);
> Transaction:
> session.close();
> at
> at
> at
> What am I missing ?
> Thanks
> Prasad
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #116715 is a reply to message #116703] Thu, 03 April 2008 08:15 Go to previous messageGo to next message
Hi Prasad,
This could also be a class-loading/plugin dependency issue (that hibernate can not see the teneo
hibernate.mapper classes).
Can you let me know how you setup the hibernate libraries? Did you put them in a separate plugin
with Eclipse-Buddypolicy: dependent in the manifest.mf?
gr. Martin
Martin Taal wrote:
> Hi Prasad,
> gr. Martin
> prasad wrote:
>> hi,
>> library xsd is attached.
>> the hibernate properties accordingly.
>> session in model-driven-dev tutorial on first day.
>> plugin ..
>> book.setPages(305);
>> Transaction:
>> session.close();
>> for columns: [org.hibernate.mapping.Column(category)]
>> at
>> at
>> at
>> at
>> What am I missing ?
>> Thanks
>> Prasad
The Netherlands
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #116725 is a reply to message #116703] Thu, 03 April 2008 08:15 Go to previous messageGo to next message
hi Martin,
here it is:
package test;
import java.io.IOException;
import java.util.Properties;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.teneo.PersistenceOptions;
import org.eclipse.emf.teneo.hibernate.HbHelper;
import org.eclipse.emf.teneo.hibernate.HbSessionDataStore;
import org.hibernate.Session;
public class StoreController {
public static final URI DATABASE_URI = URI
..createURI("hibernate://?dsname=library");
private static StoreController instance = new StoreController();
public static StoreController getInstance() {
return instance;
private HbSessionDataStore dataStore = null;
public Session getSession() {
return getDataStore().getSessionFactory().openSession();
public HbSessionDataStore getDataStore() {
if (dataStore == null) {
dataStore = initializeDataStore();
return dataStore;
public void closeDataStore() {
getDataStore().close();
public HbSessionDataStore initializeDataStore() {
final HbSessionDataStore localDataStore = new HbSessionDataStore();
localDataStore.setName("library");
HbHelper.INSTANCE.register(localDataStore);
final Properties props = new Properties();
try {
props
..load(this.getClass().getResourceAsStream(
"/teneo.properties"));
//props.put(PersistenceOptions.USE_MAPPING_FILE, true);
} catch (IOException e) {
throw new IllegalStateException(e);
localDataStore.setProperties(props);
// get the epackage nsuri
final String[] nsuris = props.getProperty("nsuri").split(",");
final EPackage[] ePackages = new EPackage[nsuris.length];
int i = 0;
for (String nsuri : nsuris) {
ePackages[i++] = EPackage.Registry.INSTANCE.getEPackage(nsuri
..trim());
localDataStore.setEPackages(ePackages);
localDataStore.initialize();
System.err.println(localDataStore.getMappingXML());
return localDataStore;
"Martin Taal" <mtaal@elver.org> wrote in message
news:ft2gsh$ft3$1@build.eclipse.org...
> Hi Prasad,
> gr. Martin
> prasad wrote:
>> hi,
>> xsd is attached.
>> book.setPages(305);
>> Transaction:
>> session.close();
>> at
>> at
>> at
>> at
>> What am I missing ?
>> Thanks
>> Prasad
> The Netherlands
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #116735 is a reply to message #116715] Thu, 03 April 2008 08:24 Go to previous messageGo to next message
Great !! That did the trick. Sorry about missing that instruction in the
first place.
thanks
Prasad
news:ft2hop$un$1@build.eclipse.org...
> Hi Prasad,
> can not see the teneo hibernate.mapper classes).
> them in a separate plugin with Eclipse-Buddypolicy: dependent in the
> manifest.mf?
> gr. Martin
> Martin Taal wrote:
>> Hi Prasad,
>> gr. Martin
>> prasad wrote:
>>> hi,
>>> xsd is attached.
>>> plugin ..
>>> book.setPages(305);
>>> Transaction:
>>> session.close();
>>> at
>>> at
>>> at
>>> at
>>> What am I missing ?
>>> Thanks
>>> Prasad
> The Netherlands
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #116748 is a reply to message #116735] Thu, 03 April 2008 08:30 Go to previous message
Ok good, btw you can simplify the initialization of the datastore by getting rid of the part that
reads the epackage on the basis of the nsuri, if you have programmatic access (at compile time) to
the epackages then you can also do this:
localDataStore.setEPackages(new EPackage[]{LibraryPackage.eINSTANCE});
gr. Martin
> first place.
> thanks
> Prasad
>> Hi Prasad,
>> manifest.mf?
>> gr. Martin
>> Martin Taal wrote:
>>> Hi Prasad,
>>> gr. Martin
>>> prasad wrote:
>>>> hi,
>>>> xsd is attached.
>>>> plugin ..
>>>> book.setPages(305);
>>>> Transaction:
>>>> session.close();
>>>> at
>>>> at
>>>> at
>>>> at
>>>> What am I missing ?
>>>> Thanks
>>>> Prasad
>> The Netherlands
The Netherlands
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #616061 is a reply to message #116598] Thu, 03 April 2008 08:00 Go to previous message
Hi Prasad,
gr. Martin
prasad wrote:
> hi,
> is attached.
> book.setPages(305);
> Transaction:
> session.close();
> at
> at
> at
> What am I missing ?
> Thanks
> Prasad
The Netherlands
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #616062 is a reply to message #116703] Thu, 03 April 2008 08:15 Go to previous message
Hi Prasad,
gr. Martin
Martin Taal wrote:
> Hi Prasad,
> gr. Martin
> prasad wrote:
>> hi,
>> plugin ..
>> book.setPages(305);
>> Transaction:
>> session.close();
>> at
>> at
>> at
>> at
>> What am I missing ?
>> Thanks
>> Prasad
The Netherlands
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #616063 is a reply to message #116703] Thu, 03 April 2008 08:15 Go to previous message
hi Martin,
here it is:
package test;
return instance;
return dataStore;
try {
props
int i = 0;
..trim());
> Hi Prasad,
> gr. Martin
> prasad wrote:
>> hi,
>> xsd is attached.
>> book.setPages(305);
>> Transaction:
>> session.close();
>> at
>> at
>> at
>> at
>> What am I missing ?
>> Thanks
>> Prasad
> The Netherlands
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #616064 is a reply to message #116715] Thu, 03 April 2008 08:24 Go to previous message
first place.
thanks
Prasad
> Hi Prasad,
> manifest.mf?
> gr. Martin
> Martin Taal wrote:
>> Hi Prasad,
>> gr. Martin
>> prasad wrote:
>>> hi,
>>> xsd is attached.
>>> plugin ..
>>> book.setPages(305);
>>> Transaction:
>>> session.close();
>>> at
>>> at
>>> at
>>> at
>>> What am I missing ?
>>> Thanks
>>> Prasad
> The Netherlands
Re: [Teneo] newbee question .. MappingException: Could not determine type for: [message #616065 is a reply to message #116735] Thu, 03 April 2008 08:30 Go to previous message
gr. Martin
> first place.
> thanks
> Prasad
>> Hi Prasad,
>> manifest.mf?
>> gr. Martin
>> Martin Taal wrote:
>>> Hi Prasad,
>>> gr. Martin
>>> prasad wrote:
>>>> hi,
>>>> xsd is attached.
>>>> plugin ..
>>>> book.setPages(305);
>>>> Transaction:
>>>> session.close();
>>>> at
>>>> at
>>>> at
>>>> at
>>>> What am I missing ?
>>>> Thanks
>>>> Prasad
>> The Netherlands
The Netherlands
Previous Topic:[Teneo] newbee question .. MappingException: Could not determine type for:
Next Topic:[Teneo] Generating JPA Annotations in Java Code
Current Time: Wed Nov 26 09:58:52 EST 2025
Powered by FUDForum. Page generated in 0.05092 seconds
